Question about KitchenAid KUDC10IXSS Builtin Dishwasher
Leak from front door seal
Leaks from the front door
Rubber Seal leaks
You have to replace the whole door seal.It can be done through the port hole,difficult but achievable or you can strip the front of the appliance off and do the inner part easier.
Unplug the appliance.
Open the door and take the seal retaining ring out of the door seal.
Peel the door seal off the front panel and fold it inside.
Take the seal retaining ring/spring out of the tub side of the seal.
Pull the seal off and take it out of the appliance.
Fit the new seal to the tub,look at the seal and tub for matching arrow marks to help align it.
Fit the retaining ring/spring into the groove in the seal and over the lip of the tub.
Fit the seal to the front panel and then fit the retaining ring into the seal.
Restore the power to the appliance and leak test it.
If you find you can't get the seal on.
Take the top off the appliance.
Take the dispenser out.
Take out the screws revealed.
Take out the screws holding the door lock.
Take off the plastic cover below the door and remove the screws revealed.
Take the front panel off.
If the panel won't come down and off there will be a hidden screw that requires the facia panel to be removed.It's snap together plastic,just release the catches and carefully remove the facia.
Take the screw out, take the panel off.
Fit the inner part of the seal to the tub.
Reassemble the front of the appliance.
Fit the seal to the front.
Leak test the appliance.
Apr 06, 2010 | EuroTech EWF150 Front Load Washer
WHY WOULD RAIN LEAK IN NEAR FRONT DOOR? ALL SEALS
Some leaks actually are from the windshield and it is contained by the trim so you can't see where it is leaking from. If it is the door seal look at the striker bolt to see if there is any abnormal wear. Make sure the striker bolt is aligned with the door striker. If you don't know how to check this run by your local body shop and ask them to check it for you. Sometimes if the keys have ever been locked in the vehicle people use door shims to hold the door open as to pick the lock. This is bad because it knocks the door out of alignment with the seals. Hope this helps.
Feb 06, 2010 | 2006 Jeep Liberty
I get lots of mould on the door seal - why? The machine also leaks when its empty or only half full
You won't notice the mold on other machines with black door seals because of the color. If your seal is gray, it is a normal thing. Chances are it really isn't mold, but a build up of crud. However in the off chance it is mold, spray the seal liberally with mildew remover, let sit and repeat until the mold is gone. . As for the leaking (assuming the leak is happening at the door), if it is a drip or two during the cycle, although it is not "normal" for this to happen, front loaders do often drip here and there. If you have more problems than a couple of drips, replace the seal. . Other leaks not at the door should be looked at. There aren't too many places it can really leak. It should be easy to find.
Nov 25, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Front loader washer leaks from bottom center of door osmetimes
Check inside the door on the bellows gasket to make sure the inlet area (normally at the 10 o'clock position) is properly positioned around the water inlet, sometimes these work themselves off the inlet nozzle and can casue a leak when the washer is filling up.
Also, carefully run your hand around the bellows gasket to see if you can find any small holes that cold be letting water leak out. You'll need a flashlight to make this easier. It is hardly ever the hinges that causes a leak since the hinges are mounted outside of the door seal gasket (bellows gasket) and aren't ever exposed to the water.
Jul 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Feb 16, 2009 | LG WM2277H Stainless Steel Front Load...
Leaking water from front of door
I replaced the seal part # 154576501. The notch is on the right facing the dishwasher. Just pull it out and insert the new one.
I've fought this problem for over a year, thinking it was an adjustment. I am now running it through the third cycle and I am positive it fixed my leak. Also, while you have the cover off, check and trim the tie-wrap around the wire loom. Mine was interfereing with the seal, but the seal was also slightly distorted allowing the splash to come underneath.
BnoGno
Nov 16, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Duet 6hw9150p leaks when i put a full load
Is the door seal dirty?
A dirty door seal can cause a leak. Remove and clean any dirt or deposits around the inner door seal with a damp cloth. The door glass seals against the rubber seal; dirt or deposits can prevent a proper seal and cause leaks.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine leaks
GE Profile stackable washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 29, 2008 | GE Profile WPXH214F
Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Washer Leaking
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process of how to fit and replace
Sep 30, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
KitchenAid KUDC10IXSS Builtin Dishwasher Logo
19 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
