Question about Dayton Heating & Cooling
Manual for dayton whole house fan - Dayton Heating & Cooling
3 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: capacitor
Here is a link to a distributor with fan specs : http://www.grainger.com/Grainger/wwg/productIndex.shtml?search_type=keyword&QueryString=3C325B&operator=refineSearchResults&originalValue=Dayton+Fans&searchIndexId=1&typeOf=
I do not know which specific motor is used on that fan ( that fan has been discontinued) however you can check out this link http://www.emotorpro.com/index.asp?PageAction=VIEWCATS&Category=280
and have a representative that sells Dayton products answer your question... Hope this helps you...
Posted on Sep 10, 2008
  • 34789 Answers
SOURCE: Whole house fan timer switch
I agree with your assessment of the operation
Posted on Jul 07, 2013
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Jul 07, 2013 | Hardware & Accessories
Dayton_furnace I have a dayton furnace the blow and burners kick on and run fine, brings the house up to the right temp the burnes shurt down but the fan moter never stops blowing. what is wrong ?
Hello, if you are referring to,the blower motor then most likely the relay on tne integrated contol board is malfunctioning. Unfortunatly the whole board must be replaced in this case.
Nov 09, 2011 | Dayton Heating & Cooling
I have a Dayton 36'' chicken house fan with 115/230 there I found 6 wires, orange &black wire nutted together . white,yellow hooked to electic(White wire from electic). purple hooked to (black...
GRAINGER.COM THEY HAVE A TECH LINE, BUT ON THE MOTOR LABEL IT SHOULD HAVE THE WIRING DIAGRAM .. GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
May 27, 2010 | Dayton Permanent Split Capacitor Motor Fan
I just bought a new motor and installed it but now
Centrifugal force.....If you replaced the motor only and not the blades, the blades are likely out of balance or possibly bent. Check for wobble and to see that the shaft is fitting tight inside the blade collar.If there is a bushing on the fan blade or shf itself, check it for play as well
Sep 13, 2009 | Dayton (2C373) Fan
DAYTON 210,000 BTU OIL-FIRED HEATER WON T LIT UP
You write "FUEL SPRAYING AND FAN WAS WORKING"
If the fan was working, but the fan is not working now after replacing the whole kit, then something was installed incorrectly during the installation, possibly the rotor gap or rotor thickness is not correct or vane/vanes installed 90 degrees off.
Dec 08, 2008 | Dayton E50 Heater
Capacitor
Sep 09, 2008 | Dayton Permanent Split Capacitor Motor Fan
Dayton Attic fan running backwards
First see if the switch has a reverse position. Sometimes you turn the fan assembly in the frame, sometimes you turn the whole frame around. Take the cover off the wiring compartment to see if there are instructions there. Also check on the name plate on the motor, there may be instructions there. Attic fans are usually engineered to blow out.
Aug 02, 2008 | Dayton (2C373) Fan
Heating & Cooling Logo
16 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
