Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissel steamer I took the base of the steamer apart and had trouble putting back together. The switch assembly the adjusts the flow of soap came apart. I dont know how to line up the the black valve to the switch. jeremyhannan@yahoo.com
  • 350 Answers
You can do this Jeremy just be take your time be patient and keep trying!
Posted on Jan 24, 2009
Can you fuse the belt back together on a bissel shamppoer power steamer
Jolene,
I have done some fusing of belts in the past and did not have real good success in doing so. I would recommend finding a replacement belt and put it on.
Nov 10, 2014 | Vacuums
How do i put the lid back together on a moulinex serie f30 after taking it apart for cleaning
One shouldn't take things apart if one cannot re-assemble them :D
Take it to your local vac shop.
Oct 29, 2014 | Vacuums
Dc 42 not sucking
Dyson Upright Animal Model DC 42 lost power head rotation. Took apart floor plate and also switch assembly. The switch assembly has two springs of which one fell out before we could determine how to put together. Does any one have an image of the spring locations in the switch assembly?
Jan 23, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Water line routing
The biggest prob with Bissel is not pumping soap. Becuase if you don't run hot water through this tank the soap will dry and clog after cleaning and storing. Before taking it apart try running hot water through the solution tank and help break up the residue, best of luck. Steve
Jun 06, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Reset button or Fuse on my Infinity?
Ok, I took it apart, cleared the clog out, and put it back together. It wouldn't switch to "carpet". Got no answer on my question. Took it apart again, only I went further. Took apart the bottom - brush out, all inside bottom parts out, cleaned all that part of vac. No clogs down there. Ran the carpet/bare floor switch back and forth several times while I had it apart. Put it all back together and it worked fine. Still didn't find a fuse or reset button...
Jan 09, 2010 | Vacuums
Bissel proheat is not sucking up water
There is a oblong black seal that sits where the tank lip and the clear noozle window come together, is it there. Also make sure the filter in the tank lid is clean.
Jul 09, 2008 | Bissell 1699 ProHeat Clear View Upright...
Doesn't emit water in either tools or floor mode.
The mixer valve is most likely gummed up with old soap and stuck you will need to take the bottom of the machine apart to get at it. The problem with that is while it is easy to get apart it can be very difficult to get back together properly even for someone that does the job all the time. The only trick I can give you is to put a phone book under the base of the unit this will keep the wheels up and the base level to aid in reassembly. If you do get it apart remove the mixer valve which is directly under the grey mixer knob and rinse it in your sink very well. In the future take the time to empty the unused soap back into the bottle and fill the solution tank with water and rinse out the system before putting it away. For any parts or cleaning solution visit www.stevessewandvac.com
Jun 26, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
HOOVER STEAM CLEANER PROBLEM
The soap dispenser is supposed to be attched to the water tank. That grey piece, if it is round with 2 small ears on it is the metering plate, it controls the flow of water. It sits on the table that the tank sits on, insert it into the hole and turn to lock it in place.
Jan 14, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
110 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
