Complete failure after modifying RAM
When I attempt to start up my computer, I see nothing on the screen. This includes the POST or operating system loading screen. The backlight doesn't switch on either.
I have tried to press F2 shortly after turning the computer on to see whether it is simply a display problem, but I do not hear the beep from the speakers associated with entering the BIOS.
However, when I insert a disc, I can hear it spinning in the drive and the computer attempting to read it. I am certain power is getting to the computer.
When the problem arose, I was upgrading the original 2GB RAM to 4 GB using two Kingston 2 GB DDR2 SODIMM modules. After I installed the new modules, the computer failed to start Windows (I did see the POST in this case, it simply frose on the OS loading screen). After several attempts at starting in safe mode (the computer restarted after loading the files), using startup repair (the same) and the memory diagnostics tool (simply frose at 0%), I removed the replacement RAM and replaced the original modules. The computer again functioned correctly.
I then attempted to insert one of the new modules with one of the original modules. This was successful, and my computer (BIOS and Windows) reported having 3GB of RAM installed. I ran several resource-intensive applications which varified that the extra gigabyte was actually being used.
The problem I described above arose when I next attempted to start my computer. The computer is an Acer Aspire 2920Z dual-booting Windows Vista SP1 and the Windows 7 beta, both 32-bit editions. When I talk about Windows above, I mean Vista. Whilst swapping the memory modules, I followed instructions on Kingston's website to the letter.
I'd really appreciate any assistance.
  • 32 Answers
If you know how to remove the cmos battery, I would suggest that you do so. Leave it out for 20 secs. Restore the battery (if possible use a battery tester to verify the charge in the battery). Restart the computer and press whatever key (delete, F2, Esc) to get into your setup to see what the system setup is reading. If you know how to change the settings for your changes then proceed.
Posted on Jan 21, 2009
Could a dead bios battery result in a blank black screen?
The EEPROM is not the copy of the BIOS used to boot the OS or effect settings. The EEPROM defaults get copied into CMOS memory (hence why it is called the CMOS battery). So if the CMOS battery is dead then there is nothing to energize the CMOS chip to retain its values. That means on every boot you will get the defaults loaded from EEPROM. It will not cause black screen.
you do not give much info, does machine come on and runs but screen is black, or computer dose not start at all, more detail would help, press the helpful button and RE POST with more info
Jan 31, 2016 | Computers & Internet
Tip
How to isolate issues between hardware and software
<p>It has been one of the dilemma of computer users is to identify what is really causing the failure in their computer. Often they think that they bought a defective product since they are getting these kind of errors in the computer. Having an error on your machine does not mean that the machine is defective or needs parts replacement. for all we know it might just need some simple troubleshooting steps to fix the issue. Here is a tip where you would be able to know if you need to bring your computer to a service shop for parts replacement or you can try to fix it at home by doing some troubleshooting steps that would help fix software failure in the computer system.<br /> <br /> On a Windows based operating system, you should always know when the issue happens. It will help much to observe your computer on how it boots up and what it does before you get to the desktop screen. Take a note on where and when exactly the error occurs.<br /> <br /><b> Power Failure:</b><br /> <br /> This is an issue where there are no lights on the power button of your computer, whether it is a portable system or a desktop computer. Obviously this is a hardware failure. surprisingly, discharging the flea power of your computer sometimes resolves these kinds of issues. Otherwise, you will definitely need to have a local technician look at your system for parts replacement.<br /> <br /><b> Note:</b> flea power is the charged power of our computer system. A computer system is made up of electronic components such as capacitors which hold electronic charges. To be able to discharge it, you should disconnect all power source from your computer and hold the power button for at least 5 seconds.<br /> <br /> <br /><b> POST Failure:</b><br /> <br /> POST is an abbreviation for Power On Self Test. as the name implies, it is the test that a system goes through to test the basic hardware components needed for a computer to boot. The components that it tests are as follows: Processor, BIOS (Motherboard), Memory, keyboard and video card. If there is a POST failure, the system would give you a black screen with lights on the front panel. Sometimes it will give you beeping sounds which would normally mean that you have a memory failure on your system. If you encounter such issue, you will need hardware technical support to guide you isolate further on what could be causing the failure.<br /> <br /><b> Boot Failure:</b><br /> <br /> Boot failure is when the computer is able to complete post. You will be able to know this if you hear a single beep on your computer. Isolating a boot failure from a post failure simply requires you to boot to the System Setup/configuration Screen (BIOS). If you are able to get to the BIOS, that means all the POST hardware component are good to go. However, booting to the BIOS differs per system. You just need to do trial and error on the following keys to tap as you turn your computer on.<br /> <br /> Del<br /> F1<br /> F2<br /> F10<br /> F9<br /> ESC<br /> <br /> To isolate an issue whether it is a software or a hardware issue, you just need to boot from the BIOS. If you are able to boot from the BIOS, chances are it is not a hardware failure and needs servicing.<br /> <br /> <p><img src="vincent_von_0.jpg" /><br /> <p><br /> If booting to the BIOS works, to further isolate the issue whether it is the advanced software, you need to boot to Safe mode. Safe mode is a troubleshooting state where only the basic applications and drivers are active. If you are having errors or boot failure, try to boot to Safe Mode. If you do not encounter the failure in Safe Mode, that means that there are advanced software being loaded in your operating system that fails. It is just a matter of knowing what that software is.<br /> <br /><b> Booting to Safe Mode:</b><br /> <br /> 1. turn computer on and tap on F8 before Windows starts.<br /> 2. You will be getting the Advanced Boot options. Use the arrow keys to get to the option for Safe Mode.<br /> <br /> <p><img src="vincent_von_0.png" /><br /> <p><br /> <p><br /><b> Safe Mode Definitions:</b><br /> <br /> Safe Mode: Just basic software are being loaded. Network drivers are not included which means no internet connection<br /> <br /> Safe Mode with Networking: Basic software and Network drivers are being loaded.<br /> <br /> note: for Vista or Windows 7, it includes wireless network drivers. This means that you can still connect to the internet with a wireless connection. In Windows XP, the wireless driver is not included even if you boot to Safe Mode with Networking<br /> <br /> Safe Mode with Command prompt: this is a troubleshooting state where you will be able to utilize DOS based commands.
on Jul 15, 2011 | Computers & Internet
During boot up the post screen shows,'Bios update data incorrect' CPUIDE 0000068A. My system is working, but sometimes it hangs/ freeze.
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive or
click startcontrol panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive)))
then click start all programs accessories system tools defragment your hard drive
you might have to install more RAM random access memory to check how much ram you have click start right click on my computer select properties you will see all imformation about your computer including installed ram
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
hope this helps
don
Mar 03, 2011 | ASUS CUWE-RM (CUWERMSWA) Motherboard
Laptop powers on fine , I can go into and change BIOS settings and everything is fine.. After the COMPAQ post screen the laptop wont boot from any media what so ever. It just displays a blank black...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 13, 2011 | Computers & Internet
My acer laptop keeps rebooting giving me a blue error screen. Don't have disk that came with it what can i do?
If you receive the Blue Screen, that means the Laptop is having a trouble with
  • Operating System/ Sub System failure
  • Software Device/Application Failure
  • RAM
  • Hard Drive
You have to include the BSOD message. Please do it next time so that I can give a more appropriate answer.
If the blue screen doesn't remain, here is what you have to do to Disable the Automatic Restarting.
  • When the system boots you have to go to the Operating System Menu.
  • Most PCs and LAPs has the Default key "F8" or "F11". Check the keys and hit until you are directed to an Operating System Choice menu.
  • Select "Disable Automatic Restart on a System Failure" and Hit Enter.
Include the BSOD message in the Next Comment
Jun 13, 2010 | Acer Aspire 5610-4648 Notebook
Toshiba p25 laptop, comes up blue screen.Can't get into safe mode, can't change bios settings, can't get prompt. Unit keeps rebooting. I put it in a desktop and copied win7 onto it, but haven't been able...
Blue Screens are usually caused by three factors, the first and easiest to detect is a faulty ram, the second and a little more complex failure surface is hard and the third and most complex operating system failures , in the latter you must use the restore disk that came with your computer and reinstall the operating system, only to lose all data on the hdd
May 24, 2010 | Toshiba Computers & Internet
Loud buzzin sound on start up
If the POST screen is coming up, showing the the correct amount of memory in the system, and then telling your hard disk failure or something similar, your hard drive has failed. Put a new hard drive in the system, reload your operating system and all drivers, and attempt to use the old hard drive as a second drive long enough to get any files you need from it.
Dec 31, 2008 | Azza Xion II Series Gaming Computer Case...
Black screen
Plz Check and change or Replace
1)RAM
2)Monitor's VGA cable
3)Any other Cards such as (Graphic,Modem etc)
Because some time Ram's cant work and system still black screen when start the system.
If RAM is Good working plz check monitor's cable
the 3rd option is replace/remove the Cards some times any hardware device failure complete computer system is Down
If Problem is still there
Go to Computer sales and Service Center
DON'T APPLY OTHER EXPERTISE!
Dec 12, 2008 | Computers & Internet
1 minute delay between windows xp splash screen and log on screen
try to to remove staru up programs that are not necessary...and modify the enableprefetcher in registry to value 1
Dec 08, 2008 | Computers & Internet
Thinkpad T40 operating system failure/won't boot
Check your RAM, reseat them, if you have RAM in both slots, swap them around. If possibe test them in another computer.
Nov 29, 2008 | IBM ThinkPad T40 2373 Notebook
Computers & Internet Logo
263 people viewed this question
David Payne
David Payne
