Question about Prestige Medical Infrared Ear Thermometer
What does POS mean on digital thermometer - Prestige Medical Infrared Ear Thermometer
The Thermo temp flashes HHH ....and the thermometer keeps beeping...??? What do I do!?
That means the temp is higher than the unit is able to detect. If it has been exposed to very high heat then it is damaged. It may still have a bad sensor.
Jun 19, 2016 | Taylor Digital Cooking Thermometer
What does Lo mean on a digital thermometer?
The sensor is sensing a temperature that is lower than the lowest possible temperature that can be displayed on the thermometer. If it is actually warm then the sensor has failed
Mar 02, 2015 | Lumiscope L2013 Jumbo Display Digital...
Beechams forehead thermometer instructions
Why not check out a non-contact digital thermometer? I think that would be easy for you to measure someone's temperature.
Catherine J. Davis
Non Contact Digital Thermometer
Aug 28, 2014 | Home
Symbol on my Pentax K-7
If you mean the thermometer, the camera's internal temperature has gotten too high. See page 156 of the manual: http://c758710.r10.cf2.rackcdn.com/files/support/manual/426_1314745050-265503871_manual.pdf
May 10, 2013 | Pentax K7 Digital Camera
What kind of battery uses Hartmann Maximum thermometer 1804?
It has been my experience with the digital thermometer batteries usually hold button cells for years, but to renew it when it unloads itself is usually more expensive than a new thermometer.
Jan 08, 2013 | Health & Beauty
How to calibrate Ryobi digital thermometer?
Wrong. You need black body to check accuracy of IR thermometers (unlikely that you will have one). Accuracy bellow 50F is +/-3F and other ranges is +/- 1.5% of the reading.
Read the manual: http://www.ryobitools.com/product_manual/file_url/478/RP4030_656_trilingual.pdf
Jan 04, 2013 | Ryobi Tek4 Professional 4-Volt Infrared...
The digital thermometer was flashing "lo". I assumed it needed new batteries and then replaced them. It is still flashing lo, but also showing a C reading. What do I need to do to reset it?
there should be a setting on it that changes the temp from Celsius or "c" to ferinheight and lo means that it currently isn't reading a temperature in the normal range. try running it under hot water and see if it says error or high.
Jul 15, 2011 | Prestige Medical Infrared Ear Thermometer
I have a Braun thermoscan type 6022, but code po5 always comes up. What does that mean?
It's not po5, its pos... you're not positioning it properly in the ear canal.
Jan 26, 2011 | Braun Health & Beauty
Prestige Medical Infrared Ear Thermometer Logo
186 people viewed this question
Top Prestige Home Experts
john h
Tom Chichester
Are you a Prestige Home Expert? Answer questions, earn points and help others
