Question about Teac CD-P1260 CD Player
TEAC CD-P1260 Brand-new, out of the box. Placed multiple factory and home finalized CDs (label side up). Get "Reading" for an inordinate amount of time -- then "No Disc." What's up with that?
Identical problem with my 4-month old player. I mailed the unit to the repair shop noted on their web page (Montebello, CA). They "re-soldered a loose connection" and made a "mechanical adjustment". I got the player back in two days. It now works fine (again). Under warrenty; no charge.
Posted on Sep 02, 2007
SOURCE:
My teac recorder model # cd-rw890 keeps flashing "reading" and will not let me operate the cd drive
How long have you had you CD recorder?
How many CDs have you burned on it?
The reason for asking is, it sounds like the laser has
failed or is failing to the point of not recognizing the
presence of a disc in the tray. Does it do this with any
disc you put in the tray. Blanks & pre recorded CDs?
A minimum amount of light must bounce back from the
surface of the disc or the unit thinks the tray is empty.
If the laser has become very weak (or died) the player
doen't know any better and thinks "no disc".
The "reading" message just indicates it hasn't passed
the stage where it has detected a disc, yet.
The first step is to run a laser cleaning disc in the player
on the off-chance the lens is dusty and that's the problem.
If you don't have one (you should) they're cheap enough
and available everywhere. If cleaning doesn't help, you
will be looking for a new laser assembly for your unit.
Be careful how much you pay for one. New 890s can be
had from Full Compass for under $200.00 and would be
a smarter move than repairing a tired one!
Oct 23, 2014 | Teac America, Inc Teac CD RW890 - CD...
Cd player stops spinning about 30 seconds after it starts. I opened the case and watched. It starts playing ok and then slows down and eventually stops.
Is it belt driven? My guess is that the belt needs to be replaced. If it's direct drive, it's probably the motor itself. Make sure you try some different CDs. Sometimes when there are scratches or smudges, the laser can't read the disk and it will stop. You may want to try a laser cleaning disk too. They are cheap and I have saved several computer drives by using one.
Dec 04, 2009 | Teac CD-P1260 CD Player
Tevion dd1018 remote code
Often times(more often than we'd wish) your brand of television, vcr etc. is not on the list. They all offer a code search sequence which is gruleing to say the least. Some times you may contact the company and they will give you the right code.Thanks, Dana
Aug 21, 2009 | Teac CD-P1260 CD Player
Error code
If it is a burnt cd then your cd player is having problems reading it. Probably didnt finalize good if burnt or its a cheap brand of cd. I always get an error with memorex cds
Jul 08, 2009 | Volvo 940 Cars & Trucks
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
TEAC H300CD Player
Hi, Your particular brand/model was made in the very early 2000. It is possible that the eye (optical lens) is already weak and would need replacement or calibration. You may want to try and clean the lens hopefully improving the reading capability. Some users of CD players use a PC CD cleaner to clean the eye (pls read the instructions) though this can be done by going inside the unit). Probably your best bet is to seek the services of a qualified professional. Hope this be of some help and give you ideas. Pls post again how things turn up and/or if you need further information. Good luck and kind regards.
Aug 04, 2007 | Teac PD-H300 CD Player
Teac CD-P1260 CD Player Logo
334 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
