LG GSA-E10L (8801031212552) DVD±RW Dual Layer Burner Logo
Anonymous Posted on Jan 21, 2009
My gsa E10L DVD STOPPED WORKING computer does not regonize it
I use the e10L 6 driver
  • Anonymous Apr 11, 2009
    my computer does not regonize to me LG GSA-E10L
  • Anonymous May 01, 2009
    my lg drivers does't work
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jan 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
851
Points
HOW DO I DOWN LOAD DRIVERS FOR A LIGHT SCRIBE DVD WRITE ABLE /CD RW DRIVE. MODEL # GSA-H3OL
Hi...
If your LG LightScribe drive will not need drivers to work as a 'normal' DVD drive as this function is Plug n' Play.
BTW - You have a great drive there... I have GSA E10L and a GSA E40L - Both fantastic drives...
However to use LightScribe you will need both:
1: LightScribe System Software
and
2: LightScribe Labeling Software.
You can download the System Software here:
http://lightscribesoftware.org/lightscribesystemsoftware/
And FREE LightScribe Labelng Software here:
http://lightscribesoftware.org/freesoftware/windows/
Happy Scribing...
Steve
External DVD Model GSA-E10L Can't read DVD-RAM disc. it's need update driver or not? now,LG GSA-E10L Firmware LE07.
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
check the leads that attach to this external dvd you might have to physically unplug the leads for this dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
1helpful
Usb not reconised the dvd rrecordert lg GSA-E10L
download latest driver u can google for the latest driver
No Lightscribe
This could be a driver issues or is it software .
Remove device and software first reboot then reinstall
if you have the disk then reinstall should be straight forward.
Try plugging in the device ,
and use the device manager for the drivers update install.
(while in device manager-select device rightclick and update)
This should fix your issue,
If problem persists,
refer the problem to the retailer you purchased from,
should be still under wanrantee if its a new one,
there supplier should honor the warantee no problems....
You may need to provide proof of purchase for warantee.
Will not burn
try to clean the lense with a special brush cd.ussualy this works
bye
LG GSA-E10L DVD±RW Dual Layer
Try reseating your IDE cables. or Assuming you have powered down and restarted and then click start button\control panel\system\hardware tab\device manager and see if there are any yellow/red flags that might give you some information.
If all else fails go to the cd drive in device manager and uninstall the driver and follow directions, choose automatic install when it gets there. Then do the same with the cd/dvd and see if things work.
Windows vista compatible
TRY THE MANUFACTURES WEB SITE..
WINDOWS USUALLY SHIPS WITH DEFAULT DRIVERS THAT SHOULD WORK FOR MOST DEVICES (MEDIA)
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
