Question about Goodman GMS90703BXA Heater
I am trying to instal the unit my self
I was just wondering what I would need to instal a Goodman 13 seer split heat pump in my home I am taking out an old unit and in stalling a new one
  • 61 Answers
You will need a refrigerant recovery machine, and an EPA certification to recover refrigerant. You will need an oxy-acetylene brazing set-up as well as a nitrogen tank and regulator set-up. You will need a set of refrigerant guages (make sure to get guages for the r-22 you will be removing and another set for the new r-410a going into the heat pump), a digital micron guage and a vacuum pump.
You may want a digital multimeter and control and power wiring supplies. You will probably need additional refrigerant also.
It may not be a good DIY project.
Posted on Jan 22, 2009
Amana heat pump 13 seer split system when in heat pump mode once the thermostat is satisfied the head pressure on the high side shoots up to 600
410 a runs at a much higher pressure then r-22. that is still very high. it would take a temperture over 150 degrees to produce it on a idle system.
Feb 15, 2015 | Amana 3.5 ton 13 Seer Split Heat Pump...
What is the problem with running a 10 SEER condenser with a 13 SEER air handler other than efficiency? I had a 2 ton 13 SEER air handler installed last August to replace one about 27 years old. The...
as most ac units are capillary tube control not tx valve having matched units is critical. as for cost the condensing unit is much more complex and expensive than the evaporator.
Feb 14, 2015 | Amana Goodman R-410A Heat Pump Condenser 2...
3 ton heat pump with piston in air handler. After unit shuts down it makes loud fluid flow noise for about 2 minutes
adding a tvx will not help. the sound you here is the pressure equalizing and that has got to happen for the compressor to start again the next time. A tvx will give you a higher efficiency because it can adjust to changing temperature conditions. Only way i know to quiet the noise is to try to insulate the lines better.
Sep 14, 2014 | Goodman GSH130301 Heat Pump, 3 Ton, 13...
Difference in seer
i would check fan speed. it's probably on high. you might be moving more air with new system. a dirty evaporater on old unit woud have gave you a larger temperture drop.
Jun 16, 2014 | Goodman Heating & Cooling
I would like to know how to replace the heat strips in an Amana GPH1330M41 unit
Buy a heat kit from a Goodman dealer. Check that your existing wire will carry the amp load.
Jan 17, 2014 | Goodman Manufacturing Goodman GPH1330M41...
Draining leak
Check for plugged drain and/or broken plumbing parts.
Dec 10, 2013 | Goodman Manufacturing Goodman GSZ130361...
How to wire high voltage goodman straight a/c package gpc1324 unit with 8kw heat kit
do any one have a old package unit is a goodman i want to see were heater on that package uint or take picture of that unit so i can see where the wire go at the heat
Aug 17, 2012 | Goodman Heating & Cooling
How do you read the model # please decode VSH130421AA
V- GMC product Family
S- Split System
H- Heat Pump
13- 13 seer
042- 3.5 Ton
1- 208/230 V, 1 Phase 60 Hz
SP1, Hope this helps,
Jacob
Nov 04, 2010 | Goodman CLQ36AR49 Air Conditioner
Goodman GMS90703BXA Heater Logo
90 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
