Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave GE spacemaker does everthing but heat up.
How do i check the fuse?
    Novelist:
  • 140 Answers
I am assuming that when you say everything works, that tells me that your control panel comes on and when you press the start button to heat something up the light comes on inside the microwave and the table turns and that it just does not heat. There is only one fuse inside the microwave and it is rated at 15amps. I can tell you now that it is not your fuse but your magnetron that is bad. However, you can unplug everything and take the cover off and you will see the ceramic fuse. To check it you need a continuity tester like an ohmmeter. As I said though since it is the only fuse and everything comes on it is not the fuse. The magnetron needs to be replaced then it will heat up fine and the table will turn. Replacing the magnetron can be done if you are a do it yourselfer. Once you unplug the microwave and take the cover off. The magnetron sits right behind but on top of where your control panel is. It is only held in place with three or four screws and has only three to four wires that unplug at a couple of places. Be sure to note which wires go where. Find a magnetron at either a local tv repair shop since they may have a used one that works that will fit in your microwave, or go to a local electronics supply house or get on the internet and find one there. Good luck and God bless. Let me know if there is anything I can do to help you.
Posted on Jan 22, 2009
Everthing works but won't heat
If turntable works suspect inverter (power) or Magnetron itself is bad.
Oct 29, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
My GE microwave Model #JE1860BH 03 will not heat. It started to arc for a few times then quit heating. Everthing else works. Can you help?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Rudy0819: My GE Microwave Spacemaker model JVM1440WH01 just stopped heating. I used it earlier and it worked fine. When I went to use it again, it won't heat. Everthing else works, the light, fan, etc,...
The most likely thing is the magnetron has 'died' but there is a high voltage fuse between the capacitor and the magnetron which may blow. Either way, repairs to microwaves are dangerous and should only be undertaken by a qualified repairer. PS I have seen a mouse cause this problem!
Sep 22, 2009 | GE JE1640 Microwave Oven
Microwave GE XL 1800 Spacemaker Not Heating
have you check the fuses, maybe its open, orthe hv diode.
Sep 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave has no heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
ytewyteyu
Aug 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1800 runs but doesn't heat.
I think you should check the fuse first that runs the magnatron if the fuse is good that means the magnatron is bad! but if its only the fuse then you save time and money!
Jan 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave turns on but does not heat
if your microwave does not heat up when turned on its maybe the coil is burnt out are fuse broken, so check your dealers
Jan 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker runs but wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jan 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
73 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
