Question about Refrigerators
Lg model grl207tuga
How to reset filter light on display
LG filter light stays on
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. Air Conditioning Boca Raton
Jun 12, 2016 | LG Heating & Cooling
The check filter light keeps blinking and it displays CL in the display area. I always clean the filter after every load and I swept any remaining lint from the vent but it won't reset.
the filter light is just a reminder. it is not connected to a sensor or anything. it is not the issue. the 'CL' code is the issue. CL means that the Child Lock is on. press and hold the child lock button for 3-5 seconds to turn off the child lock.
Aug 22, 2015 | LG SteamDryer Series DLEX4070V 27...
Cannot reset the filter light
Hi David, this is AP.
I understand you are having trouble resetting the water filter light on your Frigidaire refrigerator. On this model, FGUB2642L, I would start by pressing and holding the water filter button located at the top of the display panel for 3 seconds if you have not already. If that option does not work I would recommend using the default settings button. Hold down on the button to reset all refrigerator settings. If that still does not rest the light I would suggest cutting power to the refrigerator for a few minutes to reset the display. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect if you have additional information regarding your question.
Thanks,
Mar 21, 2014 | Frigidaire FGUB2642L
Water filter light
Instructions on how to reset the water filter status light on page 14 of your GZ25FSRXYY User Manual
Reset Water Filter Status
After changing the water filter, reset the status light. Press the OPTIONS button to enter Options mode, then press LOCK to initiate the reset, then press MEASURED FILL to confirm that you want to reset the status light. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the display screen.
If the above is not your model number then click HERE to enter the correct model number Questions please let me know, Thanks Sea Breeze
Mar 01, 2013 | Whirlpool GZ25FSRXYY
How do i reset filter display on filter replacement for a new 6 months
depends on the model but if you still have your manual it will tell you. Generally it is reset by holding one of the dispenser option buttons down for 5 seconds or by opening the refrigerator door and quickly hitting the light switch 5 times in 5 seconds.
Nov 16, 2012 | LG Refrigerators
Have changed water filter, but indicatot panel calls for order h2o filter, and comes on every time we dispence water. why?
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
Oct 16, 2012 | KitchenAid KBFA25ER Bottom Freezer French...
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
I purchased a new filter (Model LT600) Part #(5231JA2006B) for my LG refrigerator I installed the new filter and I am unable to set the filter/month button. After installing the new filter the number (1)...
Usually you just need to hold in a reset buttom (or a button near the dispensor for over 5 seconds to reset. The owners manual will tell you (I do not have one). or- Try any buttons you can find.
Apr 21, 2008 | Refrigerators
Filter status, display help
This is normal. The light is on only when it's time to change the filter. I guess you have already found the filter timer reset procedure in your owner's manual!
Enjoy your new fridge!
Mar 12, 2008 | Refrigerators
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
