I have an Epsom i/c PS 54350 power unit needs replacing, can you help?
What can I check to determine if my TV's Power Supply is bad?
Iv the voltages are low, pull the power line from each of the other boards to see which one is dragging the voltages down. If none ovf the voltages return to the correct value, then the power supply board is gone. You can get all the repair parts you need from here:
http://www.shopjimmy.com/
Feb 19, 2015 | Televison & Video
Aqua logic aql-ps-8 no power
The description indicates the unit has eight relays. There could have been a relay failure that caused the loss of power.
Dec 02, 2013 | Hayward Industrial Products Hayward...
No power supply power out, ps fan not coming on, fuse is good
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
Dec 30, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
94 suburban PS leak
The brake booster is replaceable a remanned unit cost around 225 dollars and does not include the master cylinder...
Apr 03, 2010 | 1994 Chevrolet Suburban
E Machine ATX 250 -12E replacement PS
With emachine MOBO's you have to make sure you plug in the 20 pin plug from the power supply to the mobo. Also make sure all hard drives, cd/dvd roms, floppy drives, etc are turned on. Make sure the red switch on the PS is set to 115. Make sure the PS is plugged into a known working outlet. Make sure MOBO is properly in place with all grounds/screws in place and nothing metal near or touching board which may short it out.
You can review the E Machines PS replacement guide here for further instruction.
Good Luck,
Jesse
Jan 11, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
Won't turn on - PS light on but no PS fan
Surely sounds like the power supply is in need or replacement, or fuse replacement at absolute least.  the fuse that you will be in search of will be located inside of the power supply unit.  Use caution when working inside the power supply.  If you don't see a fuse in the power supply, OR you come to find that the fuse is not damagaed then you will likely need to replace the power supply.
Regards,
Joe
May 07, 2009 | Computers & Internet
Problem with Sansui LCT37SD power supply unit
Diagram of SANSUI LCT37SD.
Power supply default.
Apr 22, 2009 | Televison & Video
Power Supply Bestec ATX-250-12E Rev.P6
Normally if you open the PSU up warranty will be void. ( if it's Under Warranty). if not once you open the unit the fuse's are located right nest to the power input.
Jan 01, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
No picture, VSCAN issus.
If you hear a kind of hissing sound then is a faulty ballast
Jul 18, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
15 people viewed this question
jasbo
jasbo
