Question about Electrolux Over-the-Range Microwave
I need a frigidaire micriwave door handle - model # FFMV162LSA - serial # KGO3900650
How can I remove door?
Hello friend, thank you for your inquiry!
From my understanding you need assistance removing the door from your Frigidaire microwave. In order to assist you further I would need to have your model number. You can locate the serial tag (which lists your model number) on the inside left had wall. Once I have that information I would be able to look into any available information for you. -Matt
Feb 05, 2016 | Frigidaire Microwave Ovens
How do I tighten the door handle on a Frigidaire over the range microwave oven?
You need to remove the inside part of door to gain access to mounting screws.
Nov 19, 2015 | Frigidaire Microwave Ovens
My child lock on my Frigidaire is constantly beeping... The door is not locked but it is beeping...
Hello Shelley, thank you for your inquiry!
I understand your Frigidaire is constantly beeping while they door is unlock, however do you have a range or microwave Frigidaire appliance? The serial tag for a range, which lists your model number, is typically located in the storage drawer, on the right side and the serial tag for a microwave is in the lower left corner as you open the door. With this information I can better address the issue at hand. Thank you!
Oct 22, 2013 | Frigidaire Over-the-Range Microwave
I need to remove the door to a Frigidaire Microwave so I can replace the handle. How do I do this?
Normally you have to separate the door panels and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Aug 04, 2012 | Frigidaire Microwave Ovens
Handle on Frigidaire Microwave broken, probably because of heat from gas burner below - this is a defect becaquse the microwave oven was manufactured to be built-in above range. Frigidaire has finally...
im kinda confussed as to why Frig would do that,,,
but if you send the model number im sure we can help
most times repacing the door is really just a matter of lifting it off the pin hinges after you have removed the vent
but i can be more clear with the exact model
Oct 28, 2009 | Electrolux Microwave Ovens
Broken door handle, have part but can't put it on.
Thats disgusting mate! The doors are either clip together, plastics or if stainless as per photo, it would require opening the case, removal of door then prising off the fascia trim to get to the handles.
I'd ring them back up, that is not a user servicable part as it will bugger the finish trying to separate the doort.
Best of luck
Dec 10, 2008 | Frigidaire FMV157GM Microwave Oven
Need to remove door to replace handle screws
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 29, 2008 | Frigidaire PLMV169DC Microwave Oven
Broken door handle on GE microwave oven
hi stormy
door handles are usually model specific, but I think your serial # may be JVM140K02. look that up at a partstore web site and see if it matches
Mar 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave door handle
Feb 22, 2008 | Frigidaire FMV156DC Microwave Oven
PLMV169 Door Handle
You can find an exploded view for model PLM168 (it's probably very similar) here: http://tinyurl.com/gv383 It looks like you'd have to gently pry out the choke cover (see attached photo) then you'll see the screws. When you reinstall the door handle screws, add a bit of thread locker or nail polish to secure them.
Sep 20, 2007 | Frigidaire PLMV169DC Microwave Oven
Electrolux Over-the-Range Microwave Logo
238 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
