Question about GE (PSS26MSRSS) Side by Side Refrigerator
Cubes do not fall thru the dispemser door
When dispensing ice the cubes do not "open" the door. The door can be opened manually from in or outside the door. Should the weight od the cubes open the door? How does the dispenser come off of the door from the outside?
  • 1 more comment
  • jakek61 Jan 21, 2009
    Hey- just replaced the 7watt bulb that blew out several months ago and although the light does not work something "clicked" and now cubes come out. The light does not work but when in on position the cubes fall. Hurray
  • Anonymous Jan 21, 2009
    the water and ice is not coming out of the despenser on the outside fo door.
    Boo. Now it is back to not working. Maybe something as simple as a bad connection. So still need answer to the original question.
  • 410 Answers
Sounds like the dispenser door solenoid has either rusted up or failed altogether. rusted up solenoid plunger is very common on the ge sxs. you can access it by grasping the disp control and pulling up and out at the same time (it will be kind of hard to do but it will come off). once you have the control cover off you will see another peice held on with 4 philips head screws remove the screws and pull that part out then on the right hand side you'll see and black solenoid hooked to the door of your dispencer that's wht needs to be replaced. thanks peyton
Posted on Jan 22, 2009
  • peyton thompson
    peyton thompson Jan 22, 2009
    after reading your subsuquent comments i am thinking that instead of a bad solenoid you possibly have a bad mother board. all the power for the disp comes from the motherboard located on the rear of your refrig. the fact that it worked temporairly after replacing the bulb lends weight to this as well. good luck. peyton...
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool side by side GD27DQXFW01; ice cubes are not dispensing
We will need to check the voltage at the auger motor while depressing the dispense switch. If all the other features work on the dispenser panel while I would consider checking the voltage going to the motor. Some auger motors are in areas where water causes the voltage to be shorted by constant moisture. We will need to remove the panel and simulate what you have done on the outside but this time we need to see if the voltage has been altered or if the auger motor itself is defective. Sea Breeze
Oct 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
GE Freezer Side Ice Dispenser
It isn't supposed to free wheel and the only solution that I know of is tumbler replacement. I have the same issue and am currently hunting replacement parts.
Jun 16, 2008 | Refrigerators
Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker does not stop working and overfills, then ice dispenser does not work and pushes door open.
Continuous ice production, too much ice in the bucket, ice cubes overflowing the bucket, ice cubes falling behind the bucket or ice lifting the chiller shelf can now be resolved by installing a redesigned feeler arm. The new arm is designed with a slight curve to cycle the icemaker “OFF“ before the cubes overflow the ice bucket. Order part number WR49X10103.
Jan 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Pull out your ice bin. In the back of the bin you will see a rod protruding from one side. That rod goes into an opening in the rear of the freezer. There is a solenoid behind that opening that raises and lowers the arm on the ice bin giving you crushed or cubed ice. Check to see if that solenoid is froze up or if your rod got stuck under it. If all check ok then replace that solenoid.
Nov 05, 2007 | Frigidaire FRS26KF5C Side by Side...
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
Oct 23, 2007 | Hotpoint HSS25GFP Side by Side...
Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Jan 02, 2007 | Samsung RS2578BB Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
79 people viewed this question
Top Refrigerators Experts
KJ4QOB
Da Doc
jerry earick
