Hello i have changed my cracked screen on vpcea16fa and it is still black it displays fine on external tv and is not brightness settings and i thought the backlight was built into the screen can anybo
Black screen even with new screen
  • garyishere67
    garyishere67 Feb 02, 2013
    Just to let you know i have now bought and changed the screen twice and i can not see the screen unless i shine a torch onto it very strange as lighting is built into the screen I scratch my head and wonder if more money should be spent ! but thank you for all the advice
  • joecoolvette
    joecoolvette Feb 02, 2013
    Is there a screen Inverter? Nothing I brought up in my searches, manuals, etc, suggests a screen Inverter is used, However........A small circuit board, usually located at the base of the LCD screen, and behind the Display Bezel. No? Alright...........How about the Video Cable? Connections were tight I assume? Condition of Video Cable was OK? Passed a continuity test? Is there a separate cable leading to the top of the LCD screen? As in a separate power wire to the LED backlighting? Do you know for sure that the LCD screen's you purchased, are exact matches for your VAIO? Are both LCD screen's from the same place? (Yes. I'm sitting here bummed out that you have purchased TWO LCD screens, and the problem isn't cured) There is a such thing as two bad LCD screens. That is also referring to they both could have a problem with their LED backlighting. This is what I lean towards now; A) Video Cable may have a bad wire in it. Continuity test was not performed, or tech who performed it for you lied, and never tested it. B) Video Cable connections aren't tight. Have to physically check. Visual inspection alone will NOT do. C) Separate wire comes up, and plugs into LED backlighting, and neither one of us is aware of it. (Just a guess) Isn't plugged in.
  • Computers & ... Master
  • 5,660 Answers
A) The Backlight IS built into the LCD screen assembly.
It's a series of LED's. (Light Emitting Diode)
I assume there is no screen Inverter, because it is LED backlighting. Also because I cannot pull one up.
Therefore I conclude that the Video Cable is either not connected securely to the motherboard connector, or the LCD screen connector; or is damaged.
Or it is the wrong LCD screen.
Did you check the motherboard side connection?
PHYSICALLY? Visual will NOT do.
Sure the LCD screen side connection of Video Cable is tight?
Did you perform, or have performed; a continuity test on the Video Cable? Check it's tiny wires to make sure one isn't stretched/broken?
You can remove the Video Cable, take it to the nearest small computer shop, and have the resident tech perform a continuity test on it. Few bucks.
If the sheath of the Video Cable looks to be damaged, the wires inside may be also. However, DO NOT assume. Needs to be tested.
http://www.youtube.com/watch?v=LOyP1kSerRk
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jan 10, 2013
Testimonial: "Thank you i will try this today"
  • joecoolvette
    joecoolvette Jan 14, 2013
    You're welcome, and thank you for the rating! Would appreciate hearing the outcome. Please post in a Comment. Regards, joecoolvette
    Problem Solver:
  • 17 Answers
If you display on tv ...that is a special card doing the video for tv... you need to replace video card on pc or get an external usb video device and plug in external monitor... cheaper to replace pc totally
Benimur
  • 6966 Answers
SOURCE: Data Shows up only on External Monitor, not on Laptop Screen
Since the laptop works on the external monitor, then it would be safe to assume that it is only the L:CD display part that is the issue. Often LCD display (of laptops) are working but only that you can see the actual display. One way to verify is to shine a flashlight at an oblique angle to the screen, semblance or part of the desktop could be seen. If the desktop could be seen (albeit very very dark background) then it could either be the CCF Lamps (cold cathode florescent) or the inverter that powers the lamps.
Often, the defective component would be the inverter. It is relatively easy to replace the inverted. It is sometimes more difficult and challenging cracking open the casing of the display panel of the laptop than replacing the inverter. Additionally, inverters are readily available online. It is also not surprising that inverters for other brands/models would also be used in your Toshiba.
This would be a good place to start for inverter boards. This is a nice tutorial if you are considering a DIY.
In some worst case scenario, it could be the video interface or even a loose/open flat cable from the laptop's main body towards the LCD display panel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 08, 2008
  • 461 Answers
SOURCE: evo n610c black black screen please help
If an external monitor works, then the LCD has failed and needs replaced.
Posted on Jul 20, 2008
Solo4665
  • 53 Answers
SOURCE: My FN+F6 doesnt keep my screen on the laptop open
Change the settings from the display settings panel. (Right click on the desktop and go to display settings)
You should see 2 monitors graphically represented there.
You can make the monitor that is greyed out active by right clicking on the monitor, and selecting active.
Posted on Dec 11, 2008
  • 50 Answers
SOURCE: HP ZD7000 laptop screen won't work.
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
49
Posted on Jul 25, 2009
  • 76 Answers
SOURCE: Replaced Laptop Screen Brightness Problems.
hi
-try updating the system BIOS of the computer
-visit support.dell.com
-click on drivers and downloads
-click or choose by service tag
-download the BIOS and install it on the computer
cheers!
Posted on Oct 04, 2009
I was watching the TV and the screen went black. Voice is still fine.
Hello dear user, with sound but with out a picture try to turn it of then on again. Consult your TV manual if still have it. Try to check you TV setting . If after clicking the menu and you can see the on screen display you are pretty sure it`s not an inverter problem. ( usual problem on LCD,s) set your brightness and contrast. To check for inverter problem, turn your lights off and shine something bright on the screen, if you can see images then it,s an inverter problem. Then you can send it for inverter replacement for a fee on service centers or to your dealer if still under warranty. Thanks and God bless.
Sep 10, 2015 | Televison & Video
Latitude B130 screen works great then cuts out to complete black, works with external monitor
Are you sure that the display is not set for external monitor only? Also take bright flashlight and shine on the display. If you can see the images then the problem is with the back light and usually caused by a bad inverter. Some times you can get the back light or inverter bu most times it is easier and cheaper to replace the entire display.
Aug 20, 2012 | Dell LATITUDE Computers & Internet
I have a advent m201 laptop . how do i turn the built in webcam on please
Try this
Function Keys Fn+F1 - Places the computer into sleep mode
Fn+F2 - Changes the (I-Powerxross) power settings
Fn+F3 - Switches display modes: LCD only, External monitor only, LCD+External Monitor
Fn+F4 - Turns Wireless LAN on/off
Fn+F5 - Switches OSD (on screen display) on/off
Fn+F6 - Turns the Touchpad on/off
Fn+F7 - Turns the Webcam on/off
Fn+F8 - Mute Sound
Fn+F9 - Reduces speaker volume
Fn+F10 - Increases speaker volume
Fn+F11 - Reduces the screen brightness
Fn+F12 - Increases the screen brightness
Fn+Esc - Toggles Bluetooth & 3G on/off (optional)
Thanks
Dec 30, 2010 | HP Pavilion dv6000z Notebook
Hi, I have a toshiba tecra m3, it boots fine and runs fine but the screen is black, if I close it and open it again the screen comes on for a couple of seconds and goes black again. Any thoughts would be...
Try connecting it to an external monitor, it could be that your laptop is either set to display through an external monitor or it could be set on a screen size too large for the laptop screen.
Oct 18, 2010 | Toshiba Tecra M11S3410 I3330M 213G 2Gb...
MY DELL 1525 TURNS ON AND THE NORMAL BLUE SCREEN APPEARS. THEN ALL OF THE SUDDEN IT GOES BRIGHT GREEN, THEN BRIGHT YELLOW, AND STAYS BRIGHT YELLOW
Please connect your laptop to an external monitor and see if the output is the same. If it displays fine on the monitor, then we are looking at either a screen cable problem or a screen problem. If the display is the same as on the laptop, then it is a problem with the display adapter on the mother board.
All the best.
Jan 14, 2010 | Dell Inspiron 1525 Notebook
I have connected my old dell laptop to this TV with VGA cable and audio cable and it worked with no problem. Have new Acer Aspire one netbook- connected to computer with same cables - can see windows...
First, you want to make sure the laptop's internal/external display mode is set properly. On Acer netbooks, this is usually changed by holding the "Fn" key, and pressing "F5". Either the TV or the computer display should flicker when you do this. There are 3 modes:
1 Computer only
2 TV Only
3 Computer and TV
If changing between thos emodes doens't work, continue on.
I am going to assume you are running Windows XP. Please correct me if I am wrong.
To display your desktop on an external monitor, you'll need to change/check some settings. Your netbook is most likely attempting to set it's display settings automatically, but it is expecting a computer display, not a television, so the resolutions and refresh rates are conflicting. That's why it will only display on one and not the other. Before Windows loads, the netbook is using a very low resolution,so it displays on the TV. Once Windows loads, it switches to some non-standard resolution that your TV cannot display and defaults back to your netbook screen.
The solution is to find a resolution that your television will display:
1.Right-click the desktop, and then click Properties.
2.In the DisplayProperties dialog box, click the Settings tab.
3.Click the Display list and select your external monitor (..the TV. It will most likely be display #2).
4.Select the Extend my Windows desktop onto this monitor option.
5.Select 640x480 in the "Screen Reolution" section for Display #2.
6.Click Apply or OK.
Note: If you see the background change on your television, mmove your mous there to make sure it's working. If it DOES work, go back to the "Screen resolution" section for Display #2 and find the highest resolution your television will display
Sep 19, 2009 | Westinghouse SK-32H540S 32 in. LCD TV
Dec 11, 2008 | Acer TravelMate 2451WLMi Notebook
Display Problem for HP DV8230us laptop
hi there,
sounds like you have a driver or internal video card problem...but first have u tried changing the screen size/resolution and color depth/quality in your display settings...
Apr 09, 2008 | HP Pavilion dv8230us Notebook
Computers & Internet Logo
David Payne
David Payne
