Question about Lexmark Optra T610 Laser Printer
HOW DO YOU CLEAN THE ROLLERS - Lexmark Optra T610 Laser Printer
Once I turn my printer psc 2410 photosmart on it makes an annoying sound like if something is stucked and freezes staying on the clock sand mode . What should i do?
During printing, the HP product makes unusual or loud noises. You might describe the noise as grinding, squeaking, or screeching.
    Step one: Clean the rollers in the back of the product
    1. Disconnect the power cord from the back of the product.
    2. On the back of the product, find the rear door.
    3. Squeeze the tab or tabs on the rear door, and then pull the rear door toward you to remove it.
    4. Open the rear door on newer Photosmart, Officejet, or PSC productsInside the back of the product, rotate the paper rollers with your fingers to make sure that they can turn freely.
    5. Rotate the rollers located on the inside of the rear door to make sure that they can turn freely.
    6. Remove any torn pieces or scraps of paper that you can see.
    7. Dampen a clean, lint-free cloth or swab with distilled water, and then wipe the paper rollers inside the product and on the inside of the rear door clean. Rotate the paper rollers with your fingers to clean all the way around them.
    8. Reattach the rear door. Make sure that it snaps into place.
    Step two: Clean the rollers in the front of the product
    1. Lift the cartridge access door to access the front paper rollers in the product.
      NOTE: On some Officejet models, you might need to close the document catcher. Then, look in through the front of the product to access the front paper rollers.
    2. Inside the front of the product, rotate the paper rollers with your fingers to make sure that they can turn freely.
    3. Remove any torn pieces or scraps of paper that you can see.
    4. Dampen a clean, lint-free cloth or swab with distilled water, and then wipe the paper rollers clean. Rotate the paper rollers with your fingers to clean all the way around them.
    Step three: Clean the small rollers Dampen a clean, lint-free cloth or swab with distilled water, and then wipe the small rollers, also called the pinch rollers, clean. The pinch rollers are the small metal rollers directly above the paper rollers. Rotate the pinch rollers with your fingers to clean all the way around them.
    NOTE: Do not clean the carriage rod. Removing or damaging the lubrication on the carriage rod can cause the product to make more noise. Figure 9: Carriage rodc02203348.jpg Step four: Clean the cartridges
    1. Connect the power cord to the back of the product, and then press the Power button (c01602202.gif ) to turn on the product.
    2. Open the cartridge access door. Figure 11: Lift the cartridge access door on newer Officejet, Photosmart, and PSC productsc01940403.gif
    3. When the carriage stops moving, disconnect the power cord from the back of the product.
    4. Press down on each cartridge to release it from the carriage, and then pull it toward you out of its slot.
      NOTE: You might need to lift a cartridge latch before you can remove the cartridge from the product. Press down on each cartridge to release it
    5. 1 - Tri-color cartridge 2 - Black cartridge
    6. Dampen a clean, lint-free cloth or swab with distilled water, and then wipe any ink or debris from the copper-colored electrical contacts on the cartridge.
      CAUTION: Do not touch the ink nozzles or the electrical contacts with your fingers. This can result in clogs, ink failure, and bad electrical connections. Figure 13: Clean the copper-colored electrical contactsc00617184.gif 1 - Electrical contacts 2 - Ink nozzles Figure 14: Do not touch the copper-colored electrical contacts or the ink nozzles Place the cartridges on a clean sheet of paper, with the nozzles facing up.
    Step five: Clean the electrical contacts inside the product
    1. Dampen a clean, lint-free cloth or swab with distilled water, and then wipe any ink or debris from the electrical contacts inside the carriage
    2. Let the cartridges and carriage sit for 10 minutes to allow them to dry, or use a clean, dry swab to dry the contacts.
    3. Slide each cartridge into its slot at a slight upward angle, and then press firmly until you hear the cartridge click into place.
      • Install the tri-color cartridge in the slot on the left.
      • Install the black cartridge in the slot on the right.
      I hope this helps you!
May 26, 2011 | HP PSC 2410 All-In-One InkJet Printer
I dont have a problem I just need to know what product I need to clean the rubber rollers on a weekly basis
Using liquids & chemicalsmay damage the rubber rollers or harden them. It is not at all necessary to clean the rollers on weekly basis. Instead you may clean them once a month with a soft, lint free cloth damped in luke warm water to remove any dust. Rubbing the rollers excessively may damage the rollers.
Also, keep the printer in a clean dust free environment and keep the printer covered if not in use for a long period of time.
Hope it helps! Good Luck!
CreativeTECH
Mar 30, 2011 | Panasonic KV-S1025C
Card are stuck in evolis perbelle 4 so we get it by hand and then we have mechanical issues
First check for your card's thickness and adjust thickness lever accordingly.
Take a soft cotton cloth soaked with Isopropyl Alcohol with minimum water content.
Clean all Rollers including one roller below the feeder.
For cleaning Rollers you can take out ribbon and press the push button on front panel.
This will move Rollers and you will be able to clean rollers easily.
Clean the rollers below ultraviolet ribbon sensor and the roller set at output hopper also.
Feb 02, 2011 | Evolis PEBBLE 4 Led Card Printer
HOW TO CLEAN THE HP LASERJET M2727NF
To clean the Top Feeder rollers simply buy/get a can of WD-40 and clean both rubber rollers, also clean the smaller glass with alcohol if you get lines on your copies using the feeder and not the bigger glass platen. Take each drawer out and find the feed rollers, you should be able to clean those with WD-40 as well.
Mar 31, 2010 | HP M2727NF Laserjet Printer
In my Selphy 710, the paper wont feed from the tray to the printer. The rollers are rolling, and the paper gets pushed up to the rollers, but Im not sure if its not gripping the paper, or if the timing is...
sounds to me like the Pick up rollers need to be replaced, you can try to manually clean those rollers with some rubbing alcohol and some q-tips and gently clean those rollers, if that doesn't help then the rollers need to be replaced. You can usually find replacement pick up rollers online
Nov 18, 2009 | Canon SELPHY ES1 Thermal Photo Printer
What is the recomended maintenance for this machine
check and clean the feed rollers at paper feed with cloth and water or cleaning fluid remove drum unit and check the condition of the foil on drum for dents or marks.. clean the rollers at pressure roller and clean this off with spirits and soft cloth(rollers under the drum) empty out the master waste treay and clean off rollers here with spirits and cloth and check nozzle at air blower to the left of drum (Yellow nozzle for damage and blockage.. then check the tension of the master feed roller and clean the thermal heads with a soft cloth..remove the scanner glass and clean both sides with glass cleaner and clean off the lamp unit mirrors(take care here you dont miss align on guides)
Nov 05, 2009 | Riso RZ220 Duplicator
Hp 1210 paper will not feed
Hi ihimc1, over time dust and paper fibres can cause the rollers to stick, which can result in the paper not feeding please take these steps below to clean the rollers.
Turn off the all-in-one.Unplug the power cord from the back.Remove the rear access door. Clean the rollers one at a time using a clean cloth that is slightly dampened with water. Rotate the roller to clean the entire surface. Verify that the three paper feed rollers on the rear access door are clean and rotate freely.
Reinstall the rear access door and then plug the power cord back in.Turn the all-in-one back on.
Nov 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
FEED ROLLERS DON'T PICK-UP PAPER FROM THE FEEDER
Clean with Isopropyle alcohol on a qtip. (Rubbing alcohol)
Jan 22, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Cards
Hi, try to clean rollers with cloth dumped with alcohol,then use dry cloth again to clean rollers.Also clean sensors.Then go to menu and calibrate sensor. BR.
Dec 27, 2007 | Fargo DTC525 ID Card Printer
The printer takes all the papers in but prints on one how can i make it take one pagg at a time
you will need som of these rollers: Paper feed Roller Ass'y part No: RM1-0037-020 Paper Pick-Up Roller ass'y Part No: RM1-0036-020 Google the part number and you should be able to find a local dealer of them
Sep 14, 2006 | Canon LBP 800 Laser Printer
Lexmark Optra T610 Laser Printer Logo
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
