Question about 2wire 2700HG-B Router (2700HGB)
Unable to connect 2 routers need help!
I just got a 2wire 2700HG-B router and Im trying to connect my cisco 871 router to it, everytime I connect the ethernet cable from the cisco router to the 2700hg-b router i lose dsl signal and the router reboots, Im unable to establish connection b/w both routers. my network is as followed dsl line comes to 2700 router and from ethernet cable from port 1 is been sent to wan port on cisco router. I need the cisco router because of the VPN that gets assign to it.
  • jademstanley Nov 21, 2009
    I have a 2wire 2701HB-G Wireless Router connected to my PC. I need help on how to set up so I can connect my IPhone wirelessly. I do not even know where to start
  • 24 Answers
Do you have any funky subnets for your Cisco router? Do not connect the wireless router to your network yet, as it may have the same IP address as your other router.
Basically the easiest way to do this is to set a dedicated IP for the 2Wire router on the Cisoo router. Then make them stay on the same subnet, but give an IP range for your Cisco router, like 1-50 or something. If you give the 2Wire router IP .51 for instance, then give the Wifi users on the 2Wire IP range from .52-75 or something.
Make the 2Wire router only use wifi and not serve DHCP addresses. Then you setup the 2Wire router to get its info from the Cisco router.
I searched and there is no howto out there for doing this with a Cisco router. However, here is one I used to setup a similar scenario with a Netgear router. It worked. If you are able to translate a bit, it might work for you:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16778323,235,239&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2Fn101236.asp&answer_id=6056802#__highlight
Here is another article:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16777285,246,260&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2FN101496.asp&answer_id=6056800#__highlight
Let me know if you are able to work through this. You need to give the 2wire router a static IP and you need to NOT use it for wired connections, and not use it to serve DHCP settings.
Posted on Jan 21, 2009
Connected io router with excelent signal but won't connect to internet , using Beklen adapter , happened overnight.Did work well before.
It sounds as though you are using both a belkin wireless router and the 2wire 2700HG-B Router.
Setting up 2 routers to work together can be tricky and unless there is some specific reason to do so I recommend you just use the 2wire router.
Oct 29, 2009 | 2wire 2700HG-B Router (2700HGB)
I don't know how to configure my 2wire 2700HG-B wireless, I need to connect my ipod. can someone help me to set them up?
hi there, first is you need to know the wireless settings of the 2wire first, the channel, SSID and the encryption.
once wireless settings are verified then you may try to go to the IPOD, go to settings/wi-fi/ then choose the network there/ try to connect to your network/if it will ask you for a network key, input that as well/ try to connect and you should be connected now.
Jun 26, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire 2701hg-b on mac browsing great, bittorrent bad...
Try to look for MTU settings on your 2wire router. Reduce that to 1492 then do a power cycle. Check if that helps your download speed
Jun 10, 2009 | 2wire 2700HG-B Router (2700HGB)
I have a 2wire 2700HG-B router and I've had a problem connecting on a wireless connection. While the wireless card finds the network and connects, it has limited or no connectivity because the router...
The 2wire is setup with a default network key. Change the network key on the 2wire to another key or type in what you think the default network key is on the 2wire.
Jan 07, 2009 | 2wire 2700HG-B Router (2700HGB)
WUSB Linksys adapter connnection
check your dns value ,firwall,proxey server, ipaddress and router configuration also.
Jun 23, 2008 | 2wire 2700HG-B Router (2700HGB)
How do i sync windows vista with my router?
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support.
Jun 10, 2008 | 2wire 2700HG-B Router (2700HGB)
Tring to bridge my 2wire
Why do you need to bridge?
Can't you use both devices off the one router?
usually to bridge you would need, effectively , 2 extra access points to set as the bridges, they then connect to the other routers, allowing communication between the 2.
I do know 2wire is slightly different but you would still need something to act as a bridge on the netgear end.
I still don't understand why you need both routers running. Connect both your computers to the same router which has the internet connection.
Hope this helps
Tony
Feb 28, 2008 | 2wire 2700HG-B Router (2700HGB)
Wireless issue.
1. Connection of phone line, ethernet and power adapter
2. Indicator light: POWER: green; Ethernet: blink; DSL: green; Internet: blink or red
3. Open IE browser.
4. address: 192.168.1.254
5. Click "Run System Setup Wizard"
6. Log-in with preset password: admin. Or change password: click "I forgot the password." Under question "Here’s a hint for the password wedding date", click "I still can’t remember the password.". Then Reset System Password by enter System Key which locate on back of the Router (like: [1234567890]), and your new password, then click "Submit"
7."Set Up Your 2700HG-B Gateway" screen. Keep default "Key Code". Click "Next"
8. "Time Zone". Select your time zone,then click "NEXT"
9. "Set Up Connection Info". Enter "PPP Authentication" information provided by internet service provider. "Username", "Password", and "Confirm Password", then click "NEXT"
10. Screen "Connecting" running...
11. Auto turn to screen "2700HG-B Gateway Setup Complete", click "FINISH", or "EXIT" to complete setup or "Register" to register with 2WIRE on line.
For a more detailed first time install no software needed check this link:
http://www.dslreports.com/faq/14083
Enjoy!
please vote...
Feb 06, 2008 | 2wire 2700HG-B Router (2700HGB)
Slow speeds compared to speedtouch 330 usb modem
How do you connect to the 2wire 2700HG? Wireless or ethernet? In any case I suggest to access the mdc (management and diagnostic console) of your 2wire and check the DSL Diagnostics under the Troubleshooting Category. Check the attenuation rate of your 2wire there so you can see if external problems are affecting the 2wire. The 2wire is also a modem\router and eventough it rarely affects the speed of your connection, the 2wire Firewall might also affect the speed of your cx. Another thing to check are the electrical interference on your 2wire. EMI (Electro Magnetic Interference) do affect the 2wire router greatly. I mean it LITERALLY. A great Interference can cut your signal strength from full bars to 1 bar even tough your just 10 feet away from the router. You can also check the Broadband Status on the Network at a Glance Page to check if the speed are jumping in and out. And also try to contact your Internet Service Provider or the 2wire direct technical support (1-877-3478680) for further assistance. God Bless!
Sep 16, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
394 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
