Question about Logitech Premium Stereo Consumer Headset
Headset volume adjustment
How do I adjust the volume of Logitech premium stereo headphones?
  • 35 Answers
To increase the volume for headphones u need to goto Start-- Control Panel -- Sound and Audio Devices and increase the device volume under the Volume tab and also goto Speaker settings in advanced button and choose from the drop down option "Stereo Headphones" and apply the settings.
Posted on Jun 23, 2009
  • 59 Answers
If connected to a pc right click on the speaker icon on the right side of the main toolbar in windows then click on playback devices and adjust the volume there.
Posted on Apr 05, 2009
I plug it directly into my pc and it wont record on my music programs.Does this mean it is broken?Is there something im missing?.And it was purchased new but came with no directions,is that right?Also...
There is no volume adjustment. You would have to use the volume controls in the PC "control panel". Not all PC's will be compatible with this mic, as this mic is monaural, not stereo. You may have to use a 1/8 jack monaural to stereo jack/plug for the mic. Be sure and set the volume levels for both the mic and headset in the control panel AND UNMUTE the mic.
May 07, 2011 | Yamaha Cm500 Headphone With Built-in Mic
I got new Logitech Clearchat stereo headphones. I plugged the two pins into the pc - pink and green. When I do a skype test I hear the message from my computer speakers (settings says Realtek HD..with no...
realtech hd is your sound device. go into windows control panel and access the sound settings then navigate to voice settings click the volume button,your mic might be muted. also if you want the headphones to work plug them into the plug that your speakers are using (side-note: mics and head phones never need something installed to work as long as your sound device works and your definitely does work,only when the mic is a special interface like USB do you need to install software and/or drivers)
Apr 01, 2011 | Logitech ClearChat Stereo Headset Headset
I just purchased this headset plugged it into the
Do you have sound otherwise? The sound to your headset comes from your sound card. You need to ensure the soundcard is properly installed. If it's ok, check there are no checks in the boxes on your audio controller. Right click on the little speaker icon in the system tray and select "Adjust audio properties", Select the "Audio" tab and choose "Sound playback". Clear any checks from the appropriate boxes and set the volume level to suit. Should now work.
Apr 18, 2010 | Logitech ClearChat Stereo Headset Headset
I can't hear anything from my logitech headset
Hi Itsyen, go to start menu, control panel, sound. Then here go into the Tabs and select the Headset as Mic and Speakers. Apply, Done !
Thanks and have a nice day Julien
Aug 04, 2009 | Logitech 250 Headset
Left ear of headphones volume low
Out of the box or before using it, you have to charge the headset for about 4hrs or until no light on the headset (red if it's charging). Then try using it again play around with the volume. If you encounter the same thing then you have to replace it at the store.
May 01, 2009 | IOGear (GBE201W7) Wireless Headset
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
I just got the Precision PC Gaming Hd set, but people can not....
yes there should be a little speaker like icon in the task bar also known as the start bar or menu double click on it.. the there should be a drop down menu that says options.. click it then click properties go through the scroll down menu and make sure that microphone is checked.. then click ok or apply. then adjust your volume for the mic
Dec 16, 2008 | Logitech Precision PC Gaming Open Air...
Headphones with mic model # na
Most headsets do not come with a volume control interface but your mic can be adjusted by going to Sound and audio devices via the control panel of your start menu. The volume can be accessed through the audio tab. Also, depending on the program you are using i.e. Skype, Team Speak or other, your volume settings can also be adjusted within that program as well. Hope this helps.
Oct 08, 2008 | Audio Players & Recorders
ARGHH I CANT HEAR OR RECORD ANYTHING!?!?!?
Hi There Try this, VOLUME Try Adjusting the vlume on your PC first. Check the volume on the Headphone too if there is one. CLEANING Using a dump clothe. Wipe the plugs with a twisting motion. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester. Hope This helps
Sep 19, 2007 | Logitech Premium Headset
Can't hear myself when recording
Sep 04, 2007 | Logitech Premium Headset
Logitech Premium Stereo Consumer Headset Logo
351 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
