Question about HP 3115m - E-450 1.65 G- Windows 7 Professional 64-bit - 4 GB RAM -
Keyboard not working
Laptop will turn on. Windows starts up. keyboard doesn't work. glide pad doesn't work.
  • 383 Answers
SOURCE: keyboard control unit problem
either the keyboard/mouse (2 in 1 on laptops) drivers are invalid in which case you can go to http://support.acer.com and download the keyboard/mouse drivers and/or utility.
Let me know if this works for ya,
Have a great and safe Sunday !
Posted on Dec 02, 2007
gsage
  • 180 Answers
SOURCE: my keyboard and touch pad isnt working...
If your operating system is Xp / vista reimage your unit by hit F11 on started up & Hp splash screen - select advanced - select full destructive recovery - you have corrupted your device controler for human interface devices - like your k/board & mouse - there is no way to reinstall the required dll's so full recovery is required.
Posted on Mar 08, 2009
  • 74 Answers
SOURCE: some keys on my laptop`s
Hi, if you spilled liquid on the keyboard then it probably needs to be replaced,
Try this... you can remove the keyboard by removing certain screws from the bottom of the laptop, then you open the laptop like if you are using it look to for sliders around the keyboard edges or if it just snaps in place, use thin flat screw driver to carefully remove the keyboard but do not pull far.. it should still be attached with a wide flat cable to the main board... now lets try to remove the cable completely and re-attach it ( when removing the cable use your small flat screw driver to pull the plastic connector snaps from the sides of the connector to loosen the cable and be careful not to break the connector, when attaching back put the cable in first and hold it while you push the connector plastic back in place)... try the computer to see if the problem is gone, if not then order another keyboard and replace it. best of luck
Posted on Jan 26, 2011
kachi
  • 406 Answers
SOURCE: hp lap top pentium 4
It's bad and needs to be changed, ie if you must keep enjoying the old functions.
Posted on Jun 23, 2011
SOURCE: HP dv6704nr power button doesn't work but quickplay/dvd start laptop, completely turns off if screen is beyond the cut off point no matter if it is in POST or in windows, and speaker doesn't w
i would take the button bar of and check to see if the cable is off to one side its a flat ribbon cable sounds like it is a little sideways that will make that happen there is a little clip be gentle undo it a little bit and straighten it out
Posted on Mar 04, 2013
Mouse pad doesn't work on windows 8
I press <alt> F5 and it will turn on/off the mouse pad!!!
Feb 17, 2013 | Acer Computers & Internet
Ge wired mouse scroll wheel doesn't work
John:
The screws to open your mouse are hidden under the glide pads on the bottom of your mouse. remove the glide pads carefully and you'll see the screws. put the glide pads on with a non-permanent adhesive (like contact cement).
Jan 17, 2013 | Computers & Internet
The letters on my keyboard doesn't work
Dust the keyboard to remove any debris.
If that doesn't work, re-seat the keyboard. This requires disassembling much of the laptop. www.ifixit.com has great guides on how to complete this for every model of mac laptop.
Nov 05, 2012 | Computers & Internet
Both my keyboard and touchpad are not working. What do I do?
Did you try a system restore to bring the computer back in time before this happened? you mentioned recovery, did you do a full recovery of windows ? "fresh install" If you have a backup disc the hard drive needs to be completely reformated before the backup disc is used, because it looks like a virus got into your system, run a deep or full scan to find out, go to www.download.com Type: Malwarebytes Anti-Malware run a full scan to see what it finds, "free software"
Apr 15, 2012 | Sony VAIO VPCEB42FX/BJ Notebook
Keyboard doesn't work
Try connecting an USB keyboard to your Acer laptop. If the external USB keyboard does not work the the laptop is faulty.
If the USB keyboard works then reseat the laptop's keyboard connector to the motherboard, it may have become loose.
Mar 02, 2012 | Acer Computers & Internet
My Keyboard and Touchpad are not working
Try installing your Windows again.A bit hard to tell, cause it can be allot of things that went wrong..
Oct 23, 2011 | Computers & Internet
Hi, i have a toshiba x205-s9800. my two year old seems to have accidently pressed some keys and disabled the keyboard...please help...
You could have deleted the keyboard in the device manager. If so, rebooting your computer and it will find it.
Are all the keys not working or just some? Take a look at this hint and see if it fits.
http://www1.fixya.com/support/r5966678-letter_keys_now_produce_numbers
I do this for fun & feedback not $$$
Oct 02, 2011 | Toshiba Satellite X205-S9349 Notebook
I spilled I tea on my Gateway FX keyboard and mousepad. The keys are working now but I'm worried they will get sticky. I cleaned up as much as possible by patting with a towel to soak up the tea. ...
Before you do anything, unless it is already dried, (turn it off first!) turn the laptop upside down and gently tap the back to coax any liquid out. Then do NOT turn it on until it is totally dried. You can clean the keys and pad it with a DAMP (NOT wet) cloth with plain soap and water. Be careful not to get any water down into the keyboard itself so it doesn't short it out. However this will not clean whatever liquid may have gone inside. Hopefully none did else you could end up with a bigger problem...
Jul 16, 2011 | Gateway Computers & Internet
Dell Latiture D600 Touchpad not working!
Have you downloaded and installed the latest glide pad drivers from Dell?
Upon starting your laptop I would enter the bios setup screens and navigate the startup screens using Alt+P to find the pointer settings and set your or check that yours is using Glide Pad only, If you so choose to use an external USB travel mouse, this setting must be changed to Serial only.
Once, you download and install the latest drivers for the Glide Pad, and by the way, the Glide Pad on the D600 series is its only weak link in an otherwise best in class laptop.
To access the sensitivity settings for your Glide Pad after installing the new driver or in your case this may be reinstalling (I have to do this way to often) open Mouse within Control Panel and the last Tab is your Glide Pad. Here you can change a lot of the property values for things like sensitivity and double tap scrolling etc. Your mention of the mouse traveling up and to the right in most case is normal for this laptop.
Here is the link for the Glide Pad driver update. If this link has expired, here is the permanent location. Just click on the download button on this page. Download and move to a unique folder as the file name won't be of help. Move to something like c:\software\Dell\Glide Pad\
Regards,
Worldvet
Jul 24, 2008 | Dell Latitude D600 Notebook
HP 3115m - E-450 1.65 G- Windows 7 Professional 64-bit - 4 GB RAM - Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
