Question about Canon iPF700 InkJet Printer
Ipf700 paper size not detected - Canon iPF700 InkJet Printer
Kkonika minoltaprinter 363 paper not detected prperly
size detection assy stays back side of Tray.
if their tension plate moves out of position , then such issue happens.
Apr 12, 2017 | Konica Minolta Office Equipment & Supplies
Is there a drying system for the Canon iPF700? We
normally you don't have to wait for drying.
Most of the printings materials are instant dry except some special papers that the driver handles the drying time.
Be sure that the papers you are using are suitable for this kind of printer.
Oct 12, 2009 | Canon iPF700 InkJet Printer
Output is a different size to that input
Try the following, from size options set a new paper to the max dimensions (914cm width and 15240 lenth).
Then at the Layout tab click the box NO SPACES AT TOP OR BOTTOM.
It's very important to click the box if you choose large lenth paper sizes.
Mar 30, 2009 | Canon iPF700 InkJet Printer
As to enter SERVICE MODE canon imagePROGRAF iPF700?thanks
Service Mode - With power off, hold paper feed (paper select) button and info button while powering on, release after initializing screen.
Mar 13, 2009 | Canon iPF700 InkJet Printer
Disabling Ink level Detection Canon iPF700
you can disable it only if an error occures at the first in filling, with the latest firmware installed (ver 1.37) if the machine will starts normally then you can't disable it.
Mar 11, 2009 | Canon iPF700 InkJet Printer
Paper size error
What that means is that you put in a size of paper that your printer can't use. Apparently, the paper you loaded was detected by the printer and was recognized as being a size it isn't designed to use. HP.com has a web page for your printer that tells you which paper sizes you can use for your printer.
Product Specifications
When the web page opens, scroll down to the Paper specifications area and look for the Paper sizes table. Use only the paper sizes that are listed there in your printer. Good luck.
Oct 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
How to change the size of the paper on this printers
Where is your problem?
Changing the paper size and size adaptations are possible from the printer driver settings - just look into the tabs.
Paper size of sheets is detected, when you load it.
Roll paper is loaded in the drawer - and I think width is detected while the loading process.
Please give more details on your problem
Regards AToe
Jun 03, 2008 | Canon imagePROGRAF W7200 InkJet Printer
PAPER SIZE DETECTION ERROR
Are you tring to use a paper tray or the manual by pass tray?If you are tring to use a paper tray for more then one or more copiers, you are going to have to ask your service techs to change the setting of one of your paper trays to A4 in service mode. Or if that has been done, look behind the paper trays for a wade of paper blocking the size detect switchs behind the paper trays. Good Luck
Mar 03, 2008 | Canon CLC 1120 Color Copier
Loading cut sheets
Try to check the paper media set on the plotter (roll/plain paper). It usually happens if paper media is not the same with the plotter setting. To change it, unload the paper, press the media button on the printer to the right media and load the paper again. It should work now.
Dec 06, 2007 | Canon iPF700 InkJet Printer
Canon iPF700 InkJet Printer Logo
50 people viewed this question
old marine
old marine
