Question about Linksys Ultra RangePlus Wireless Routr Router
Adding ciisco router to existing network with binken on intenet.
I added linkysy sisco to my existing network
I can't see the other computers on my network or share files or printer from behind the cysco turned firewall off on both routers abd all computers
thanks mike
    Scholar:
  • 66 Answers
You have to re-crimp the wire.but if the problem persist then you will have to reset the router .i hope this helps
Posted on Sep 15, 2009
I purchase a wireless interprets 405> Do i need a router foir the wireless
X1270 is not a wireless printer...
I find nothing on an Interprets 405...
If you have purchased a wireless printer device, your computer will need a wireless card.
If your computer has wireless built in and you have no router it is called an 'Ad Hoc' network. The printer must support an 'Ad Hoc' network or you will need a wireless router.
'Ad Hoc' networks are notoriously insecure, so a wireless router is a very wise choice. It helps keep you safe from hackers on the Internet as well as it functions as a home firewall and network host.
If this does not help, please give me more detail.
Mar 22, 2010 | Lexmark X1270 All-In-One InkJet Printer
My intenet does not work through my netgear router. It will work when connected directly to the modem but when I connect to the router it shows the 2 screens with a red x. When I connect it in another room...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 07, 2010 | 2wire (1000-400108-001) Router
When I hook the etherton cord from the cable box to the Linksys router I loose all intenet contection. The only way I am able to access the internet is plugging the cable modem wire into my laptop. Any...
Jan 26, 2010 | Linksys Wireless-G WRT54G Router
I have a DGL-4100 behind a Linksys DSL router 2 networks don't.
zSB(3,3) Installing a Two Router Network Installing a router to work as the second one on a home network requires special configuration. Do the following on the second router to ensure it (and the devices attached) function properly:
    1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode. Note that some home wireless routers do not support client mode; these must be connected by cable. Check your router documentation for details on its client mode configuration support.
    2. Check / change IP address - Most home network routers use a default IP address setting. Often, these default IP addresses will not work in a two router environment. Check the second router's IP address value and reset it if necessary to work within the valid address range of the first router (and to not conflict with any other device on the network).
    3. Disable DHCP - To avoid IP address conflicts between all of the devices on the home network, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
Instead of adding a second wired router to an existing network, consider adding a network switch instead. A switch accomplishes the same goal of extending the size of a network, but it does not require any IP address or DHCP configuration, greatly simplifying configuration.
Oct 10, 2009 | Computers & Internet
Adding lap top to wireless network - need network key?
If you don't remember what the key is, log on to the router and create another one. You will have to change the key on all other wireless devices on the network.
May 18, 2009 | Buffalo Technology AirStation G54...
Router installation
You do not have to uninstall your existing router. You can connect the new router to one of the ports on the old router.
But why would you do that? All wireless routers also have ports for wired connections. You are adding an additional possible point of failure in your network. Unless you have a good reason, keep it simple.
Jan 08, 2009 | Computers & Internet
Cannot setup home wireless network between computers
Hi!
Since all computers are online, you do not need to change any setting on the router for the computers to share file or resources.
If you are using Windows XP - try this link:
http://support.microsoft.com/kb/304040
For Vista:
http://windowshelp.microsoft.com/Windows/en-US/Help/e2e03106-2546-4085-bd07-6c3ac95003111033.mspx
I hope that helps!
Good luck and have a nice say!
Dec 02, 2008 | 2wire 2700HG-B Router (2700HGB)
Home wireless network
Most wireless1.gif networks are setup as infrastructure networks, meaning all communication is to/from a wireless access1.gif point/router that serves the same function as a switch/hub in a wired network as a central point to transfer communications from machine to machine. One works over the air the other through a wire.
There is an alternate form of wireless networking1.gif refered to as ad hoc -- in this version of wireless networking every wireless adapter1.gif can "talk" to any other wireless adapter configured with the same SSID (name) and security encryption (none, WEP, WPA). This is how somewhat less impromptu wireless networks are created similar to impromptu infrared networks some of us have used. One limitation of the ad hoc networks I have seen configured to date is access to the internet. I have posted an article where a stationary PC (required to be running for any other wireless machine to access the internet) with a wireless card in ad hoc mode could act as the router for wireless network but it required a cabled connection the internet. I suppose it could be a second wireless connection on a separate channel with a second wireless adapter in an infrastructure network but why? These types of networks are only recommended in another article for a limited (small) number of machines.
Based on this are you asking to create an ad hoc network to connect 2 PC's1.gif wirelessly without a wireless router1.gif or access to the internet from the wireless network (without a dedicated machine)?
Dec 19, 2007 | Linksys Wireless-G Broadband Router
Linksys Ultra RangePlus Wireless Routr Router Logo
89 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
