Question about Sanrio Hello Kitty Watch Set
Need to get the back off my mzb sanria hello kitty watch
Need to change battery in this watch and don't know how
How do i get the back off a hello kitty, Sanrio watch?
You don't, you take it to a jeweler to replace the battery. Typically $6 to $15. They have all the tools, the know-how and the batteries.
Mar 05, 2018 | Sanrio Toys
How do i set time on hello kitty watch
If the watch has a stem, it probably pulls out and rotates for time setting.
Dec 26, 2013 | Sanrio Hello Kitty Watch Set
Hello Kitty Digital Camera 87009v2
This Sakar needs to be returned, too many people are having problems with these, buy something better.
Jan 17, 2013 | Sakar Hello Kitty 87009 Digital Camera
I dont know how to change it
Hi Mateo,
I suppose you don't know how to open the backside of your watch, to replace the battery.
If that is so, check the back side of your watch. At the edge of the centre cover, or just under it, there is at 1 place a little notch of a view millimeters. Juse a small screw driver or tweezers for instance to lift it up. If you don't succeed, the cover might be tight and sticky. So you need to put the back side of your watch on a hot and wet cloth. That might help to loosen the sticky edges.
Good luck ;)
Andre
Oct 20, 2012 | Watches
Changing battery on TE4027 watch
Pl don't try yourself better visit a well experienced watch maker to replace it otherwise you will finish with worse
Jun 23, 2012 | Ted Baker TE4027 Watch
Just purchased a gold ladies 1928 watch. No instruction manual with it. Is it a manual windup or battery operated watch? Need instruction manual or booklet also.
Hello Ted,
Can you please specify the the Brand and Model of the watch? If you don't know it, just specify all the markings you can read from the watch.
Thanks.
I'll be waiting for your reply.
Nov 16, 2011 | Watches
I've lost the instructions for changing the channel on the our Hello Kitty KT2022 walkie talkie. It would seem simple (obviously someone played around with it and figured it out) but we can't seem...
To change the channel on the Hello Kitty KT2022 Walkie-Talkie:
-Tap the power button. The channel will blink.
-Use up/down arrows.
-Tap the power button again to save the channel selection.
The entire manual can be downloaded from here:
http://www.spectraintl.com/images/stories/pdf/hk/KT2022%20Manual.pdf
Oct 19, 2011 | Spectra Hello Kitty Mini FRS Two Way...
Sanrio Hello Kitty Watch Set Logo
54 people viewed this question
Top Sanrio Toys Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Sanrio Toy Expert? Answer questions, earn points and help others
