The audio output in imcos gitiesse PA system is very low in public spaces.why?
Have replaced the amplifer with new one but no improvement.
Garfunkel01
  • 56 Answers
SOURCE: audio output
you should be able to connect any pc to any home stereo device. you will need a special cable to connect them though. usually a local radio shack or circuit city type store will be able to help you. You will need a " Stereo Headphone to Stereo RCA " cable. ask someone at the store for one of these, explain what you are trying to do, and they will likely be able to help you as well. after you get this cable you can simply plug your computer into the back of the Speaker amplifier (usually called aux or line1) where there will be a red and white plug. set your amplifier to the Aux input and listen away.
Posted on Aug 15, 2007
  • 146 Answers
SOURCE: after the thunderstorm...
these are amplifer ic's that drive your convergence yokes. this is not something that a consumer can do.
Posted on Mar 15, 2008
  • 12 Answers
SOURCE: low volume and problems with squelch
Check your speaker for a short.
Posted on Aug 14, 2008
  • 29 Answers
SOURCE: how can I connect my P.A. system to pur phone
This is very tricky unless your phone system has an analog audio line input provision. It's almost impossible to introduce external audio ( from your P.A. system ) into the phone system when a phone is on hold unless the PBX system has an external audio line input. If it does, all you need is a standard 600 ohm to 600 ohm audio transformer where you connect your P.A. systems preamp signal out to one side of the transformer and the other side of the transformer to your PBX systems external audio ON-HOLD line input.
Posted on Sep 01, 2009
  • 4234 Answers
SOURCE: pioneer SA100 integrated - low, distorted output
At this point, I would be looking at the main power suply for the final output stage. You may be attempting to drive the output with the driver section rather than the final amp stage. The center pin of the output transistors should have B+/B- on them. Measure that to ground and report the value here.
Dan
Posted on Jul 13, 2010
I need PA speaker recommendations for a 100 watt powered mixer rated 4 ohm minimum.
100 watt output isn't a huge amount for a public address system by today's standards but where PA is concerned there are a number of variables to be taken into consideration and these are best considered by experts in that field who will then suggest a variety of options.
They will want to know whether it is to be used indoors/outdoors, whether it needs to be weatherproof, whether it is to be portable or fixed, the size of the venue, whether it is a 100 volt line and the size of your budget and probably a few other things in addition...
Apr 18, 2017 | Audio Players & Recorders
Why will Amp not produce sound unless the input and output are patched together
A typical stereo receiver / amp consists of switching low level input signals (CD, DVD, Phono, DAT, etc.), processing them and then output to the amplifier (low level) input for amplification to levels needed to drive speakers. The low level signals would barely be audible via an earphone, so they need to be boosted significantly in order to drive speakers.
Some amps provide jumpers to insert into the phono jacks on the rear of the amp to bridge the processed low level output signals into the low level amplifier input. You could install a Y cable here to feed two amplifiers - or - connect a tape recorder's "REC L+R" to the low level output and the "PLAY L+R" to the low level amp input so that you'd hear the actual audio as it had been recorded on the tape.
If you remove the jumpers (or tape recorder if used instead), there is no way for the low level audio to get into the amp's low level inputs for amplification.
Feb 24, 2015 | Audio Players & Recorders
CB Plays out PA Speaker
it is possible that the PA speaker output is intended for a normal (unpowered, unamplified) speaker. Perhaps in your case the audio you hear from the PA speaker is only signal leakage from the PA Speaker connection.
To know.. connect a regular speaker to the PA speaker connector (any speaker, home audio, old car 6x9....). If the PA works and drives the temporary speaker OK, and you hear no CB receive, then the PA output is for a normal speaker, with leakage of CB audio.
It is just a guess, but easy to try.
May 04, 2014 | Radio Communications
Sleuthing a 300/4 low-ohm issue. 300/4 amp history: unknown. just connected today whole system yesterday/today: head unit, 300/4(to 4 polk 6.5" component speakers brand new) 1000/1 (4-W3's),...
Are you sure you getting enough power to push everything. I have seen when the voltage is too low coming in, the amps will shut down so they don't overheat. Once they've cooled off and the volume level is lowered they will kick in again. Low voltage and a heavy draw will create massive amounts of heat.
May 24, 2011 | Jl Audio 500/1 Car Audio Amplifier
Lost manual. I need to know how to hook a TDK-3826 dual recorder to a PA System at church to record the services and what CDs to use.
Hi wpless43!
The TDK-3826 supports analog input/output, digital coaxail input/output, and digital optical input/output. To connect a PA system, you'll have to determine what type of connection it uses. If your PA system uses an analog connection, it will have two audio cables, one for the left sound channel and one for the right channel. These are color coded and can be connected to analog connections on the back of recorder. Coaxail and optical connections are both single cable connections, and can be connected to their respective locations on the back of the recorder.
Regardless of the connection used, you'll want to connect one of the outputs of the PA system to the recorder if you want record. If you want to use the recorder to play back audio over the PA, you'll want to connect the output of the recorder to the input of your PA. Most PAs support multiple outputs and inputs, so you should be able to connect the recorder input and output at the same time.
You'll want to use CD-R/RW discs to record, but make sure they are audio discs (See image). joehaydu.jpg
You can find a copy of the manual for the TDK-3826 at http://audio.manualsonline.com/mdownloads/bd4c0d62-6f82-4bfb-bf83-8d832f3fe222.pdf. Hope that helps!
Mar 05, 2011 | Computers & Internet
How to connect microphone to Yamaha RX-V365 as a PA system.
Home-theatre receivers don't have microphone inputs. If you want to use the receiver as an amplifier in PA system, you need to use some kind of mic pre-amp or a mixer with mic inputs.
For PA mixer is needed anyway almost every time and all mixers have at least one mic input (with a pre-amp). Mixers have line-level output(s), which you can connect to the analog input of receiver.
Using receiver as an amp in PA has advantage that you have 5 channel amp. When using high sensitive PA speakers (as oposed to less sensitive Hi-fi home speakers), you can get good performance with the power rating of receiver. You could even use 2 separate channels for subwoofers and 2 channels for satelite speakers - but for that you would need a receiver with 5.1 analog inputs and special device called crossover which would divide the output from mixer into low-frequency signal and high-frequency signal which you would then connect to the front and rear analog inputs. But with RX-V365 you can use only 2 channels with analog input
Sep 15, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Need a new amplifer for a sh-eh790 as my main audio output has gone
before throwing out your old amp open it up and check the processor inside the amp its a little black thing behind the fan. if that dont work then contact me again. and i will suggest more things. but if you really want to replace it would you give me your old amp please and here is a link to a amp for you. i know its correct as i have the same system. I LOVE TECHNICS PRODUCTS. http://cgi.ebay.co.uk/Technics-SA-EH790-AMPLIFIER-/130501062833?pt=UK_AudioTVElectronics_HomeAudioHiFi_Amplifiers&hash=item1e627830b1#ht_646wt_1141
Nov 14, 2009 | Technics SCEH790 CD Shelf System
How can I connect my P.A. system to pur phone system? cheaply easy Phone is NEAX PBX P.A. system is basic pre-amp output (analog)
Aug 31, 2009 | Audio Players & Recorders
The pa won't work. Tried a different outlet. nothing happen
Because you have not indicated a make or model, I can't rpovide any details at all, but I would suspect that the outputs have shorted and that the main fuse has blown. Replacing the main fuse may show you some lights, but you will not likely get any output. The internal protection circuits will prevent the outputs from working. Please post the make and model and I should be able to provide you with more details.
Dan
Mar 17, 2009 | Audio Players & Recorders
47 people viewed this question
 Grubhead
Grubhead
