Question about Promethean Board Promethean Prm-20a 720p Lcd Projector - Open Box
Prm-20 reset lamp hours - Promethean Board Promethean Prm-20a 720p Lcd Projector - Open Box
Green light on prjector PRM 35 will not stop blinking and the projector will not come on
open the case, and reseat the ribbon cable at both ends.
5 screws on the bottom and 3 screws inside the lamp housing to open the case. Be careful not to break the 2 plastic clips in the back.
Also check the micro switch on the lamp door is working correctly.
Mar 10, 2014 | Promethean Board Promethean PRM-35 DLP...
Prm 25 projector
Not what you want to hear but this error means the lamp did not ignite. The most common problems I have had with projectors has always been the lamp itself, so if you have another or know someone with a good lamp try that first.
Jan 15, 2014 | Promethean Board Lamp for PROMETHEAN PRM25...
I need instructions on how to replace the lamp in the promethean prm-25 projector
Make sure projector is unplugged and cooled down, lamp can be very hot
Remove the cover over lamp area
There are 3 screws in lamp unit (they have little arrows that point to them even) or check against new lamp to make sure you take out the correct ones
Pull straight up, place new lamp in securely and screw back down (screws are attached to each lamp set)
Place cover back over lamp area and screw closed
Reset lamp hours by hooking up your computer to board
Get to lamp reset screen
Press down up left right arrows in sequence then press return button in middle
Jan 26, 2013 | Promethean Board Lamp for PROMETHEAN PRM25...
How do I reset the lamp counter
You CAN reset the lamp hours. It is surprisingly easy.
Hold UP on the projector until the lamp hours appear. Then press left or right to reset.
This took me a while to find! But it's in the service manual.
Aug 19, 2010 | LG PREMIER - RD-JT50 RD-JT52 - AJ-LT50 DLP...
Sanyo PLC XU48 Need to know the lamp hours!
press and hold down the power button for about 20 seconds. The info will show in the top right of the screen.
Micketec
May 25, 2010 | Sanyo PLC XU48 Multimedia Projector
Flashes change lamp after a couple of hours run
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Oct 02, 2009 | Sharp ANXR1LP Projector Lamp for XR1X,XR1
Can't start infocus sp7200 after changing lamp.
The end of lamp timer has reached it's limit and won't let the new lamp strike. What you need to do is Reset the end of life timer. To do this, with the projector switched off press and hold both the up and down Brightness buttons on the projector. while holding them in turn on the projector. Continue holding the buttons in for 10 to 15 seconds This will reset the end of life timer in the projector.
Cheers
Sep 25, 2009 | InFocus ScreenPlay 7200 Multimedia...
Plus UP-1100 Lamp Hours Rest Procedure needed. The lamp is replaced but no menu option for resetting hours and Google provides no answer.
To reset the lamp timer on the Plus UP-1100, turn on the projector, press the menu key, navigate to the power menu, go to the lamp timer, then press and hold the "power on" button on the remote control for 20 seconds - you will see the timer reset to 0000.
Aug 05, 2009 | Office Equipment & Supplies
Shuts lamp dwons as if over heated. Lamp 4200 hours.
You need to reset the lamp hours. Here is the manual to tell you how to reset.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and please Rate. FixYa!
Mar 12, 2009 | Panasonic PT-AE700U Multimedia Projector
Promethean Board Promethean Prm-20a 720p Lcd Projector - Open Box Logo
260 people viewed this question
Top Promethean Board Office Equipment & Supplies Experts
FireballXL55
Gramonion
Gramonion
Level 1 Expert
Are you a Promethean Board Office Equipment and Supply Expert? Answer questions, earn points and help others
