Question about Vtech Lands Phones
2 of my 4 vtech handsets keep giving me a 'check battery warning'
When i check the battery and place it back on the holder it charges for a while and then goes back to 'check batter warning'. If i put it on a different phone set it charges just fine. Is the problem in the phone set?
  • 71 Answers
Try to reset the handset from handset menu, maybe the eeprom setting for low battery warning threshold have been ereased . Also check ,if the battery is the oregional battery for the phone.
Posted on Jan 21, 2009
How to activate a vtech phone
Instructions
    • 1Remove the battery cover from the back of the phone. Most models have a door that slides downward to reveal the battery compartment.
    • 2 Install the battery by inserting the connector on the battery wires over the pins in the handset battery compartment. The connector will only go on one way.
    • 3 Insert the battery pack into the compartment and replace the battery cover.
    • 4 Charge the phone by sitting it in the charger for a minimum of 16 hours on the first charge.
    • 5 Place the fully-charged phone onto the cradle of the base unit and wait for the display to show "PRESS FIND HNDST 4 SEC ON BASE." If the message does not come up, lift the phone off the base and put it back in the cradle.
    • 6 Press and hold the "FIND HANDSET" button on the base unit for approximately four seconds. The display on the phone will change to "PLEASE WAIT," then "HANDSET X REGISTERED."
    • 7 Test the phone by making a call.
Jul 14, 2014 | Vtech Lands Phones
Model 2461 - "check
Power light indicators on flashing red as warning that battery is almost depleted of functionality. ascertain that devices with extension cables deriving power from elsewhere are plugged in to reattain power to acheive regular functionality. For example, devices with red light indication as power warning would also flash yellow or green when in full power charge from another source. refer with devices user guide or manual for refering, diagnostics.
Jul 20, 2011 | Vtech VT 2461 Cordless Phone
LI misplaced my handset How does the "locate
The locate handset button will make the missing handset ring for 60 seconds. This will usually give you time to find it (assuming the handset battery is good, the handset is not out of range, and/or the handset ringer isn't set to OFF). Once you have the handset, press the Page/Handset Locator button or place the handset on the base.
You can press the locate handset button again if you haven't found the handset in one minute. The manual for the Vtech 2451 is available from Retrevo: http://www.retrevo.com/support/Vtech-t2451-Telephones-manual/id/470ag516/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
(If you have a large area or several floors to check, those 1 minute intervals aren't enough time to search for one person. Enlist assistance if you suspect the missing phone isn't just under a throw or pillow near the couch (for example).)
Jul 01, 2011 | Vtech 2451 Cordless Phone
I have a three handset 6.0 v tech. the one handset keeps beeping. What is going on?
With vtech phone (many times) a beeping handset indicates a low battery or an inability to connect to base station. check to make sure the battery is connected correctly and that the phone is setting in its docking station correctly. (remover and obstructions that would prevent correct charging) If this fails go to your local store that sells batteries for cordless phones and purchase to correct type.
Oct 13, 2010 | Vtech 5.8 Ghz Handset Cordless Phone...
One of the handsets is flashing "Warning Check Battery" It is a mi6896.  We have lost two of the handsets.  We don't know how to use the "Find Handset" feature on the base unit (the manual...
Find handset works by causing the handset, or handsets to beep when you push the button on the base unit, and until you find the handset and push the off button. If the handsets do not beep the batteries are probably dead.
We have a handset that flashes "Charging", and later, "Connecting", but it never connects. When the handset is removed from the charger the handset shows "Place in charger". By process of elimination I have determined that the handset has a problem. The problem is NOT with the battery OR charger. I hope this info helps you.
-Vector721
Aug 05, 2009 | Vtech mi6896 Trio Cordless Phone
VTech 2420 handset will not promp me to key in the base ID
If the other three handsets work ok then you have a defective handset.
Mar 17, 2017 | Vtech VT 40-2420 Cordless Expansion...
My vtech 5825 screen says NOT REGISTERED and does not work
Place the handset in the charger and press find handset for 4 seconds.This will register the handset. do the same for other handsets.
May 16, 2008 | Vtech IA 5845 Dual Handset Cordless Phone...
Warning check battery
I have the same problem.... not sure why it happens but in fact the battery has actually been charged. If you open the battery compartment, then unplug the battery and plug it back it will work fine. Quite annoying to have to do this all the time.
Feb 27, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
Vtech phones loosing connection to base
You are pretty close to the solution. The problem is the charge detection in the handset. All handsets on a cordless phone detect the battery level with an hexadecimal value in the memory. Each hex value equal a volt value of the battery. EX: 3.5v = 9B
3.6v = 9C 3.7v =9D etc... The problem is the hex value in your defective handset are all mess up. So 9B is not 3.5v anymore. Then your handset could last 1hr after foul charge or doesn't alert you before the phone goes dead due to low BAtt.
Mar 20, 2007 | Vtech i5808 Cordless Expansion Handset
Lands Phones Logo
589 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
