Question about Dell Dimension 8250 PC Desktop
Dell Dimension 8250 won't boot-up IDE fail code 5
My Dell Dimension 8250 won't boot.  The hard drive is making a clicking noise and the monitor was blank.  I reviewed the manual and it directed me to view the 4 lights on the back of the CPU.  I have 3 green then one yellow.  The manual then directed me to open the box and check the drive connectors.  All connections are good - nothing lose.  Upon rebooting, I hit F12 and ran the IDE diagnostics. It recognized the hard drive but it failed the test with error code 5.  Now when I try to reboot the system I get "error loading operating system."  I'm going to try and boot with my operating system reinstall disk - wish me luck.
What is code 5 and is my hard drive dead?  Any suggestions for moving forward?
  • grahamdr Jan 21, 2009
    I tried to reinstall OS but it couldn't do it because the hard drive "is operating outside normal specifications".  The message went on to advise me to replace my hard drive.  Thanks for the help.
    Problem Solver:
  • 3 Answers
Install your OS and then firstly run chkdsk..
Posted on Jan 21, 2009
Have a used dell dimension 2400, hard drive died i replaced it, but i dont have the original os disc that came with the system, can i use my copy of vista, or find another copy
If your Dell computer had Vista installed then you can use your copy of Vista CD and you can use the product installation code that is printed on the Windows label that is attached to your Dell.
When you insert the Windows CD into your Dell and boot up your computer then select the CD as the boot device (ie 4=IDE CD).
After Windows is installed and activated then you need to install the Dell computer's device drivers.
You can download the device drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows of the drivers for your Windows operating system. Click on this link to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Jan 21, 2013 | Dell Dimension 2400 PC Desktop
Computer acts like it in standby mode will not power up, made a weird noise according to my daughter and quit
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 23, 2011 | Dell Dimension 4400 Power Supply ** FREE...
Error code; 00f00:136c IDE device failed; Blank or no media is present in optical drive. Front panel audio and flex bay cable: not installed Onboard or USB floppy drive (not present) Onboard IDE hard...
the diagnostic was looking for media in the CD drive during the test. If the drive works in Windows and reads media or you can boot to the CD drive, then there is nothing wrong.
Jan 07, 2011 | Dell Dimension E310 PC Desktop
I got the blue screen of death on my Dell Dimension 8250. I was able to boot once in safe mode and retrieve 1/2 of my files. Now it won't boot at all and is making a ticking noise. I would like to...
If you have faulty RAM, this can cause massive instability with your system. Is the ticking noise coming from the hard drive? If your hard drive is failing or has bad sectors, this can also cause problems as the Operating System tries to use that damaged sector.
Try to test the unit using a new RAM modules.
Let me know here again for any development.
Jul 08, 2010 | Dell Dimension 8250 PC Desktop
When I start up my Dell Dimension 8250 (Windows
Sounds like the machine got stuck in the middle of a installation of windows. Best thing to do is to reinstall windows and let the cd format the hard drive, if it can't format the hard drive then the hard drive is bad and would need to be replaced.
Apr 23, 2010 | Dell Dimension 8250 PC Desktop
Inspiron 8500 laptop (80GB) intermittant boot failure
Hi
Thank you for your query
If there is a clicking noise inside then the hard drive is on the way out, the arm that reads the data is knocking against the plates, thus the noise
I would recommned that you back your data as soon as possible as the drive will eventually fail
Please can i ask that you leave feedback and vote if this has been useful
Feb 12, 2010 | Dell Hard Drive for Inspiron 8500 and 8600...
Want to wipe hard drive on dell dimension 8250
You don't need a recovery cd (or any other cd) to wipe the hard drive. Boot to a command prompt and type "format c:"
Reinstalling your operating system is the only time you need a recovery cd. If you have no way to reinstall your operating system, don't wipe the hard drive.
Jun 30, 2009 | Dell Dimension 8250 PC Desktop
Dell 8250 Hard drive 0 not found after move from US to UK
IT sounds like the hard drive went bad, especially with the clicking noise. If you want to keep the system, you will need to buy a new drive (relatively cheap) from tigerdirect or newegg and istall it. NOt sure if dell still send out recovery cds with their systems but if you have one just insert the cd after you install the new drive and follow the prompts. If you do not have one contact dell support and they should beable to send you one
Jan 21, 2009 | Computers & Internet
Dell Dimension 8250 PC Desktop Logo
584 people viewed this question
Alun Cox
