Question about NetGear WGR614 Wireless Router
Intenet connection I have ethernet internet but unable to use wirelessly. Also I am unable to remember the netgear password and User
  • Julie69willi Jan 22, 2009
    my netgear is slowing my pc and ps3 console down, due to not having password for netgear, can you help?
  • 55 Answers
Hi did you change the password? To login type either http://192.168.0.1 or http://192.168.1.1 in your address bar in your web browser.
The routers username is admin, the default password is password or (for older routers) 1234
Try the default username and password before resetting the router to the factory defaults.
If these don't work you will need to reset the router, but be advised that by doing this you will loose all your ISP settings. So make sure have a way of restoring them. You can either do this manually by going to your ISP's website and making a note of the settings or by using an installation disk that you got from your ISP.
DO NOT RESET UNLESS YOU HAVE A MEANS OF DOING THIS  AS YOU WILL NOT BE ABLE TO CONNECT TO THE INTERNET AFTER!
To reset
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
Log in with the default password.
If the router was not cleared, try these additional steps AFTER the router has finished rebooting.
  1. Unplug the router's power.
  2. Press and hold the reset button. While the button is held down, reconnect router's power.
  3. Continue to hold the reset button for 20 seconds after reconnecting the power.
  4. Wait for the router to reboot.
  5. Log in with the default password.
Hope this helps.
Posted on Jan 25, 2009
NetGear router WGR614 v9. No manual, don't know user name and password so can't login to your site. Need an encryption key for this router. Cannot get a wireless connection to internet otherwise.
plug computer into ethernet port of router
Via blue ethernet cat5 patch cable
try user name admin
and password as password
try 192.168.1.1 ( later version of router ) or 192.168.0.1 for router ip address in an internet browser.
then look at the wi fi settings for wi fi security encrption key or add one if not set .
https://www.lifewire.com/netgear-wgr614-default-password-2624841
Oct 16, 2017 | NetGear Computers & Internet
How to configure the router??? how to used the router?
To configure router it depends on whih router you are using a broadband or a wireless. Here I can so you how to setup routers in different ways. Here I have defined 5 different router to setup it.That is given bellow. How to configure linksys broadband router.
  • Connect and install your router according to the product manual.
  • Open your Web browser then check your product manual for the Web address you need to enter.
  • Enter the Web address, then enter the user name and password supplied in your manual.
  • Enter the required setup information. You'll need to call your Internet Service Provider (ISP) for this information if you don't have it already.
  • Choose the connection type you want from the drop-down menu labeled "WAN Connection Type." The connection type you need will depend on the information you receive from your ISP.
  • Click the "Apply" button to save your settings, then close the browser window.
  • Reset the power on your modem.
  • Restart your computer.
How to configure netgear wireless router.
  • Connect your high-speed modem to the Netgear wireless router with an Ethernet cable. Turn off and unplug your high-speed modem's power before connecting the device to your wireless router. Plug the Ethernet cable that was connected to your high-speed modem into the "Internet" port on the back of your Netgear wireless router. This port is located next to the wireless router's power port and is designated by a green color.
  • Connect your computer and the Netgear wireless router with an Ethernet cable. Shut down your computer before connecting it to your wireless router. Plug one end of the short, blue Ethernet cable that came with your Netgear wireless router into your computer's Ethernet jack. Plug the other end of the cable into a LAN port on the back of your wireless router. Your wireless router will have several numbered LAN ports, designated by a yellow color. It does not matter which LAN port you use.
  • Turn on each device in order. First, power up your high-speed modem, then wait at least 2 minutes. This allows it time to connect to your Internet Service Provider's (ISP) server. Make sure that your high-speed modem's status indicators show that it has successfully connected to your ISP's server. Next, plug the Netgear AC power adapter into the Netgear wireless router and a power outlet. The AC power adapter plugs into the back of the wireless router in a black-colored port labeled "Power." Wait at least 2 minutes for your wireless router to connect to your high-speed modem. You will know that it has successfully connected if all of the status lights on the front of the wireless router are on. Finally, turn on your computer.
  • Open your Web browser and connect to the wireless router's URL. In the address bar of your browser, type in the wireless router's address. The Netgear wireless router addresses are: http://www.routerlogin.net, http://www.routerlogin.com or http://192.168.1.1. You can use any one of these URLs. Press "Enter" on your keyboard once you have typed in the address.
  • Input the default user name and password. The default user name is "admin," and the default password is "password." The text boxes are case-sensitive, so it is important that you use lowercase letters.
  • Follow the Setup Wizard instructions. Once you log into the router, a Setup Wizard will load and ask if you want it to detect your Internet type. Click the "Yes" radio button, then click "Next." Once you have completed the wizard, configuration is complete, and you can access the Internet using the wireless router.
  • Configure wireless settings. If you have wireless devices that you want to connect to your Netgear wireless router, you must access your wireless settings. Log into the wireless router as described in Steps 4 and 5, then find and click the "Wireless Setting" link on the main menu. You can change the default SSID (wireless network name) from "NETGEAR" to a custom name, and you can change security settings such that a passcode is required to log onto your wireless network. When you finish changing your wireless settings, click "Apply." You must use this SSID and passcode to connect your wireless devices to your Netgear wireless router.
How to configure 2wire router.
  • Things You'll Need :
  • Ethernet cable
  • Connect your router to your computer using the Ethernet cable inserted into the appropriate ports. Launch your browser and type the following in the address bar:
  • http://gateway.2.wire.net
  • Click the tab for "Home Network." In the right-hand frame, "Status at a Glance," click the button next to the "Wireless" option (in the Home Network section) and set to "Disable."
  • Click the "Wireless Settings" link in the top menu bar. Verify or type the name SSID, which is the Network Name (located on your router's label with the prefix, "2WIRExxx" where *** is the unique identifier). Locate your WEP encryption key on the label below the serial number.
  • Select the Wireless Channel using the drop-down menu. Click the box next to "Enable" to enable SSID Broadcast.
  • Click the box next to "Enable" to set the Wireless Network Security. Select "WEP-Open" in the drop-down menu for "Authentication." Click the button next to "Use default encryption key."
  • Set the Power Setting to "10" using the drop-down menu. Click the "Save" button.
  • Click the "System" tab above the top menu bar and click the option, "Restart the system."
  • For your wireless router: exit the browser application, unplug your Ethernet cables and select your network in the list of available wireless networks. Type your WEP password in the "Password" and "Confirm Password" fields. Click the "Connect" button.
How to configure SMC router.
  • Ethernet cable
  • Plug an Ethernet cable into the back of any network computer and plug the other end into any port on the back of the SMC router.
  • Open the Internet browser on the connected computer. Type "http://192.168.2.1," "http://192.168.2.1:80," or "http://192.168.2.1:88" (depending on your model of SMC router) into the address bar and press "Enter."
  • Enter the default password for your SMC router, found in the instruction manual for your specific model.
  • Click "Advanced Setup," "WAN," and click "PPPoE."
  • Enter your username and password for your Internet connection (if any). Set the "MTU" value to 1440 and set "Maximum Idle Time" to "0" (zero).
  • Click "Advanced Setup," "Wireless," and "Encryption." Enter a 26-character code of your choice to password protect your network. Press "Apply" to save your configuration changes.
Aug 24, 2011 | Computers & Internet
Not sure that this is a netGear problem, however, I have Windows XP, (Very old version, prob never updated - not mine - Father in laws) Ethernet port broken so bought NetGear N300 wireless adapter. Have...
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Jan 12, 2011 | NetGear Computers & Internet
I can not connect my Netgear router to my computer though ethernet cable also could u tell me what a WPA key is please.
Hi Kelly, Connecting the router with cable is fairly easy and hassle-free. All you have to do is connect the router and PC using CAT5 or CAT6 Patch cable and the internet should work if the cable is fine. It is indicated by the corresponding LED on the router and LAN port LEDs of PC. WPA Key is the password required to connect wirelessly to the router. User Guide for NetGear WGR614 is available for reference.
To secure the router, first you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is usually 192.168.1.1 or 192.168.0.1 and lookup for the options to do the following: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password (unless you've configured otherwise, the default username is admin and the password password.)
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Settings" 2.Under "Security Options", select your desired encryption method (preferably WPA or WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Apply
Now your router and your connection would become secure and the user has to provide the network key (WPA) to access the internet.
Feel free to contract me for further assistance
CreativeTECH
Dec 28, 2010 | NetGear WGR614 Wireless Router
Cannot remember my WEP 128 number. How do I find it please?
hi,
it should be
http://192.168.0.1
http://www.netgear.com/Products/RoutersandGateways/WiredRouters/DG834.aspx
  • Username = admin
  • Password = password
    • For older devices, password = 1234
  • Regards
    Gewiz,
    Dec 26, 2009 | NetGear DG834 Router
    Need my WPA key for my Netgear wireless router(model no wgr614) my sons X-box 360 live wont connect to my wireless router without it..tyvm
    connect your router to computer with ethernet cable.
    Then you can access it with following link.
    http://192.168.1.1
    or
    http://192.168.0.1
    type user as "admin" and password as "admin" or blank or "password"
    Then you can see configuration page of router.
    Click on wireless security check WPA code it is your password to connect internet .You can also change it there then save and restart router to take effect.
    Let me know if you need further assistance.
    Thanks for using FixYa.
    Dec 25, 2009 | NetGear WGR614 Wireless Router
    I am trying to change my router supplied by vodafone at home for the netgear DGN2000. I have used the cd set up and input the relevent passwords and name but I don't get connected to the internet. any...
    Sir what you can do is to try the user name as admin and password as the word password both in lower case and then you will have the access to netgear smart wizard from where you can do all the setting's.
    Default access:-
    username:-admin
    password:-password
    Nov 18, 2009 | NetGear RangeMax Dual-Band Wireless-N...
    Net gear was completely disconnected from computer. net gear WPN82r v 2 was inadvertently reset. dont have a password. any help
    To bypass the wizards, connect the router via an Ethernet cable, log in from a DHCP enabled (IP & DNS) computer at
    http://www.routerlogin.net/basicsetting.htm
    User name is admin and the password is password, both in lower case letters.
    Note that wireless connectivity is off by default. When you configure this router manually , remember to turn the wireless connectivity on.
    Jul 11, 2009 | NetGear RangeMax WPN824 Wireless Router
    Have lost/can't remember the security code to wirelessly connect to my netgear DG 834G
    Paul.
    Can you connect to the router via ethernet?
    If so assuming you havent changed the routers address connecting to 192.168.0.1 from your web browser should get you into your routers admin page.
    Once you have entered the user name and password click the Wireless link from teh main menu where you will be able to see the relevent key and or change it if required.
    If you need the manuals you can download from here.
    http://kbserver.netgear.com/products/DG834G.asp
    Regards
    Nick
    Oct 28, 2008 | NetGear DG834G Router
    No access to internet via wireless or ethernet
    Check ADSL is active and connectted on the router.
    Use webmanagement link the link below.
    http://192.168.0.1
    username: admin
    password: admin
    If the above details does not allow you to connect, check under the router for correct details.
    Mar 11, 2008 | NetGear DG834G 802.11G Wireless ADSL...
    NetGear WGR614 Wireless Router Logo
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
