Question about Whirlpool MH1150XM Convection/Microwave Oven
REMOVING A RANGE MICOWAVE OVEN
TRY TO REMOVE MICROWAVE OVEN BUT SEE NO SCREWS. i HAVE CABINETS ON BOTH SIDE
    Problem Solver:
  • 12 Answers
Look inside the cabinets to see if there are any screws, as they act as anchor support, in supplement to the mounting bracket at the back of the microwave which supports most of the weight.
Posted on Jan 21, 2009
How do I remove a 1991 Roper over the range microwave. There are no cabinets above it that it would be screwed into.
If it is not mounted above, it is most likely attached to a mounting bracket behind the microwave. I would start with removing the vent cover (if there is one) and check for access to screws or bolts on the back side of the microwave. Make sure that you have a friend helping!
Some other tips:
http://www.ehow.com/how_4452966_remove-wall-mounted-microwave-oven.html
Jul 25, 2014 | Microwave Ovens
How do i ermove the oven from the wall (get to the back installation hardware)?
There should be Two very large screws that secure it from the top. These will be in the cabinets above the micowave.
Be very carefull when removing these, the unit will be heavy.
I hope this helps.
asnowman
Mar 05, 2011 | Sharp R-1610 Microwave Oven
Trying to change a fuse in ge microwave oven je2160. however, we can't determine how to find the old fuse and remove the cover
THE FUSE IS ON THE RIGHT HAND SIDE OF THE MICOWAVE AS YOU LOOK AT IT JUST AT THE TOP BEHIND THE CLOCK
Dec 25, 2010 | GE JE2160 Microwave Oven
How do I remove my Hotpoint microwave RVM 44004? Two bolts visible from the cabinet down into the microwave. Removed them with zero result. No other fasteners visible in top or side cabinets.
It is much easier for two people to remove the microhood. If attempting alone, please move the range out so you can get under the micro to support the weight. If the range stays in place, protect the top from damage.
1. make a landing site to the side to protect the floor when putting the micro down after removal.
2. Disconnect the power cord in the cabinet above.
3. loosen the two screws in the bottom front corners of the cabinet above. When removed the front of the micro will drop, be ready for the weight. Busy times, tools in hands microwave coming down in front.
4. tilt the front down. pull the cord out of the upper cabinet.
5. with micro still tilted down in front, lift the back of the unit upward to free it from the wall plate.
6. remove the fasteners in the wall plate and remove.
Congrats, begin celebration.
Jan 20, 2010 | Hotpoint RVM1435 Microwave Oven
How do we get an jvm59 GE Microwave oven out? The cabinet above appears to be covering the screws.
Sometimes older microwave ovens are built into the walls and are attached to the studs and mountings already in the house with cabinets built around them. Try taking off the paneling of your cabinets a little at a time until you can see how the microwave is attached. With any luck, it's held in by brackets underneath the cabinets and not attached to the studs in the walls.
Dec 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How to remove maytag microwave over the stove about 10 yr old
There is a considerable amount of weight to lower. It is an easier removal with the range pulled out and moved to the side. If you choose to move the range, be sure to protect the floor. Unplug the microwave. The plug should be in the cabinet above the range. There are two screws in the cabinet above that screw down into the top and support the front. These are the only fasteners that hold the machine directly. An assistant would be nice to have to help with the weight. While supporting the microwave, remove the two screws and slowly lower the front of the microwave pulling the cord out of the cabinet above as you go. Once the cord is free, tilt the machine down in front until the back can be lifted up off the plate that is fastened to the wall.
Jul 12, 2009 | Maytag MMV4205 Microwave Oven
Door wont open
After unplugging the microwave, I took the side/top panel off by removing the screws on the back*. Inside I found the piece that had broken off the part that pushes the door release. I then glued this piece back on using "Extreme Power" medium advanced performance instant adhesive. I bought this glue in a hobby shop in Richardson, Texas. I waited 12 hours for the glue to set. The door has been opening for the last two days.
*With the cover off, you can open the door by pushing the door release.
Nov 02, 2008 | Panasonic NN-C994S Convection/Microwave...
Sharp R-1450 micro over range removal
Those specific installation instructions are no longer available, but I have a couple for other models that may be close enough to help.
I have uploaded them here and here.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 21, 2008 | Sharp R-202EW Microwave Oven
Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Jan 31, 2008 | Microwave Ovens
Whirlpool MH1150XM Convection/Microwave Oven Logo
183 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
