Question about Motorola MC9190-GST
Change beam width - Motorola MC9190-GST
Headlight low beam on my envoy 2006 not working
The headlamp driver module (HDM) is an electronic module that provides electrical power to the vehicle low beam headlamps. The HDM is controlled by a pulse width modulated (PWM) ground signal from the body control module (BCM). The BCM determines the desired lamp intensity using the ambient light sensor, multifunction switch and the park brake switch as inputs. In general, the HDM will operate in 1 of 3 modes:
Reduced Intensity Mode: This mode is used by features that do not require or allow maximum low beam headlamp intensity such as daytime running lights (DRL) (nominal: 85% duty cycle).
Full Intensity Mode: This mode is used by features that require full low beam headlamp intensity such as low beam headlamp operation in manual or auto modes (nominal: 100% duty cycle).
Off Mode: This is the default mode of the system that will occur when none of the features described above are active. The BCM will deactivate its PWM output (0% duty cycle) during this mode.
The normal battery voltage input to the HDM must be between 6 and 16 volts DC to operate. Any deviation to these values could cause improper operation.
Major components of this system are the BCM, HDM, ambient light sensor, multifunction switch, park brake switch and low beam headlamps.
DTC B2575 Headlamp Control Circuit
When the body control module (BCM) senses a request for headlamp or daytime running lamp (DRL) illumination, the BCM sends a pulse width modulated (PWM) ground signal to the low beam headlamp driver module through the low beam headlamp driver module control circuit. The low beam headlamp driver module will illuminate the headlamps, adjusting the intensity based on the PWM signal received
You best bet is to take your vehicle to a ASE certified repair shop or the dealer >
Jan 15, 2016 | GMC Envoy Cars & Trucks
How do I narrow the scan beam on the n410
The scan beam is fixed and can not be adjusted. However moving the n410 closer to the bar code will reduce the width of the beam itself. The narrow beam is designed to accommodate static stands as well as manual use.
Simply hold the n410 a few inches away from the bar code and the beam will be able to read the code underneath. No adjustment except the distance between the n410 and the barcode is required.
Nov 24, 2014 | Computers & Internet
Fuse box diagram
No there is not, you either have a dual filiment bulb or a pulse width modulated system, if one works but not the oter you an bet it's the bulb. Also on the 11 Jettas try switching the bulb from side to side with the bulb housing.
Nov 28, 2013 | 2011 Volkswagen Jetta
Mc9190 laser beam width is too wide. I need to change the width of the beam. How can I do this?
Hello
Contact Motorola Solutions Get Support or Zebra Technologies
Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
Mark
Motorola Mobility Support
Apr 12, 2013 | Motorola MC9190-GST
I have a mfc-8440, 5 years old, low usage, 50% drum life, new toner cartridge. The problem is that the contrast of the printed copy does not change regardless of the setting using the path...
This is very easy to solve. Remove the drum and toner cartridge. Look into the machine where they sat. Now look up and you will see (a little aukward but its there) a glass plate the width of an A4 sheet of paper. Run your finger accross it. Look at your finger and will probably be dirty. This is the window the laser beam passes thru to hit the drum. When its dirty it does not allow enough ;light to the drum hence a weak beam and light printing.
simples?
May 18, 2011 | Brother MFC-8440 All-In-One Laser Printer
What was the year that the Slickcraft SS140 was built and what is the beam width?
this model was built in 1965 here is a link to the PDF artile about the history of the comapny if u are interested in reading it.
http://www.hope.edu/jointarchives/quarter/winter05.pdf
Not much info exists but the beam is stated in one article as 8'0"
Jul 20, 2010 | Boating
How do i change the bulb
Unscrew the bottom portion, where the batteries go. Then unsrew the top where you can adjust the beam width until it comes off. Very carefully pull the bulb out and replace the old bulb with the new. The Reassemble is the reverse of the procedure.
Jun 23, 2009 | MagLite RX3019 Rechargeable Flashlight...
Wedding Ring Fell Between Two Wooden Deck Beams
places like princess auto have thin really strong "super" magnets at low cost. fold a coat hanger or baling wire around it and go get 'er.....
Bye for now,
redd fraser,
phoenix rehousing.
Aug 15, 2008 | Computers & Internet
Motorola MC9190-GST Logo
309 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
