Question about Dymo LabelWriter 400 Turbo Thermal Printer
Dymo 400 laser turbo prints the label then multiple labels after that
  • Anonymous Feb 21, 2009
    I have the same problem, after printing 2 or 3 blank labels follow after that, tried the suggest fix but still same problem. Help
    Problem Solver:
  • 6 Answers
This is due to the print template you have chosen.
control panel > printers > right click dymo print icon > properties > press "printing prefrences" in General tab > click "Advanced" button in layout tab
Here you can choose the paper size. The dymo "shipping label" (30573) sold in most office stores is template number is "30323 Shipping".
Also these templates choices are available in the software you are using to print the labels under file -> print setup or whatever your software calls it..maybe "print setup"
Hope this helps.
Posted on Jan 23, 2009
My dymo 450 turbo prints only 1 label even i order to print 10 labels. I use mac(10.11.5) and dymo label(8.5.3). updated last version.
Double check that your using correct printer driver.
Completely remove restart computer with printer discontente,then reinstall the printer.
Jun 29, 2016 | Dymo LabelWriter 400 Turbo Thermal Printer
How do I get Quickbooks POS 10.0 to print Dymo Label Write 450 Turbo Labels?
I'm not sure you can actually print the labels from Quickbooks, but can print address labels, etc. to use with Quickbooks invoices, etc. you will actually have to print the labels from within the label software.
Nov 26, 2012 | Dymo LabelWriter 400 Turbo Thermal Printer
My Dymo Labelwriter 450 turbo feeds out 4 labels each time I print one. The print setting is on one label. The first one prints and the next three are blank. If I try to use the reverse button the printer...
Multiple label feeding usually occurs because the sides of the spool holding the roll are not squeezed tightly together. Make sure there's no gap between the labels and the sides of the spool. If this doesn't help. take out the labels and blow a blast of air into the feed slot. There is a sensor inside the slot on the left that detects the hole in the labels, and maybe it is blocked.
Jan 26, 2011 | Dymo LabelWriter 400 Thermal Printer
My Dymo Labelwriter 400 turbo will not print. The print error comes up and does not tell me what is wrong. When I take the labels out and reinsert them the labelwriter will not load I have to unplug the...
In most cases, problems are solved by checking whether the spools are firmly pressed against the label roll: This machine can be very picky. Many questions can be answered at the following site. http://global.dymo.com/enNZ/HowTo/LabelWriter_400.html
Chris Thrash
B52Computers
Jan 19, 2011 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo prints blotchy labels and feeds out many labels after print
Sounds like you have a couple of issues going on...your labels are incompatible or you have an incorrect template selected in the Dymo Software.
Check that the label model matches the template and you are using quality Dymo Labels. Such as the Dymo name brand or the LabelValue brand Dymo labels.
Apr 30, 2010 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo label writer 400 turbo will not print
Uninstall the software and disconnect the printer from your PC. Then reinstall version 8 of the Dymo Software (without the printer connected) and connect the printer when prompted by the software.
Make sure you are using version 8 of the dymo label software - it is compatible with Windows 7.
Apr 24, 2010 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo labelwriter 400 Turbo -We replaced the roll of labels and it keeps feeding with no stop
There are a few common reasons this is problem can exist.
1.) the incorrect template is used when creating the label
2.) the labels are installed incorrectly - the labels must be loaded and pushed against the left side of the printer and lid closed when printing to ensure the labels don't "wander" out of the sensor's view.
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view. Use quality Dymo labels.
4.) The labels are defective - if you have another roll of the same size, try it to see if it has the samme issue.
Oct 17, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
Lables i was loading has gone in but has not come out the front
When loading the label roll..place it along the left edge then press to button on front of the label printer once and dymo will **** it in. Now it's ready to print labels. Be sure to unplug the printer and plug it back in to avoid the common "printing error" message from windows.
Jan 22, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
My Dymo LabelWriter 400 Turbo stops printing after it has printe
Did you change the number of copies to print prior to printing?
Jan 16, 2018 | Dymo LabelWriter 400 Turbo Thermal Printer
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
Dymo LabelWriter 400 Turbo Thermal Printer Logo
700 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
