Question about Bosch Washing Machines
Bosch Maxx Washing machine WFL2260
Flashing END red light, what does this mean.
  • Bosch Master
  • 3,463 Answers
On most washers, this usually means, end of prog, and you should be able to remove washing.
plz rate my comments.
TYhankyou.
Posted on Jan 21, 2009
Where is the filter on Bosch Maxx WFL2260
should be a round cap in front, remove it filter in in front , unscrew counterclock wise. it s the filter
Jun 03, 2011 | Washing Machines
I have a Bosch Maxx 1000 Washing machine and it seems to be stopping just before spin dry and flashing end. Door won't open so I need to turn to spin or drain to complete cycle. Today the spin cycle...
this is because the water can't evacuate . check the pump trap filter and make sure there are no blockages. you will probably find water still i the machine when this happens. There might be a blockage up in the hose pipe before the pump. Good luck
Jan 22, 2011 | Bosch Washing Machines
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
Bosch maxx wfl2260 wont spin or drain
there will be a blockage in your "fluff" Filter cap. i could not get mine open so what i had to do was unplug the washing machine disconnected the filter from the waste and the blockage pipe and the electrics and found a bra wire i pulled it out with some long nosed pliers then the cap came off i cleared it all out connected it all back together and it worked good as new
Oct 11, 2009 | Bosch Washing Machines
Need instruction manaul for bosch wfl 2260
Programmes appear to be taking excessively long time to complete even with the quick wash button pressed - 2 hour 15 min for 30 Cotton wash cycle. Is this right or is there a fault? 30 Easy-care seems to be taking almost as long.
May 17, 2009 | Bosch Washing Machines
Fabric softener usage on quickwash
most likely normal operation .. try a normal or heavy cycle if it works there consider it normal operation
Nov 27, 2008 | Washing Machines
Bosch max wfl2000 washing machine
Just been through this with our Bosch Maxx, problem was the pump discharge pipe was blocked with soap deposits. I also removed the large black rubber pipe from the drum/pump and cleaned this out as well.
All working fine now.
SteveN
Sep 08, 2007 | Washing Machines
Washing Machines Logo
542 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
