Question about Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Washer leaks from the door
From day one my washer has leaked from the bottom of the door panel. the tech has been out twice now to fix it. First he tried to blame the soap. I showed him I was using the HE soap with the recommended amount needed. Then I showed him that it leaks even with no soap or clothes in it( I ran the clean washer cycle). The next time he replaced the seal and again said I was using to much soap....I use two tablespoons of HE soap as he recomennded the last time he was out. Still it leaks. I financed this washer and am ready to tell the furniture store where they can shove it if they can not fix it...oh did I mention it sounds like a freight train walking through the house. The furniture store nor the repair man seem the least bit concerned that this thing not working properly is ruining my floor!
  • Whirlpool Master
  • 3,463 Answers
Make sure the transit brackets and screws have been removed.
Other than that,I would say it needs a new door, as it is possibly twisted, and not closing tightly enough against the door seal.
Plz rate my suggestions.
Thanks.
Posted on Jan 21, 2009
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool duet washer error codes
Each one of these washers comes with a technical data sheet inside the cabinet which includes in depth troubleshooting tips.
In order to access, you will need to locate and remove the screws under the bottom front edge of the toe panel under the door. Once the screws are removed, the panel will drop down, then come off. If the tech sheet isn't located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all error codes, test points, diagnostic procedures and helpful illustrations to assist in troubleshooting and repair of your washer.
If you have any questions, or require additional assistance, please post back and let me know. I hope you find this information helpful.
Oct 21, 2010 | Whirlpool GHW9150 Duet Washer
Water seeps into Whirpool Duet washer
If your washer is leaking water when it is not in use, the following link explains how to troubleshoot to isolate the cause:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
The problem is either attributed to a defective pressure switch or a water inlet valve that is leaking by. The link I provided will explain how to determine which one.
If you still require assistance, please let me know.
Jan 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front loading Whirlpool Duet Washer leaks from bottom of machine
If the washer only leaks during the spin cycle, you may have a worn door bellow (rubber seal). As the washer spins, the centrifugal force of the tub can spin the water into the door area. If the seal is torn, it will leak out of the bottom of the washer. You will need to inspect the perimeter around the door to ensure the seal does not have any rips or tears. To be sure, you need to remove the lower toe panel under the door and inpsect the washer thoroughly. The following link explains how to access the interior of the washer cabinet and how to inspect for leaks:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
The door bellow DOES wear out with age, but if you have a tendancy to overload the washer it can contribute to premature wear. If you determine that the bellow requires replacement, the following link explains how to replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If you have any questions, please let me know. I hope I've given you enough information to help you find the source of your leak.
Jan 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaking water
If the washer is leaking around the door area, more than likely the bellow (rubber seal) is ripped or torn. If you pull back the rubber folds in the bellow and inspect, you may find a rip or tear causing your leak.
Another cause can be the rear bellow clamp (clamp that is affixed to the front of the wash tub) can come loose causing a leak between the bellow and tub. All you may have to do is tighten the clamp if this is the case.
The dispenser tube on the left hand side of the door, if not seated through the rubber correctly, can also leak during the fill or rinse cycles. The tube should be inserted through the rubber in the bellow to the flange on the tube. If not, water can fill behind the rubber and drip into the bottom washer casing.
The following link explains how to access and/or replace the the door bellow on a Whirpool Duet:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com and repairclinic.com carry the bellow. All these sites offer competitive pricing, so shop all of them for the best deal.
If you have any questions, or require addtional assistance, please let me know. I hope this helps you. NOTE: The bellow can also become mishapened over time after frequent use. This can also cause leaks around the door. Look to make sure the bellow is sealing around the door glass. If not, it should also be repalced.
Jul 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaking from door area
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Sport Washer still making noise now it s leaking
make sure to look really close all it takes is alittle whole in that seal anywhere to cause a leak try to look close while it is running but first dry everything you can and then run it. also make sure your door glass is clean if it is leaking down the front just alittle dirt or hair can cause a leak aswell
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water on my floor
Is it the bottom or coming out the door at the bottom? When your seal is bad it will leak, mine leaks only on handwashables and delicates. I have had to have my seal replaced twice in the three years i have had one, and the last seal was not put on right and leaks.
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Front Loading HE (GH9400PW4) washer is leaking! Hellllp!
remove the bottom acesss panel and run through drain/spin cycle youll see where the leak is then. perhaps debis has puntured drainline hose or pump housing is leaking
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Front Loading HE washer is leaking! Hellllp!
hi there i would check the softner part of your soap drawer first for blockages, you can let me know
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
101 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
