Question about GNC Talking Bathroom Scale
How do I turn on a gnc talking scale - GNC Talking Bathroom Scale
Goes to 88888 no matter what. How do I fix that?
Are you over 330 pounds? If not, remove the batteries and count to 10 and replace them.
Description Item # 00835165000P Model # 4GNC25302 The GNC WirelessWeight GS-7006 Digital Bathroom Scale accurately measures weight, body fat, water hydration, bone and muscle mass. This item features a removable wireless display that can be conveniently mounted on the wall, so you can see the readout clearly. Built with durability in mind, the scale is made from extra-strong tempered safety glass. The GNC bathroom scale also features an energy-saving auto on/off function and auto zero.
  • Removable wireless wall mount readout display
  • Measures weight, body fat, water hydration, bone and muscle mass
  • Energy-saving auto on/off and auto zero
  • Extra-durable tempered safety glass
  • Weight capacity: up to 330 lbs
  • Requires one 9V and 2 AAA batteries (included)
Apr 28, 2016 | GNC Digital Bathroom Scale
How do i reset my digial bathroom scale
Remove all the batteries. In ones with memory, there are two sets, a 9 volt and 2 x AA.
Jul 16, 2015 | GNC Digital Bathroom Scale
GNC On the Go Blender
these have a fusible link in line with motor normally
you will need a multi meter
Aug 17, 2014 | GNC On-The-Go-Blender - Red 6 Piece Set
How do I set up the GNC ProTrack GF-0008 Digital Pedometer Plus Body Fat Monitor:
I just won one from GNC and not sur if it is working properly, because screening is flashing in some type of error mode. removing battery was only way to reset.
1. First normal screen is the time display. (only shows 3 numbers.)
2. Press "set" then up/down for correct time.
3. after setting time, press up/down for 12h/24h format
4. Press "mode" & NO 1 flashes, showing Wt 50 Kilo & Man
5. Press "Start" and place one thumb on each end of unit to auto-read body fat.
6. Set weight in Kilos (not sure how to convert unit to lbs, before setting, so maybe use online converter.
7. Set ht, age, man/woman, stride, using up/down arrows.
Follow process for users 2-5,
Mar 07, 2013 | Generic GNC ProTrack GF-0008 Digital...
Scale not working since I replaced the batteries
  • My scale no working I replaced the batteries
Mar 05, 2013 | GNC Digital Bathroom Scale
Where can I buy protein bars online?
bodybuilding.com and gnc.com offer all kinds of protein bars. Check out these links: http://www.gnc.com/family/index.jsp?categoryId=11839529 and http://www.bodybuilding.com/store/bars.htm. I personally order from bodybuilding.com all the time and really enjoy their service. GNC offers free 2-day shipping, so they're a good choice as well.
Jan 24, 2013 | Health & Beauty
Pro-form 10.8x
If your talking about the wire harnesses connecting the main body thru the console tower to the upper console. May I suggest going to the iconservice.com click on manual input the manufacturer and model name and select your unit you'll be able to download in PDF format of your owners manual. You can enlarge the section that talks abut this procedure and give a little better viewing of the diagram. The connectors will only fit on one way this made for us visually impaired Technicians. Hope this helps
May 17, 2010 | Proform GT 85 x Upright Bike at GNC
GNC Talking Bathroom Scale Logo
50 people viewed this question
Top GNC Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
ray gallant
Tom Chichester
Are you a GNC Exercise and Fitnes Expert? Answer questions, earn points and help others
