Question about Home Security
When do security lights know to turn on? - Home Security
    Sergeant:
  • 248 Answers
Light sensors that check for daylight and infrared detectors to activate.
Posted on Jan 10, 2013
    Guru:
  • 269 Answers
It depends on the model and type but most have a motion sensor to detect movement.
How do I reset the security system on a 2001 Oldsmobile Aurora
If the security light is on you can try the 10 min. relearn procedure . Turn the key to run ( not start ) an leave the key on for ten min. If the light goes off in ten . min. turn the key off . Then start the vehicle . If the security light doesn't go off there is a hard fault an you will need to have it diagnosed by a repair shop that knows how .
Jun 21, 2016 | Oldsmobile Cars & Trucks
I have a 98 buick park avenue and it turns off after crancking up the security light comes on. how do i reset the computer i think that's the problem but i dont know how to reset it
The Security features are installed into the ecu at the dealership. you can unplug the battery for 15 minutes and then re connect them this resets sensor codes and such but im pretty sure that your problem will still persist. i know for a fact that even if you replaced the ecu the security features will not let the vehicle run without pairing the new ecu with the existing security features.
Jan 29, 2013 | 1998 Buick Park Avenue
Security light flashes as you turn ignition key on and car won't turn over
if that has a chipped key for the security system,try another key,that will let you know if its a bad key or the reader is screwing up.
Nov 14, 2012 | 1994 Buick LeSabre
Security light not coming on
At the year of this vehicle, I would propose that your dashboard light bulb for the security light might be burned out. Turn your key till just before your starter kicks in and for just a few seconds every one of your lights on your dash will turn on. If that particular light does not come on then you know what to do.
Good luck,
Phillip
Dec 27, 2011 | 1992 Cadillac Seville
My 2001 grand am will not even turn over
If you notice that the security light is on, that is a common issue with pontiacs. My mechanic told me that my security light was going to start giving me problems. The security light can stop you from starting your car for x amount of time. I was told that it is an easier solution just to disable the security than to get it fixed.
Dec 20, 2011 | 2001 Pontiac Grand Am SE
Security light stays on. IT took four attempts to get car started and security light remains on.
It helps to know what kind of car you have even the year makes a difference GM cars with the chip in the key have two small white wires coming off the lock cylinder that break. Then you need a lock cylinder rekeyed to your old key. The code is in the chip. Newer GM cars can go though a security reset that involves turning the key on for 5 minuetes or more after a try to crank and the light goes out then turn the key off wait a second or two and turn it back on, the light will come on , in about the same amount of time the light will go out and again turn the key off then back on light on wait again then this time when the light goes out turn it off then back on and start the car the light will come on and the cars running with out a security proble it'll go right back out . This will happen if the car doesnt reconize the key and repeated attemps are made to start the car with the wrong key that just happens to turn the lock. As you found out if you try it enought with the right key it'll start and the light will stay on
Aug 13, 2009 | Vehicle Parts & Accessories
Security light is flashing on 03 grand am
Everything you need to know is on this link
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Mar 26, 2009 | 2003 Pontiac Grand Am
Security light blinking
You can beat this yourself. This link explains why the problem exists, and how to fix it yourself.
Oct 15, 2008 | 2000 Pontiac Grand Am GT
Security light came on
hello on GM car. Some you have to put the key in the ignition turn it on so all the lights on the dash are on. Leave it on for 10min. do not turn the key off after the 10min. just start let run 1min then shut it down cycle the key again the light should be off let me know. thanks
workitover
Jul 26, 2008 | 1994 Oldsmobile Cutlass Supreme
Home Security Logo
443 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
