Question about Building Materials
Where can I buy a new front door for my house in Newton, Mass?
    Guru:
  • 269 Answers
Here's a website with a bunch of different places to get and install new doors:
http://www.homeadvisor.com/tloc/West-Newton-MA/Doors-Exterior-Install-or-Replace/
Posted on Jan 10, 2013
Write a pseudocode declaration for a string array initialized with the following strings einstein newton
the nice thing about pseudocode is that there's many ways to do it
E.g 1;
String str = new Array["einstein',"newton"];
E.g 2;
myStringArray = new Array{'einstein','newton'}
BOTH of the above are correct, because they are pseudocode
Oct 19, 2014 | Computers & Internet
Where can I get hours grooming supplies in Newton, Mass?
I suggest Petco or Waban Pet Center.
Feb 04, 2013 | Equestrian
Dual mass flywheels
for light vehicle, recommended torque is 45 newton meter and an additional 3/4 turn of the wrench and for 6 bolts tightening sequence should be 3 by 3 as star delta.
Feb 22, 2012 | 2005 Renault Laguna II
Change thermostat on 2004 chevy impala?
first you need drain engine coolant down below thermostat. what engine type 3.8 or 3.4 need to know.the 3.8 engine thermostat housing on top intake follow top radiator hose to thermostat housing.the 3.4 engine you have to remove air filter housing with air inlet duct with mass air flow sensor.you have to remove throttle body with coolant hoses.go to auto parts store buy new throttle body hoses old ones will be hard to remove might have to cut two small hoses also buy new throttle body gasket also. before you can remove throttle body unit you have to remove accelerator cable and downshift cable from bracket bolted to throttle body.once throttle body remove then you can remove thermostat housing bolt remove replace thermostat.
Nov 11, 2011 | 2004 Chevrolet Impala
How do I convert 200N to kg
The problem here is that N (Newton) is a unit of force and kg (kilogram is a unit of mass) .
I Newton is the force required to accelerate a mass of 1 kilogram at 1 metre per second squared.
However the non SI unit kilogram-force is the force of 1 kilogram being acted on by earths gravity and is the equivalent of 9.80665 Newtons.
So the best answer to your question is 200N equals 20.27 kilogram-force.
Aug 16, 2011 | Office Equipment & Supplies
Water leaking out of the bottom of the pump - low pressure leak, light stream
Will be a gasket, o-ring or seal that has blown. Could even have a cracked fitting or a split hose.... remove housing where leak is coming from and inspect. call service part agent and order new part (make sure you grease seal or o-ring with rubber grease. If it is a gasket you may need to use a gasket sealant and find out what the torque setting are for the component you have disassembled.
General quide is: 10mm head = 10 - 12 newton meters 12mm Head = 18-20 newton meters
Hope this helps... hard to diagnose accurately with your vague description
Feb 10, 2011 | Karcher 2500 PSI Pressure Washer
2002 ZX-9R: what are the torque settings for front and back wh...
Hi
Both front & rear axle nuts should be torqued to 125Nm (newton/metres) & the front wheel clamp bolt should be 20Nm
Ride safe
Bike-Doc
Please mark this as very helpful (if it has been!!)
May 06, 2010 | 2002 kawasaki ZX-9R
No reception in our house
the reception quality around your house has dropped, probably because of new high rise buildings in the area or trees interfering with the reception. Best option buy a network booster to improve your reception quality.
Sep 28, 2009 | Motorola Mobility i880 Cellular Phone
Large inside rubber seal torn for the third time
new boot or "bellow" is $116 and you could do it yourself. some older front loaders had this problem. the larger the gap opening to its lower trench the more it collects. would not recommend tranditional top loader as these are being phased out. if you must buy a new machine- recommend other than whirlpool, front load (buy GE, or LG)
Mar 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Building Materials Logo
680 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
