Question about HP PSC 2210 All-In-One InkJet Printer
Need the two top cartrige latches for hp pcs2210 series (C8654A)
I need the two top cartrige "LATCH CATCHES" for my printer hp psc 2210 series (C8654A) VERY URGENTLY. Im desperate. PLEASE HELP !!!!!.
  • Johan Jan 17, 2013
    Please, I still need the two top latch catches for the carriage of my printer, that keeps the cartridges in position. "VERY URGENT" Hp psc 2210 series. (C8654).  The label sticked on back of my printer read as follow: MY2CNF71SJ.
  • 883 Answers
SOURCE: hp 5550
try searching for an AS-IS item on ebay to use for spare parts.
Posted on May 31, 2007
IB4G2008
  • 3587 Answers
SOURCE: help on an hp psc 1350 printer... the printer wont read the inc cartrige
hmm...can you isolate it from the computer, and attempt to do a test page from the menu?
Posted on Mar 30, 2008
SOURCE: need to install printer HP PSC 1500 all-in- One series
i lost the software of psc 1500 all-in-one can you help me?
Posted on Nov 14, 2008
SOURCE: How do I install the new cartridge latch (color) of my HP PSC
You will need a small TORX screwdriver (star shape) to remove 3 screws.
see my post @ techtalkz.com/hp/124170-hp-psc-2210-cartridge-latch.html
Posted on Nov 19, 2009
I am looking for a color access door for a print carriage on an hp psc2210 all in one printer. (C8654A)
  1. If you are putting in a new cartridge, make sure to remove the tape.
  2. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  3. Fit the cartridge into the proper carriage.
    • The carriage with the gray latch is for the black ink cartridge (HP 56), or the optional photo cartridge (HP 58).
    • The carriage with the blue latch is for the tri-color cartridge (HP 57).
    Slide the cartridge into the carriage at a slight angle, as shown in the illustration above. When the cartridge is fully inserted into the carriage, rock it upright.
  4. Hold the hinged flap of the latch out while lowering the latch.
  5. When the latch is fully lowered, release the hinged flap. It should catch under the tabs on the carriage, as shown in the illustration.
  6. Close the cartridge access door.
  7. The LCD display may indicate that the cartridges need to be aligned. Press Enter on the front panel. You may discard the alignment page that prints.
Remove cartridges
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of each ink cartridge latch and pull the lower section of the latch out to release the cartridge.
  3. Pull the cartridge out of the print carriage and relatch the empty print carriage. The print carriage may move to the right automatically, and if the latch is up, it could be damaged.
Aug 23, 2011 | HP PSC 2210 All-In-One InkJet Printer
How to change ink cart. in hp psc 2210 all in one printer
  1. Turn on the unit, then open the print cartridge access door. The print carriage moves to the center of the unit. Never attempt to move the carriage by hand.
  2. Press down lightly on the top of the ink cartridge latch and pull the lower section of the latch out to release the cartridge.
  3. Pull the cartridge out of its holder.
  4. Carefully remove the protective tape from the new cartridge.
  5. Reinsert the new cartridge into the carriage at a slight angle. When the cartridge is fully inserted into the carriage, rock it upright.
  6. Hold the hinged flap of the latch out while lowering the latch.
  7. When the latch is fully lowered release the hinged flap. It should catch under the tabs on carriage.
  8. Close the cartridge access door.
  9. The LCD display may indicate the cartridges need to be aligned. Load paper and press "Enter" on the front panel.Discard the alignment pages that print.
Feb 01, 2011 | Office Equipment & Supplies
Catridge latch broken. Can one replace or buy a new printer?
If tghe cartridge latch is briken, it seems to be the machenical issue with the printer, in that case it is worth buying a new printer and if you want to go for an HP unit, you can log on to the chat support of the printers and ask for the discounts on teh new printer as compared to the stores.
May 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
its better u call hp support at 1800-477-6836 & ask for an upgrade u will better printer but in good cost, though it will refurbised. but dont tel them that Catridge latch broken.
Mar 30, 2010 | HP PSC 2210 All-In-One InkJet Printer
Where can I buy the cartridge latch that hold the ink cartridge in place for a hp psc 2210 all in one printer
You will have to probably buy the whole assembly it will cost a lot. Try to find a used broken machine or partsurfer.hp.com will be your best bet. Steven 818-888-0006
Mar 06, 2010 | HP PSC 2210 All-In-One InkJet Printer
Jan 21, 2009 | HP PSC 2210 All-In-One InkJet Printer
Remove and check print cartridge
Remove the cartridges and check them. If faulty, replace them.
Sep 19, 2008 | HP PSC 2210 All-In-One InkJet Printer
Kindlly assist hp 2210 problem narrow paper
you have to go to the menu and change the settings , try the DEFAULT setting . also do you have the printer connected to the PC ?
Apr 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
Ben Johnson
