Question about Baby Gear
Model number 03-528-PGH - Baby Gear
Gracceford will be confirmed.signature:Todd Slow
how can i enter my code W0343
Dec 31, 2011 | pch.com
Driving back from harrisburg, pa to pgh, pa., check engine light came on, hope i make it home, car seems to be running ok so far.
Next time you stop, go to a close parts store and have them pull the codes. Could be that you didn,t tighten the gas cap enough. this would be an EVAP code
Jan 22, 2011 | Mercury Cougar Cars & Trucks
Hi! Our gun trigger is not working right on Model
Lowes and home depot sell replacement guns for most smaller pressure washers.
Jul 29, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
Can't load software
If you can borrow a Microsoft full install CD for the version of Windows that came with your machine, you can do a fresh installation using the product key from the sticker on the computer. You will need to download and install hardware drivers from HP's site and also go through the Windows activation process yourself. This will give you a working computer with Windows, but none of the other applications that came preinstalled. (This isn't always a bad thing. HP systems come with a lot "bloatware" preloaded that you can live without anyway.) Unless you paid extra for an application like MS Office, you won't be missing anything.
Mar 20, 2010 | HP Compaq Presario SR1520NX (PX801AA) PC...
I have scratche in the hodd from love bugs in
Hi if your in the UK about £140 its normally £100 a panel but this depends on colour and type of paint used. certainly dont pay any more than £150
Regards
Dan
Feb 01, 2010 | Kia Sedona Cars & Trucks
What is the difference between Porter-Cable air compressor models that have a type 1 or type 2 behind the model#?
When searching for a tool or machine part at eReplacementParts.com, the product's model number and type number are always necessary to ensure an accurate part match. Even when a model or type number is only different by one digit, the parts for that model or type may not be compatible with other models and types.
Each manufacturer uses a different model and type number system, and manufacturers often call type numbers by different names. Some type numbers are especially difficult to find on the tool or machine.
This article provides explanations and pictures for finding model numbers and type numbers for several tool and machine brands, making it easier to order the right part for the right tool.
Explanations are listed below alphabetically by brand, but first, some additional information about model numbers and type numbers will be helpful.
Model and Type Numbers
Model numbers distinguish a manufacturer's models for a certain kind of tool within a given tool category (like drill/drivers and nailers). For example, two different power sander designs from the same brand would be distinguished by having two different model numbers. This is true for every b rand, that they separate major designs by model number.
However, manufacturers often update the design or features of a tool model, creating types of tools with the same model numbers. Most manufacturers distinguish the different types of a tool model from one another by assigning type numbers to them in addition to the tool's model number.
This is where it gets tricky. Finding type numbers for tools can be difficult because of the following reasons:
  • Type numbers can be very different from brand to brand. Sometimes an entire type number is just one digit or letter, and sometimes type numbers are very long numbers or long combinations of letters and numbers.
  • "Type numbers" go by different names, depending on the manufacturer. Some manufacturers call them type numbers, while sometimes they are called the: engineering number, series number, or bar code number.
  • Some model types are only distinguished by the year of the model.
  • Type numbers can be very difficult to find, sometimes located on the inside of a tool's housing (like some Ryobi tools). Fortunately, most type numbers are listed on the name plate with the model number.
  • When a manufacturer does not anticipate redesigning a tool or machine model, the first type of that model often does not have a type number assigned to it by the manufacturer. Designs that follow the first type will usually have type number designations.
  • Some manufacturers do not use a type number system at all, and instead change model numbers for each new design. In this case, the model number is the only number needed to match the right parts to the tool or machine.
In general, when searching eReplacementParts.com for the right model number and type number of a tool, the most important idea is just to match all numbers displayed on the webpage (under that tool's picture and name) with the numbers on the product.
On eReplacementParts.com, type numbers are displayed under the tool picture to the right of the model number. Sometimes type numbers are displayed in parentheses, like "(Type 1)" or "(0601916460)". Models that are not assigned type numbers will not have a type number displayed on the web page.
However, we will often list "Type 1" or "Type 0" for the first redesign of a tool model in a type series, even if the manufacturer does not list "Type 1" or "Type 0" on the name plate. This makes it easier for our customers and us to tell the first type apart from the rest.
Jan 19, 2010 | Porter Cable Air Tools & Compressors
GREEN PICTURE
sounds like one of the tubes is gone. RGB stands for red green blue. These colours are mixed together to make all the other different colours on your tv's picture. when one goes then you end up with whats left working.If tv is fairly old chances are its cheaper to replace then to try getting fixed. tv's have came down drastically in price lately because of such high demand and competition to the market.
May 16, 2009 | iLO IWT3206 TV
How difficult is it to replace the magnetron? I can get the part for free but to repair it costs more than a new one.
It's not difficult to replace the magnetron. Only 2 to 4 screws hold it to its bracket (depending on model) and there are only two wires connected to it. The biggest problem sometimes is removing the cover. Many models use security screws to keep people from opening them. Also there are hazardous voltages that may be present even a good while after the unit's been off. But if you can open the oven, make good notes (or take a camera phone picture) about what went where if you have to take off any parts, and exercise some care, you can change the tube yourself.
Are you sure the part you're getting for free is good, and is a suitable replacement for the original?
Dec 19, 2008 | GE JE1640 Microwave Oven
Can't close an umbrella stroller I purchase
i dnt kno how to close this stroller
Oct 09, 2008 | Baby Gear
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
