Question about Jamo SUB 200 Subwoofer
Schaima elektonic jamo sub 200 - Jamo SUB 200 Subwoofer
5 Suggested Answers
  • 127 Answers
SOURCE: my jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
Posted on Mar 03, 2010
  • 137 Answers
SOURCE: Jamo Sub with no power
THE IS A FUSE INSIDE THE UNIT,YOU MAY WANT TO CHECK THAT.IF IT BLOWS AGAIN WHEN TURNED ON YOU HAVE SHORTED MOSFETS. THEY ARE LIKE TRANSISTORS.
Posted on Apr 20, 2010
  • 142 Answers
SOURCE: The fuse of Jamo Sub-200
blown fuse indicates that current drawn is more then fuse's limit. there may be integrated ic failure or any other short circuit in amplifier. u need to check with a multimeter where is the short circuit.
Posted on Aug 26, 2011
  • 28 Answers
SOURCE: i have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
Posted on Sep 13, 2012
I brourt a jamo sub 200 and five a102speakers but
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Aug 31, 2014 | Audio Players & Recorders
Hi My problem is that my Jamo 200 sub sounds very
Is everything hooked up correctly sounds off I know also could be your amp is going on you cold be a multitude of problems or one of the simple ones i stated
Oct 26, 2013 | Jamo SUB 200 Subwoofer
I have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
Sep 13, 2012 | Jamo SUB 200 Subwoofer
I want jamo sub 1810 circut diagram
Check out this link:
http://2getdtv.com/directv/stereo_receiver_codes.html?phpMyAdmin=ed9585cdc5a4551847999cb4dbcce76a
Feb 22, 2012 | Jamo SUB 1810 Subwoofer
The fuse of Jamo Sub-200 gets blown off. is there anyone who might know the reason. thanks
try replace the blown fuse with ampere and check the sound if still ok.
some fuse got blown if the load current exceed. maybe high volume can cause the high current.
other cause by short circuit coming from the amplifier.
Aug 26, 2011 | Jamo SUB 200 Subwoofer
I have jamo sub200. I connect to pioneer vsx-rs320k audo video receiver. when I turn the volume of subwoofer to a higher value with the receiver, the bass sound becomes distorted and not satifieng to...
hi,
Do one thing set the control behind the sub. set the level and cutoff control at it half position. Set phase control at "0" position. Then test the sound. if you ate using tower speaker as front speaker then you have to set the position of phase control 180 ,
ok
Apr 11, 2011 | Jamo SUB 200 Subwoofer
My jamo sub 200 & pioneer vsx517 receiver is not working properly
Feb 08, 2010 | Jamo SUB 200 Subwoofer
Why is there 2 line in.left and right. and there is only 1 cable to plug in to left and stright to amp
YOU NEED TO PLUG THE RCA INTO THE SUBOUT FROM THE AMP,THUS YOU ONLY USE 1 CABLE FOR THE SUB
Jul 30, 2009 | Jamo SUB 200 Subwoofer
Jamo 250
hi, there must be this LINE IN socket (ur so called Hole), then on the onkyo, there must be this sub-line out socket, plug one end of the RC socket to the sub out of onkyo , and other to the line in of the sub, its all to do wirth its appropriate inputs and outputs,let me know
Jan 11, 2008 | Jamo D 4SUB Subwoofer
Jamo SUB 200 Subwoofer Logo
Top Jamo Audio Players & Recorders Experts
Electro Med Services...
Tom Chichester
 Grubhead
Grubhead
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
