Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
E402blw gurgling sound - Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Gurgling sound in the cab
Well yes and no. The gurgling sound is air in the cooling system moving thru the heater core. The cooling system is not full of liquid coolant.
As for the cause of the coolant loss, if you fix the external leak and you continue to loose coolant, the head gasket could also be leaking.
Feb 06, 2014 | Dodge Cars & Trucks
Freezer gurgles
    • Give it mouth wash lol
      Check the water valve on the back of the refrigerator if it has an ice maker. Make sure the valve is turned completely on and not constricting the flow of water to the refrigerator via the water supply line. You might also hear a simultaneous buzzing sound when the gurgling noise occurs. In some refrigerator models, this filling process is on a timer, and you might hear the buzzing and/or gurgling every 15 minutes or so.
    • Check the water supply line for leaks or damage. You might see a puddle of liquid on the floor. If air is pulled into the water line as the refrigerator is pulling in water, that can create a gurgling noise. Replace the damaged hose yourself, or contact an appliance repair technician for assistance
      • f he refrigerator to feel a slight vibration. This is probably the compressor processing the refrigerant, which is a liquid. This flow of refrigerant can produce a gurgling sound, and it is normal. However, a simple way to reduce this noise is to make fewer trips to the fridge. When you open the door, you let hot air in, which means the compressor has to work harder (and gurgle the refrigerant more) to cool things back down.
    • Wait while the refrigerator completes its defrosting cycle if you hear water dripping and gurgling in the freezer area. When the heating coil turns on, the melted water from the frost flows down to a drain pan for evaporation to take place. The defrost process usually takes about 30 minutes. This is automatic and cannot be prevented in most refrigerators. Keep the closed to try to prevent unnecessary frost buildup.
    • Wait while the water equalizes in the refrigerator if you hear a gurgling sound when shutting the door. This is normal and is a result of air being forced through the drain tube. The gurgling can last several seconds but should eventually dissipate this usually happens with old fridges upgrade its a good investment
Dec 10, 2013 | Freezers
My culligan water filter makes a gurgle sound
The reverse osmosis faucet you have incorporates an AIR GAP to prevent cross contamination to the RO system. The waste water first goes up the to RO faucet AIR GAP and then goes to drain. The "gurgling noise" is the waste water going to drain. Some of these are much noisier than others.
RJ
Jun 10, 2010 | Culligan Under Sink Water Filter
Our pool is gurgling and the water level seems low. what should we do.
Add enough water to bring the level halfway up the skimmer. Sounds like it's sucking in some air with water and that's what is causing the gurgling sounds.
Mar 26, 2010 | Pool & Spa
Toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
Jan 23, 2010 | Toto Aquia II Dual Flush Toilet
When I open and close the freezer door there is a gurgling sound
The gurgling sound , is the vacuum being pulled thru the defrost drain line . Like when you close a freezer door , and you see the gasket being pulled in tighter . This gurgling , is the drain p trap with a vacuum being pulled thru it . Normal .
Sep 25, 2009 | Kenmore Refrigerators
Gurgling sound
the gurgling noise is the water going into the base. since you haven't used it in so long your going to hear some weird noises at first then they should go away. but before using it make sure that all dust particals and everything is cleaned. if you have any more problems please let us know.
Jan 27, 2009 | Bionaire W9U Humidifier
Sub-zero 650 makes loud gurgling sound
gurgling is not unusual and is caused exactly by fluid bubbling thro a pipe.
Nov 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
41 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
