Question about Samsung BlackJack II Smartphone
Black jack 2 phone charger wont stay in the phone
If I plug my charger into my phone it does not work, I have to put something on my phone to hold the charger in and than anchor the phone down.
  • Anonymous Apr 21, 2009
    I have the exact same problem. My Blackjack 2 is only about 3 weeks old and all of a sudden, the charger won't stay in. Well, it will stay in, but not well enough to keep a connection. I have to hold it at an angle so that it will connect...but there's no way I can sit around and hold it the entire time it's charging.
    President:
  • 625 Answers
Return to the carrier for warranty repair.
If you are out of warranty there are some options you can choose from
1. Get repaired
2. New phone
3. external charging source
The external battery charger runs about 20 dollars on ebay with an extra battery.
Check out the following link to find more about these options
Samsung BlackJack II charging problems
Posted on Jul 27, 2009
Mophie charger plug wont stay in
I had the same issue. I was able to trim the cable shell to get it to insert further and take better hold. I suspect some cables may work better than others but the design is poor as they have the jack on a curved corner. Had they angled it a little it would work better and actually work. They should also include a screen protector for the price. The case scrapes off standard protectors because of the tight fix, though the tight fit is good. I actually love the product though as it actually works. Just not enough real world testing.
Jan 20, 2014 | Apple iPhone Smartphone
Hi Mine is a iPhone 3GS 16gb it will not charge nor turn on when I hold down the on off button nothing happens but when I plug in the charger and hold the on off button it shows the charging sign which...
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 31, 2012 | Computers & Internet
My Nextbook wont turn on
Although it is not recommended for normal operation, try turning it on with the charger plugged in. If this works, check the battery status indicator. If it shows a full charge, try disconnecting the charger. If the Nextbook quits working, the battery is bad.
If it does not turn on, try holding the power button for five seconds, then while holding the power button on, plug in the charger and continue holding for five seconds. If nothing happens, release and press the power button again with the charger still plugged in. (This may reset the internal power management chip.) Also, try the recessed reset switch (see your owner's manual).
If none of this works, verify that the charger unit is good. The simplest and safest method is to measure the output voltage on the output plug with a digital multi-meter while the charger is plugged into an AC outlet. It should be within 5% of the nominal output voltage on the charger label.
The most common power problems are battery failure, broken charger wire (usually next to the plug or the power conversion box), or broken charger jack in the unit.
Jan 10, 2012 | Office Equipment & Supplies
H wont turn on.when i put the charger in and turn on the power power light stays on .can here something working inside but nothing happens
Possible that there's some power glitch on the board.. what you can do it to take the battery out and disconnect the charger, once done press and hold the power button for at least 2 minutes, it would drain the excess power on the board.. then after doing so plug the charger and test if system would turn on..
hope this helps..
Apr 14, 2011 | Computers & Internet
I got a short or something wrong the phone wont
change your charger 7 if that doesnt work . your board mey be bad , unfortunately , you may have to buy a new phone . if you would like to know how you can get a better phone . go to www.ytb.com/gizelle and click on "view company presentation".
May 06, 2009 | Samsung Blackjack SGH-I607 Smartphone
Black jack 2 wont charge or turn on
take out the SIM and micro sd and turn on the phone. then shut it off again, replace sim and micro sd then turn back on. DONE! **works on samsung jack too!!!
Apr 26, 2009 | Samsung BlackJack II Smartphone
Phone will not stay on
maybe your mobile battery is defected ,
Jan 14, 2009 | Motorola Mobility RAZR V3
Battery wont charge
First of all (change your 1.charger 2.battery 3.battery jack then there will be a problem of Power I.C because the battery jack is connected to power I.C then change it.....That's all.
Jan 02, 2008 | Nokia 1112 Cellular Phone
Problems with laptop staying powered up.
Sounds like you have a bad power jack. http://www.800tech.com/
Sep 03, 2007 | Balance CN6555 Notebook
Samsung BlackJack II Smartphone Logo
137 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
