Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Esp 3200 error code 2077 not enough memory - Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I have a Cash Register Casio TK-3200 and I am getting error 15 and is not listed in the error listing.. how do I fix it ??????
Hi Luis - Error code 015 refers to Receipt Paper End.
Error code 014: Receipt paper end (1/2) RECEIPT PAPER EN (plain English message)
Error code 015: Receipt paper end (2/2) D
There are several versions of the TK-3200 manual but this one lists the error code you want:
http://www.salopcashregisters.co.uk/pdf's/TK-3200.PDF
Aug 04, 2013 | Casio tk-3200 cash register
Ram for my pc
Yes.
Why?
Hans Pedersen,
http://www.fixya.com/support/t16340342-ram_required_motherboard
http://www.okmemory.com/Foxconn-N_Motherboard_Series-N15235-D27847-memory.html
It IS DDR2 Sdram ram memory.
Has 240 gold plated contact pins. 120 on EACH side.
Has one Locating Notch on the bottom.
It is DDR2 Sdram that operates at a maximum frequency rate ('Speed') of 400MegaHertz.
[400MHz]
Also known as PC2-3200
It is Non-ECC. Your computer USES Non-Error Correcting Control
http://en.wikipedia.org/wiki/ECC_memory
[Also known as Error Correcting Code ]
NO MATTER WHAT, make sure there is a ram memory module ('Stick') in Slot 1. Also known as DIMM 1.
This is the ram memory slot closest to the Processor. (CPU)
For additional questions suggest posting in a Comment.
Not a new product question.
Regards,
joecoolvette
Feb 03, 2013 | Computers & Internet
I want the authorization code for that serial number 1111-1111-1111-1111-1111-1111. and Activation Number 1263-8719-2872-6976-2077-7426-3135-7617.my email id is karthikeya.765@gmail.com
Photoshop CS
for
serial number:- 1045-1385-4532-0315-3672-3288
Activation Number:- 1263-8719-2872-6976-2077-7426-3135-7617
authorization code:-3271-7022-3767-6682-5464
and for
serial number:- 1045-1174-5355-7811-8116-1363
Aug 29, 2011 | Adobe Photoshop CS for PC
Kodak esp5 error code 3821
Your error code, 3821, means that the internal memory is screwed up!
Solution:
Unplug the printer for 30 seconds, and then plug it in again. If you want, you can wait a whole minute for the memory to discharge itself. Anyway, that will force a memory reload and everything will be just fine.
Apr 11, 2011 | Kodak ESP 5 Printer
Hello p.c. proffessional's: my name is Harold, I just recieved a Kodack ESP 3200 series...All in one printer for Christmas. My two questions for now are, Can i hook this printer to my xp window...
Question 1: You should be able to hook it up to that.
Question 2: It's rather simple - here are the steps (these will work on any USB printer):
1. Install the drivers from the CD.
2. Plug in the printer's power (If it hasn't told you to already).
3. Plug in the USB cable (If it hasn't told you to already).
Dec 25, 2010 | Computers & Internet
I have successfully installed my ESP 3200 into a Compaq lap top but my 9 year old etower PC does not recognise this model of printer. I have inserted the disc to no avail. Can you advis please?
How is the ESP 3200 connected to the 9 year old tower? Do you have it on the network and are trying to add it through the network, or how does the old tower have access to the same printer that the laptop does?
Please let me know, just reply here to my answer and I can help,
Tim
Nov 05, 2010 | Computers & Internet
Is tosshiba satellite computers are compatibile to kodak esp 3200 or3250
Yes ofcourse toshiba is compatible wi th kodak esp
it will run without any problems.so go for it
Thanks
Jul 28, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
I am getting a code of E000751-0302, not all the time but is becoming more frequent. I have the codes for the 3200 but this one must be 3220 only as it is not listed. Thanks, Tom
E751 (0302) code is not found in the Service Manual. This code is addressed in Tech Pub TP03 125. The code refers to a memory writing error in the magenta drum unit. Check or replace the magenta drum unit or the Memory board (Memory Board part number is FG3-2345-000.
E751 The connection of the drum unit /toner container is faulty. The mark x indicates color [Y=1, M=2, C=3, K=4]. 000x The connection of the drum unit (at the printer side) is faulty. 100x The connection of the toner container (at the printer side) is faulty. 010x Built-in memory writing error in the drum unit. 110x Built-in memory writing error in the toner container. 020x Built-in memory data error in the drum unit. 120x Built-in memory data error in the toner container. 030x Built-in memory writing error in the drum unit (When the number of retry exceeds the specified value) 130x Built-in memory writing error in the toner container (When the number of retry exceeds the specified value).
Sep 30, 2009 | Canon Office Equipment & Supplies
Error code 1-2036 on Kodak ESP3 printer
Perhaps this will help, universal error codes for the Kodak 5100 thru ESP 9 inkjet printers:
RME: Kodak
STATUS_OK_ALL = 0,
STATUS_OK_MANUAL_DUPLEX_STARTED = 97,
STATUS_OK_MEDIA_DETECT_STARTED,
STATUS_OK_FORM_FEED_STARTED,
* Informational (0100-0999):
* Busy (1000-1999):
STATUS_BUSY_SYSTEM_BUSY = 1999,
* Warning (2000-2999):
STATUS_WARNING_IMAGE_TOO_LONG = 2998,
STATUS_WARNING_IMAGE_TOO_WIDE,
* Asynchronous Ok (3000-3099):
STATUS_OK_MANUAL_DUPLEX_COMPLETE = 3000,
STATUS_OK_PAGE_EJECTED,
* Asynchronous Warning (3100-3199):
STATUS_WARNING_BLACK_INK_LOW = 3101,
STATUS_WARNING_COLOR_INK_LOW = 3102,
STATUS_INK_TANK_INVALID_MANUFACTURER_COLOR = 3103,
STATUS_INK_TANK_INVALID_MANUFACTURER_BLACK = 3104,
STATUS_INK_TANK_VERSION_EXCEEDS_FW_VERSION_COLOR = 3105,
STATUS_INK_TANK_VERSION_EXCEEDS_FW_VERSION_BLACK = 3106,
STATUS_MEDIA_VERSION_EXCEEDS_FW_VERSION = 3107,
STATUS_INK_OVERFLOW_EXCEEDS_CAPACITY = 3108, // Will be deprecated
STATUS_WARNING_BLACK_AND_COLOR_INK_LOW = 3109,
STATUS_WARNING_PROOF_SHEET_WRONG_MEDIA_SIZE = 3110,
STATUS_WARNING_PROOF_SHEET_WRONG_SESSION_NUMBER = 3111,
STATUS_WARNING_PROOF_SHEET_NO_IMAGES_SELECTED = 3112,
STATUS_WARNING_PROOF_SHEET_READ_ERROR = 3113,
STATUS_WARNING_MORE_THAN_1000_IMAGES = 3114,
STATUS_WARNING_INVALID_DPOF_FILE = 3115,
STATUS_WARNING_NO_IMAGES_FOUND = 3116,
STATUS_WARNING_SCAN_TO_OPERATION_FAILED = 3117,
STATUS_WARNING_BLUETOOTH_CONNECTION_DROPPED = 3118,
STATUS_WARNING_UNSUPPORTED_USB_DEVICES = 3120,
STATUS_WARNING_OVERCURRENT_USB_DEVICE = 3121,
* Asynchronous and Synchronous Error (3200-3499):
* Job Recoverable. No User Interaction.
// STATUS_PRINTER_BUSY = 3201, // not used. duplicated number
STATUS_INK_TANK_REPLACEMENT_IN_PROGRESS = 3207,
STATUS_PRINTHEAD_UNCAPPED_TIMEOUT = 3208,
* Asynchronous and Synchronous Error (3500-3599):
* Job Recoverable. User Interaction Required
STATUS_ERROR_UNIT_OPENED_WHEN_IDLE = 3501,
STATUS_ERROR_MAIN_PAPER_TRAY_EMPTY = 3502,
STATUS_ERROR_PHOTO_PAPER_TRAY_EMPTY = 3503,
STATUS_ERROR_PAPER_JAM_DURING_PICK = 3504,
STATUS_ERROR_NON_PLAIN_DETECTED_DUPLEX = 3505,
STATUS_ERROR_MEDIA_SIZE_MISMATCH = 3506,
STATUS_ERROR_INK_OUT_BLACK = 3507,
STATUS_ERROR_INK_OUT_COLOR = 3508,
STATUS_ERROR_INK_TANK_INSERTED_INCORRECTLY_COLOR = 3509,
STATUS_ERROR_INK_TANK_INSERTED_INCORRECTLY_BLACK = 3510,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_COLOR = 3511,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_BLACK = 3512,
STATUS_ERROR_PRINTHEAD_NOT_INSTALLED = 3513,
STATUS_ERROR_BACK_COVER_REMOVED_WHEN_IDLE = 3514,
STATUS_ERROR_CARRIER_STALL_DURING_PICK = 3515,
STATUS_ERROR_MEDIA_LOADED_UPSIDE_DOWN = 3516,
STATUS_ERROR_INK_OUT_BLACK_AND_COLOR = 3517,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_BLACK_AND_COLOR = 3518,
STATUS_ERROR_PHOTO_TRAY_ENGAGED = 3519,
STATUS_ERROR_FAIL_TO_DETECT_PAPER_EDGE = 3520,
STATUS_ERROR_VOLTAGE_TO_PRINTHEAD_NOT_CALIBRATED = 3521, // Should only be used at the factory
* Scanner (6000-6299):
SCANNER_ERROR_ADF_PAPER_OUT = 6101,
SCANNER_ERROR_ADF_PAPER_JAM = 6102,
SCANNER_ERROR_MOTOR_LOCK = 6201,
SCANNER_ERROR_MOTOR_MOVE_FAILED = 6202,
SCANNER_ERROR_HOME_NOT_DETECTED = 6203,
SCANNER_ERROR_CALIBRATE_FAILED = 6204,
SCANNER_ERROR_ADF_SENSOR_FAILURE = 6205,
/* Internal used errors. to be removed */
STATUS_ERROR_PAPER_JAM = 3201,
STATUS_ERROR_CARRIER_STALL = 3202,
May 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Code errors on kodak easyshare esp 3
error code 3501 means the front access door is open on the printer. Error code 3502 means the paper tray is empty. The error code 3602 means the print job did not finish printing.
for more hrlp visit CBR Tech Solutions
Apr 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
