Question about Vizio GV42L 42 in. LCD Television
Vizio TV Picture in Picture is showing as "snow" - can't get rid
Touched a wrong button - and the small PIP box came up in the bottom right corner of the TV showing a picture of "snow". (I was not trying to do PIP). No matter what I try - I cannot get rid of the box. I have even unplugged the TV and cable box - it is still there. Help!
4 Suggested Answers
SOURCE: vizio plasma hd 42
Sounds like you hit the PIP (picture in picture) button on the remote. Hit it a few more times and it should go away.
Posted on Jun 19, 2008
SOURCE: vizio 37in lcd yellowed picture
Mine turned red. Had a bad HDMI cable. TV is missing part of the video feed. Try a new cable but first make sure old cable is in all the way.
Posted on Feb 27, 2009
alpug
  • 1961 Answers
SOURCE: Turned TV on a week ago to find that there was a
can you post a picture of your TV so I can help you analyzed the problem..tnx.
Posted on Jun 24, 2011
How do I disable PIP?
Some remotes allow PIP to be turned on and off but your initial set up routine may have to be revisited to prevent PIP from popping up uninvited.
Aug 18, 2015 | Televison & Video
My vizio flat screen has screen stuck in top right
Your TV is in Picture in Picture (PiP) mode. The small picture is the previous live input. The bigger dark area is the current input where there's no live source.
Find the PiP button on the TV remote or via the TV's menus. Press PiP a number of times to cycle through the options. Stop when the picture is the size you want.
Have a read of your TV manual. Stuff like this is detailed in there.
Sep 02, 2014 | Televison & Video
My vizio flat screen has picture in small box in top right corner
It is in Picture in Picture (PiP) mode. The small picture is the last live channel. The big empty space is the current input but there's no signal
How do you get the picture in picture to work? What two sources can you use, a cable box and what?
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Let's say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected that's not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables; these can be found anywhere home theater equipment is sold. Then follow these steps.
1. Turn off both your cable box and television.
2. Take the coaxial cable that comes OUT from the wall and connects to the IN of your cable box and disconnect it.
3. Connect that cable to the IN on your coaxial splitter.
4. Connect your two extra coaxial cables to the OUTs on your coaxial splitter. We will call them cable 1 and Cable 2, just because.
5. Connect cable 1 directly to the DTV/TV input on your television.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by their Green, Red, Blue colors for video and Red and White cables for audio.)
7. Power on both the cable box and your television. Using the INPUT button on your VIZIO remote select the input connection where your cable box is located your cable box picture should come up on the Main screen.
8. Press the PIP button on your VIZIO remote to bring up the small box in the corner. Press the PIP input button until you select the TV input and you should be ready to go. You may need to perform a channel scan with your TV tuner to locate all available channels before you do this step. In order to understand better how to perform a channel scan please check under the F.A.Q.s in the discussion area of your particular model television.
In order to change channels in the small screen use the PIP CH - and + buttons located near the bottom of the remote. You can swap picture in the Main and Sub screens using the swap button and swap which screen will sound off its audio by using the AUDIO button. You might notice an X next to some of the selections in the INPUT and PIP INPUT screens when you have PIP activated. That means that input selection is unavailable and cannot be used. For example, if you have the input TV selected on your main screen then if you press the PIP INPUT button and bring up that input menu you will see X's next to the TV and AV selections. The X's mean that when you have TV on the main screen you won't be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them.
Sep 14, 2011 | Vizio VF550M 55 in. LCD HDTV
How to work viewsonic remote
Hi red recruite,
I am happy to help.
The blue box is the Picture in Picture function. Press the PIP button on remote till gone.
The No Entry Sign on the inputs is because nothing is connected to these inputs.
Unless  I an mistaken you have only a HDMI cable connected.
Let me know if I got it right and please rate this solution. Please keep in mind that Thanks For Trying rateing is negative.
Lone99star
Jan 28, 2009 | ViewSonic NextVision N3260W 32 in....
PIP
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Lets say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected thats not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables, these can be found anywhere home theater equipment is sold. Then follow these steps.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by thier Green, Red, Blue colors for video and Red and White cables for audio.)
unavailable and can not be used. For example if you have the input TV
selected on your main screen. If you press the PIP INPUT button and
wont be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them. PIP like this is not possible using any dish or satellite broadcasting companies as all of their signals must go through their boxes to be decoded. The televisions internal tuner can not handle those signals and turn them into anything watchable. If you are using one of these companies contact them to see if they offer a set top box that does PIP on its own and doesn't need the televisions help to accomplish it.
Oct 11, 2008 | Vizio L37 Television
Vizio plasma hd 42
Jun 16, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
PIP
Look for a "PIP" (Picture In Picture) button on the remote or in the TV's menu. I suspect that it has been pushed but there is not a second source to view. That would explain the smaller version in the corner.
Apr 08, 2008 | Vizio GV42L 42 in. LCD Television
Vizio GV42L 42 in. LCD Television Logo
341 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
