Printer status : 5002 material end
My hp Photosmart 7450 printer was working, then in the middle of printing it stopped and there is an error message on my computer, the green light is blinking on printer but won't print
First things first... try connecting your printer to another pc or laptop and try printing... make sure spooling is on in the driver and there are no other programs running...
if issue reappears then
It sounds like your printer cartridges are the issue
I would try reinstalling them...
if that does not work then
I would try cleaning your printer cartridge...
Gather cleaning supplies:
Clean distilled water. Use bottled or filtered water if distilled water is not available.
Clean cotton swabs or any soft, lint-free material (coffee filters work well).
Remove both cartridges.
Unplug the printer.
Lightly moisten the lint-free cleaning material with clean water.
Clean the cartridge contacts. Avoid touching the nozzles. Replace the cleaning material if it gets dirty.
If that does not work then I would try ordering some new cartridges
hp photosmart 7450 ink cartridges
Sep 12, 2012 | HP Photosmart 7450 InkJet Printer
Conon mp 258 printer error 5002 fix,However
Indicator appears blinking lights on the printer " P,O, 8?. That Mean The print head temperature above the specified value. You can replace the ink cartridge
for more help visit https://cbrtechsolutions.net or
CBR Tech Solutions
Mar 12, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
I get an Error 5002 when I try and print to my printer from my pc.
Yes, make sure you have the installation disk first.
Open Printers and delete the printer.
Disconnect the printer cable
Go to Control Panel and Programs
Find the software for the printer, highlight, then click uninstall. If asked, select to remove all.
Then reinstall the printer and connect the cable when asked.
Let me know if that fixes the problem.
Thanks, Jim
Feb 21, 2011 | Office Equipment & Supplies
I have and Canon iR3570 and when SNMP is disabled the printer goes offline and network printing ends. Enable SNMP and change the default community to something more secure and printer goes offline and...
It's possible that the SNMP Status Enabled box is checked on the print server (Printer/Properties/Ports/Port Settings). When you disabled SNMP or changed the community name on the printer, the server was no longer getting status updates and so flagged it as offline. Make sure the community names match.
Aug 31, 2010 | Canon ImageRUNNER 3570 Copier/Printer
What does drum end soon mean? Status monitor for my brother MFC-944)CN printer is saying Drum end soon! the file is being sent the status says ready, the paper goes through and comes out blank!
1. replace drum unit
2. after replacing reset the counter - press "3" and "9" button at the same time in the ready state, the reset menu will appear on the LCD, select "DRUM" and press "ok"
resetting without actual drum replacement might damage your printer.
Jun 29, 2010 | Brother MFC-9440CN Laser Printer
Cant print, pending has no status.
Please check printer cable both end otherwise please replace the data cable.This is the only data cable faulty/ lose connection problem.
Jun 01, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Printer keeps on jamming paper
Dear all,
I will try to help you. Paper jam error may be caused by some possibilities. So, please notice this indication:
  • If the printer status is READY immediately after Power ON then Paper Jam Error message appears while feeding the paper: Sheet Feeder Unit is faulty or any other material (such as broken paper) present inside paper path blocking paper end to reach paper feed sensor.
  • If Paper Jam Error messages appears immediately after Power ON: Paper feed sensor or logic board is faulty
Corrective action:
  • Remove the material from paper path
  • Replace Sheet Feeder Unit
  • Replace Paper Feed Sensor / Logic Board
Please rate me as Fixya if you find this useful for you. Thanks.
Source:
Canon Inkjet Printer Forum
Re
Sep 01, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Status monitor for Konica Minolta 2400w
The status software does not run when the printer is shared. Whenever I have a problem I have to unshare the printer then run the status and it will show up. I then resolve the problem then turn the share back on.
Pain I now but it works
Aug 02, 2008 | Konica Minolta magicolor 2400 Laser...
Unfamiliar Error message:
This seems to be related to a network problem, specifically, authentication. Has anything been changed or upgraded recently? There are a number of references to the error on the internet. I have attached them below.
Firstly, one user has looked at the /var/log/messages log file and found the additional error "uam: uam not found (status=-1"
Can you check that log?
A fix suggested by one user is:
"Turns out I needed to update the nettalk version that was included with YDL 2.3 to version 1.5.3.1-1c. After that and a restart apple talk works perfectly, on both our os9 and X machines." Maybe there is a lead there.
Attached bits from other users below.
Apparently, this error is "-5002 afpBadUAM: AFP Bad UAM," something to do with the User Authentication Module.
I've looked in var/log/messages
>>and it says : uam: uam not found (status=-1)
http://www.yellowdoglinux.com/support/solutions/ydl_2.3/netatalk.shtml
Good Luck. If you need to talk further, pls post it here. Rgds,
May 08, 2008 | Apple MacBook Pro Laptop Computer with...
67 people viewed this question
jasbo
jasbo
