Question about ASK Proxima M1 Multimedia Projector
Blue Screen We have a Proxima M1 projector. The image is displaying a deep blue tint overall. We tried restoring factory presets, adjusting color temperature and balance, etc. No change.
  • 2,237 Answers
You have a dmd chip failure or a main board failure. may just need reflashing.
Posted on Sep 03, 2009
The image color on projection is not the same as shown in laptop. There's is no red color.
It could be a broken connection in the computer lead for the red signal, or a fault on the projector that the red panel doesn't work any more.
To diagnose, bring up the projector's on screen display. If there's white in the menus then the problem is the cable. Replace it with a new one. If the menus are affected too then it's a projector problem. This requires the attention of a service engionner.
Aug 20, 2014 | Toshiba Tdp-s25 1080i 720p Hd Dlp...
VT540 projector does not receive the input impulse from the laptop..... just a blue screen
try the Factory Default that's located in the User Menu... located at Image Options Menu, which is in the Advanced Menu. what this does is reset the settings and/or adjustments to factory preset levels.
May 31, 2011 | NEC MultiSync VT540 Multimedia Projector
Image looks doble in colors.Gren,Blue Red
Depending on how severe it is, it can be fixed. I can do the repair if you'd like.
Mar 10, 2010 | InFocus Proxima DP6155 Multimedia...
Proxima c180 has a rectangular yellow image in the center of the screen. You can see the displayed image through the yellow. The lamp has been replace and no improvement
the polarizer on the blue lcd panel is fried due to excessive dust and heat. you may need to replace the whole optical engine. send it in to an infocus service center for repair. try www.avsolutionsny.com. they're really good.
Jan 26, 2010 | ASK Proxima C180 Multimedia Projector
No matter how |I try I cannot adjust the projector
Don't know this model but try the colur temperature- turn it down to the kelvin temp. (sorry is this is a too obvious solution- hope it helps)
Jan 08, 2010 | Epson (ELPLP25H) Projector Lamp for...
Projection has yellow tint
From your description, it sounds like a problem with the blue color. Green LCD=purple onscreen, Red=cyan(baby blue) onscreen, Blue LCD=yellow onscreen. It could be a lot of dust on the blue lcd panel, or worse, might be a burned polarizer filter behind the lcd panel due to excessive heat. If you can focus on the yellow and its tons of yellow specs, its dust. A burned filter however, must be replaced. A technician trained in projectors will have to do it. The filter material is glued to a thin glass panel and is replaced as a single filter. It's a very involved repair.
Sep 04, 2009 | Hitachi CP-X251 LCD Projector
Hitachi cp-s240 blue tint cloud problem
This might sound like a worn spot in the (blue) lens from heat, or a bad color driver on the mother board. It could possibly be dirt or condensation behine the lens(s)
Jun 19, 2009 | Hitachi CP-S240 Multimedia Projector
Display has a green tint to it tho it looks fine on the laptop.
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loose cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Assuming that you've made sure that the cable connections are solid at both ends, there is a simple test to verify that this is a cable issue and not a costly projector issue. While the image is tinted green, open the menu. If the menu colors appear fine while the rest of the image is still tinted green it's the cable.
Jan 21, 2009 | InFocus LP70+ Multimedia Projector
NEC LT35 color problem
If you're trying to project video, then the unit needs professional service. If you're trying to project from a computer, you may have a loose display cable, broken pins in one or both ends of the display cable, or broken conductors (wires) within the display cable. The computer sends its image information as a template of RED image components, GREEN image components and BLUE image components with the projector overlays to create the complete image with blended color values. (The computer also sends HORIZONTAL and VERTICAL synchronization signals, but those don'e affect the color content of the projected image.) That's why I'm suspicious of the display cable, conductors or pins.
Jul 02, 2008 | NEC LT35 Multimedia Projector
Infocus LP70 - It's all Green
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loos cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Nov 20, 2007 | InFocus LP70+ Multimedia Projector
ASK Proxima M1 Multimedia Projector Logo
215 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
240cpa
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
