Question about Samsung SyncMaster 460PXN LCD Monitor
Check cooling system - Samsung SyncMaster 460PXN LCD Monitor
What Should I do to Maintain the cooling system of my Hyundai Verna 2016?
In the cars, the engines use liquid cooling which comprises of various components and thus the system is a bit complicated. Here are a couple of tips you should follow to keep the Hyundai Verna engine cooling system running fine so that it doesn't surprise you in the middle of nowhere, check out the mention link
=> Top 4 Tips to Maintain Your Car Cooling System
=> How to Maintain Car Cooling System
Jan 17, 2018 | Hyundai Cars & Trucks
When i start my 2008 Cadillac sts i get a notification that engine hot A./C off. Even though it is the first time i stated it today
ENGINE HOT - AC OFF
Cooling System Description and Operation
you must have a cooling system problem of some sort !
Do the cooling fans come on when A/C is switched on ? Fan's should come on ! Does your vehicle have two or three cooling fan's ?
Cooling Fan Control - Two Fan System
The engine cooling fan system consists of 2 puller type electrical cooling fans and 3 fan relays. The relays are arranged in a series parallel (S/P) configuration that allows the engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block. The ground path is provided at G104.
During low speed operation, the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan S/P relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the ECM supplies a ground path for the high speed fan relay and the cooling fan S/P relay through the high speed cooling fan relay control circuit. This energizes the cooling fan S/P relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time, the high speed fan relay coil is energized closing the relay contacts, and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit, to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
The ECM commands the low speed cooling fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 94.5°C (202°F).
• A/C refrigerant pressure exceeds 1447 kPa (210 psi).
• After the vehicle is shut OFF, if the engine coolant temperature at key-off is greater than 101°C (214°F), the low speed fans will run for a minimum of 60 seconds. After 60 seconds, if the coolant temperature drops below 101°C (214°F), the fans will shut OFF. The fans will automatically shut OFF after 3 minutes, regardless of coolant temperature.
The ECM commands the high speed fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 104.25°C (220°F).
• A/C refrigerant pressure exceeds approximately 1824 kPa (265 psi).
• When certain DTCs set
At idle and very low vehicle speeds the cooling fans are only allowed to increase in speed, if required. This ensures idle stability by preventing the fans from cycling between high and low speed.
Cooling
Having a qualified professional technician check it out would be your best bet ! Hooking up a factory or professional type scanner an check data input's an DTC'S - diagnostic trouble codes .
Diagnostic Starting Point - Engine Cooling
Begin the system diagnosis with the diagnostic system check. Refer to Diagnostic System Check - Vehicle . The Diagnostic System Check - Vehicle will provide the following information:
• The identification of the control modules which command the system
• The ability of the control modules to communicate through the serial data circuits
• The identification of any stored DTCs and their status
The use of the Diagnostic System Check - Vehicle will identify the correct procedure for diagnosing the system and where the procedure is located.
DTC P0480: Cooling Fan Relay 1 Control Circuit
DTC P0481: Cooling Fan Relay 2 Control Circuit
DTC P0691: Cooling Fan Relay 1 Control Circuit Low Voltage
DTC P0692: Cooling Fan Relay 1 Control Circuit High Voltage
DTC P0693: Cooling Fan Relay 2 Control Circuit Low Voltage
DTC P0694: Cooling Fan Relay 2 Control Circuit High Voltage
DTC P1258: Engine Coolant Overtemperature - Protection Mode Active
DTC P2600: Auxiliary Coolant Pump Relay Control Circuit
DTC P2601: Auxiliary Coolant Pump Performance
DTC P2602: Auxiliary Coolant Pump Relay Control Circuit Low Voltage
DTC P2603: Auxiliary Coolant Pump Relay Control Circuit High Voltage
Dec 10, 2017 | Cadillac Cars & Trucks
Changed a radiator today, drained system. Hot water will not heat now. Heating and radiators are working ok
Helen, if it is the radiator in your car that was changed, you may have air in the cooling system that needs bled out. May also be a failing water pump, thermostat,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Bleed Cooling System EricTheCarGuy
Bleeding Air In Cooling System
How to Bleed Air From Your Cooling System DoItYourself com
May 02, 2016 | Cars & Trucks
Is there 2 pumps on cooling system
No there is not two pumps on a cooling system. If your car is overheating then it can be many problems. Take it to a professional where they can further diagnose it.
Jan 04, 2015 | 2000 Chevrolet Venture
Overheating,
First check the level of cooling .After check cooling system when engine work open the radiator and check for cooling fluid moving or not when you throttle .Or may be have air in the cooling system and make air pillow.
Dec 15, 2014 | 2011 Honda CBR125R
I just put a brand new radiator and radiator cap in my car and its still over heating and now its misfiring what could be causing this?
Did you bleed the cooling system? and check operation of the thermostat, which should have been done after fitting radiator before finishing by putting on radiator cap.
If not remove radiator cap when cold get vehicle warm and check thermostat operation, while bleeding any air pockets in cooling system and if no flow and bubbles or it starts to boil (shooting water) out of radiator the thermostat could be jammed or head gasket blown.
Sounds like it could be a blown head gasket. Get it hot again and miss firing, remove and inspect all spark plugs you may find a very clean spark plug indicating water entry into that cylinder or even water/coolant droplets in spark plug. You can also hold paper over spark plug holes and give the engine a quick crank over to see if any water comes out of cylinder while cooling system is still under pressure, or use radiator pressure tester to pressurize cooling system, wait 5-10 minutes and then crank over checking for water/coolant in cylinders. Another tool to check for blown head gaskets that cause overheating is a TK Head check, which sniffs the cooling system for evidence of exhaust fumes in cooling system.
Jul 21, 2011 | 1992 Toyota Celica
Code P0A93 for toyota PRIUS WHAT IS THE PROBLEM ? Check Engine light and ! and VSC Warning lights I looked up code P0A93 equals StandaRD DTC'S (ISO 15031-6/SAE J2012) WHAT THIS MEAN?
P0A93 is an inverter cooling problem. The inverter is cooled by a dedicated cooling system, which consists of an electric water pump, cooling fan, and radiator. This cooling system is independent of the engine cooling system.The mechanic should check if there is sufficient amount of coolant for the inverter, check if the coolant hose is not bent or clogged, if the water pump / cooling fan motor connections are ok, and of course if both of the cooling fan motors are OK
Sep 20, 2010 | 2004 Toyota Prius
Hello Ive got cooling fault on my galaxy 3000 can u help
try to check the fluid in the cooling system, if it's full. then try to check the sensor on the cooling cap, or maybe change the sensor. Hope this help.
ps: cooling liquid is not water ( buy it from mge, i forgot what's the name )
Sep 04, 2010 | MGE UPS Galaxy 3000 UPS System
How to change a radiator
1988–91 Models
  1. Disconnect the negative battery cable.
  2. Properly drain the cooling system into a suitable container.
  3. Disconnect the fan motor and motor connector.
  4. Disconnect the upper and lower radiator hoses.
  5. Disconnect and plug the automatic transaxle cooling lines at the radiator, if equipped.
  6. Disconnect the coolant reservoir overflow hose.
  7. Remove the radiator attaching bolts and brackets.
  8. Remove the radiator with the cooling fan attached.
  9. Remove the cooling fan and shroud from the radiator. NOTE: Check all cooling system hoses for any signs of damage, leaks or deterioration and replace if necessary. To install:
  10. Attach the cooling fan and shroud to the radiator and install the assembly.
  11. Attach the radiator bolts and brackets. Tighten the radiator bracket bolts to 7 ft. lbs. (10 Nm).
  12. Connect the coolant reservoir overflow hose.
  13. Connect the automatic transaxle cooling lines to the radiator, if equipped.
  14. Connect the upper and lower radiator hoses.
  15. Connect the fan motor and thermo-switch wire connector.
  16. Refill the system with the proper type and quantity of coolant, check for leaks and bleed the cooling system.
  17. Reconnect the negative battery cable. Fig. 7: Cooling system components — 1988–91 engines 86833085.gif
1992–95 Models
  17. Reconnect the negative battery cable. Fig. 8: Cooling system components — 1992–95 engines 86833086.gif
Aug 27, 2010 | 1991 Honda Civic
Cooling fan on radiator do not work sending unit on block checks ok with oms meter relay in fuse box ok now what
Change the thermostat and bleed the ir from the cooling system,then ,if the cooling fans do not come on,check the relay module under the cooling fans on drivers side,they are bad to go out,but if there is air in the cooling system,the cooling fans will not come on.
May 31, 2010 | 1998 Dodge Caravan
Samsung SyncMaster 460PXN LCD Monitor Logo
Jerry Greenberg
Jerry Greenberg
