With sound no picture...but there is a light in tube.
SOURCE: KV-36FS10 - No picture or sound Stand By Light blinks
5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
SOURCE: kv-32s120 standby LED blinking no sound or picture
the led next to my power button flashes nonstop on my sony wega kv27fs320
what do i do thanks
SOURCE: Sony Trinitron 2002 Model #
7 times blinks shows problem in Horizontal Deflection stage of tv and possible defective part can be Horizontal Output Transistor or Fly back Transformer.
If your are qualified tech person then go ahead to check above parts.
SOURCE: kv-32fs16, no picture or sound , red lights flash 4 times
Hi
In sony tv`s the 4 blink code(sony error codes)usually means that there is a vertical deflection problem.
It is often caused by a faulty vertical output i.c and/or related components.
If you feel handy with a soldering iron let me know and i`ll help you with it.
Hope this help Merry Christmas
SOURCE: No Display, no sound- not working, showing dead.
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
