Question about Electro-Harmonix Memory Boy Analog Echo Chorus Vibrato Pedal
I was told that I can find the Electro-Harmonix Memory Boy schematic at the Studer Archive Service website. Pls can you let me know the website
When I on the unit, the power indicator LED is on, but there is no effect, none of the 4 knobs have any effect. I need a schematic to help solve this problem
Name some best Distortion Pedal. Where to buy them?
The best top 5 distortion pedal are:-
  • BOSS Audio DS1 Distortion Guitar Pedal
  • Pro Co RAT2 Distortion Pedal
  • Boss BD-2 Blues Driver Guitar Effects Pedal
  • Electro-Harmonix Nano Big Guitar Distortion Effects Pedal
  • Electro-Harmonix Soul Food Distortion/Fuzz/Overdrive Pedal
I use to buy any distortion pedal from this site
Top 5 Best Distortion Pedal You Must Buy New 2017 Musical Study as they guide the best to buy the best.
Jan 02, 2017 | Music
Problem with emt 262 reverb amplifier
The schematic is available from Studer's archive service. I forget the name of the service, but I found it on the Studer website. I had to send an email and request for the specific schematic, but a nice woman sent me a link. I downloaded it as a .pdf
Aug 07, 2012 | Music
Chorus on- no problem- noise free. Chorus off- big problem- massive hum. This item is supposedly "new" (stupid me, I bought from Ebay...)
It sounds like the bypass contacts on the pedal are not working... this may be right in the pedal switch itself. With unit in off position, use an ohmmeter to check continuity between in and out cable tips.
Sep 07, 2011 | Electro-Harmonix Electro Harmonix Neo...
I have a electro-harmonix , voice box , harmony machine and vocoder! I need to know what kind of power supply to use , as I have lost mine !
Takes a 9 volt DC 1 amp (1000 ma) center positive adapter. Not too common, search online and at Ebay.
Jul 28, 2011 | Music
A big hum of 100 c/s in the output,i need the schematic for repair
You must be on 50Hz power. You don't really need a schematic to repair the unit. Since the hum is twice power line frequency, the likely cause is the electrolytic filter cap for the high voltage has failed. The cap should be obvious in the unit. It will be near rectifier diodes and have a voltage rating above 50 volts. To test, bridge the one in there with another cap observing the correct polarity. If hum changes, replace the original cap.
May 25, 2011 | Electro-Harmonix 12ay7 Tube Microphone...
It stopped working and smelled burnt
I suspect the inut power circuits have a failure. Electrolytic filter cap and the votage regulator (probably a 7805 type) may have failed. IF the 7805 failed, then there is likely a short on the 5 volt supply to the electronics. In short, unless you are adept at electronics, you need to take it to an electronic tech for repair.
Nov 30, 2009 | Electro-Harmonix The Wiggler
Electro-Harmonix Memory Boy Analog Echo Chorus Vibrato Pedal Logo
62 people viewed this question
Top Electro-Harmonix Music Experts
freddybrass
Level 1 Expert
Tom Chichester
Terry
Terry
Are you an Electro-Harmonix Music Expert? Answer questions, earn points and help others
