Question about Manttra 36122 Stainless Steel Pressure Cooker, 6-Quarts. 36122
38111 parts - zpd safety plug and hold down cup
Nutribullet just stopped working,removed cup then replaced still no action...what now?
One probable reason for failure: The bottoms of the jars have outward-facing prongs which engage slots--incorporating integrated small power switches in the base. If those prongs break off or wear down--or, otherwise they can't make good contact by pushing inward those small switches (all of them)--your blender can't start.
It's an interlock safety feature intended to make certain users use the company's jars when starting their blenders. If the jar seems satisfactory, you may need to push down on the jar. (This reliance upon problematic plastic tabs holding up over time, in order to provide the safety feature, proves the "Achilles Heel" of this small kitchen appliance.
I've noted that Shark/Euro Pro appears to invoke a similar safety solution on their jars for at least some of their Ninja Blenders. The importer company behind Nutribullet still does offer replacement jars, I believe.
The company behind Nutribullet also warns users not to leave the base running for more than one minute at a time. (The system is designed to provide short, intense bursts of grinding and cutting power--not lengthy blending times.)
Aug 13, 2014 | Magic Bullet NutriBullet Nutrition...
My K10 MINI Plus keeps shutting off by itself
The shut down may come from a safety standpoint, whereby if a heater gets too hot, lines get plugged, or chambers are not filled with water as necessary; the unit could shut down accordingly. Try to clean the ports/lines/ and cup holder. Fill water to line (Not Over the line) and descale to clean the interior chamber.
Feb 19, 2014 | Keurig K10 K-cup Mini Plus Coffeemaker...
How to remove and clean and replace the rear brakes on a 2008Toyota yaris
REMOVING REAR BRAKE DRUM SUB-ASSEMBLY
1. Release the parking brake and remove the rear
brake drum.
If the rear brake drum cannot be removed easily,
do the following:-
2.Remove the hole rubber and insert a screwdriver
through the hole into the backing plate, and hold the
automatic adjust lever away from the adjuster.
3.Using another screwdriver, contract the brake shoe
by turning the adjuster.
4. Take out the brake drum from the flange.
5. remove the shoe hold down spring cup, shoe hold down spring, pin and front side brake shoe.
6. Remove the tension spring. Remove the shoe return spring from the rear brake shoe and remove the parking brake shoe strut set.
7. Remove the shoe holding spring cup, shoe hold spring, pin and rear brake shoe.
8. separate the parking brake cable.
9. Remove the automatic adjust lever tension spring and remove the automatic adjust lever.
10. remove the C-washer and remove the parking brake shoe lever.
NOTE: Do not use any solvent like gasoline to wash the brake parts.
Always wear safety goggles and mask before using compressed air.
Dec 28, 2013 | Cars & Trucks
How to reset keurig b40
1. There is some confusion over models. I've seen "B40" models and instructions with only one size cup button, both labeled B40. I own one stamped "B40" on the bottom, and it has two buttons -- small and large. FWIW, small = 8 oz, large = 10 oz.
2. These reset instructions from another site seemed to do something
What to Do If Your Keurig Won Brew Cup Barista
So.. this is what I did that worked for mine: 1) Hold down Auto-Off and LARGE cup at same time. (all lights should hold steady ON) 2) press SMALL cup while still holding Auto-Off and LARGE cup 3) Release all three, press LARGE cup again.. all lights should go off. 4) Unplug for about 5 - 10 second, plug back in. SHOULD WORK!
3. On *_my_* B40, remove the K-cup, close the door, fill the reservoir. Unplug and replug the B40. All lights should be off.
Pressing "Auto Off" and "Large Cup" together will turn on 3 lights (Heating, Add Water, Power) for about 3 seconds. Doesn't matter how long the buttons are pressed or what order they are released.
I tried lots of add-on combinations: e.g. press button x, press x multiple times, press x while lights are still on, press x after lights are off, press buttons x and y together, press x then y, press x and/or y while still holding Auto and Large, release Auto but not Large and press x, etc.
Nothing gave any confirmation that a reset was accepted. All lights always turned off after 3 seconds. Maybe Reset is only 1 step, i.e. Auto+Large together?
Jan 04, 2013 | Keurig Elite B40 Coffee Maker
When using the my k cup, i get water coming down in 3 streams.I have to hold the coffee cup up so that the coffee hits the cup
The bottom needle is plugged...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 22, 2011 | Keurig Elite B40 Coffee Maker
My dirt cup is stuck. how can i remove it?
You have to push the lever to open. Then hold down on the grey shelf the cup sits on with one fingernail, and pull up on cup. It should then slide out. The dust has made the cup get stuck to the shelf that goes up/down and hold the dirt cup.
Aug 18, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
1999 nissan quest rear brake shoes need changing
help is here:
http://autos.groups.yahoo.com/group/villagerquest/
Drum Removal
  1. Remove the rear wheel and the tire assembly. Refer to Section 204-04 .
  1. Retract the brake shoes and loosen the brake adjuster screw.
  1. Remove the brake drum.
May require big hammer to loosen drum from axle flange. Hit between the the lugs, not on them.
#10 is access plug to back off adjusting wheel.
Item Part Number Description 1 2261 Rear wheel cylinder 2 — Dust boot (part of 2128) 3 2197 Wheel cylinder piston (part of 2261) 4 — Cup (part of 2128) 5 2204 Wheel cylinder piston cup spring (part of 2128) 6 — Wheel cylinder housing (part of 2261) 7 — Brake shoe hold-down pin 8 — Access hole (part of 2212) 9 — Rear brake bleeder screw (part of 2261) 10 — Access hole plug 11 — Rear wheel cylinder bolt 12 2212 Rear brake backing plate 13 — Rear brake backing plate bolts 14 2N790 Parking brake lever clip 15 — Spring washer 16 — Secondary brake shoe and lining (part of 2200) 17 — Brake shoe hold-down spring (part of 2B514) 18 — Lower retracting spring (part of 2B514) 19 2A637 Parking brake lever 20 — Parking brake lever pin 21 2A177 Brake shoe adjusting lever 22 — Adjuster lever pin (part of 2A177) 23 — Primary brake shoe and lining (part of 2200) 24 — Upper retracting spring (part of 2B514) 25 2041 Brake adjuster screw
Shoes Removal
Take a picture and remember how each part goes and attaches
  1. Remove the brake drum, refer to Drum in this section.
  1. Remove the upper retracting spring.
  1. Remove the lower retracting spring.
  1. Remove the self-adjuster.
  1. Remove the hold-down springs.
  1. Remove the parking brake lever clip and the parking brake lever.
Apr 17, 2009 | 1999 Nissan Quest
Manttra 36122 Stainless Steel Pressure Cooker, 6-Quarts. 36122 Logo
63 people viewed this question
Top Manttra Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Manttra Kitchen Appliances - Other Expert? Answer questions, earn points and help others
