Question about Ovens
I have a whirlpool self cleaning double oven, no manual, just moved in to house. Anyways, oven is reading E6 F2 on screen.
  • 84 Answers
E6 F2 on a whirlpool double oven translates to "Cancel Key drive open". We see this frequently and is always a problem with the control board. At www.fixyourboard.com it can be repaired quickly and reliably at a fraction the cost of a new board.
Posted on Nov 01, 2010
How to remove side panels on a whirlpool Gold double oven, in order to remove control panel. I would like to reconnect the control panel, it may reset the panel to work again
Hello Ms Jackson,
An E6-F2 is a very common control board failure. The control board in your appliance will need to be repaired or replaced.
Read more below about common Whirlpool oven Fault codes and what they mean. FixYourboard.com can repair this issue quickly and economically. We also back our workmanship with an industry leading two year warranty. http://blog.fixyourboard.com/2015/08/20/gbd-rbd-whirlpool-oven-problems-causes-and-solutions/
I've also attached a link on how to remove your Whirlpool oven control board How to Remove Whirlpool Oven Control Board
Feb 10, 2017 | Whirlpool Ovens
Rbd245pdt12 error code e6 &f2
This oven uses control board part number 8302967. E6 F2 is due to a failure in the control board. This board is no longer available from Whirlpool. It can be rebuild at www.fixyourboar.com with a 2 year warranty.
Apr 01, 2012 | Whirlpool RBD305PD Electric Double Oven
Received E6 and F2 code. repair man replaced the control panel key padand it worked for a while. stopped working and got same codes E6 and F2. Repairman saw the control's behind the key pad needed to be...
Hello & Welcome to FixYa
F2-E6 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure then before replacing the sensor you can test it with a voltmeter for around 1100ohms....if it reads more then 1120 ohms then it needs replacement however, if the reading is between 1080-1120 ohms then it is the control board that needs replacement. However, after reading your problem it seems that the sensor is causing this and replacing it is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 15, 2011 | Whirlpool GBD307PR Electric Double Oven
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
Whirlpool double ovens error message e6 f2
good day,
hope this link below will solve your problem.
ovens
Mar 26, 2010 | Whirlpool RBD245PDS Electric Double Oven
E6, f2
You have a stuck or shorted keypad. Try Cancel/Off and hold for 10 seconds. Then push every key several times to unstick. If that does not work unplug range and remove the access panel, disconnect the wire connections, then replace them. If all these steps fail replace the control. good luck
Jun 06, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool RbD275pdq10 double oven E6 F2 error
I have a "double oven", Model # RBD275PDQ10 and it has Error Code E6 F2, What is the part that I need to fix it?
Dec 20, 2008 | Whirlpool RBS245PDS Electric Single Oven
Error code E6 F2
hi there. i have located the manual and posted the link below.
PARTS MANUAL
Oct 23, 2008 | Whirlpool GBD307PD Electric Double Oven
Display F2 E6 error, then dead. Keypad realted? How do I remove control panel?
fiest press the on key see if the display comes if not the turn the power off for 5-8 seconds if that doesnt do it turn power off then pull the oven out from the wall and remove the top to acess eoc pull the mylar ribbion out of the eoc by releasing the latch which is a tiny pullout bar at the base of the connector at the eoc then you cam clean the ribbon gently with a clean pencial eraser also under the top panel will be a tech sheet with more info pay atten to resseting the oven cavity size on start up
May 15, 2008 | Whirlpool RBD275PD Electric Double Oven
Ovens Logo
153 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
