Question about Acer Aspire 4530-5889 Notebook PC
Temperature of my acer 4530, which i think not normal
My acer 4530 has a temperature of the GPU gets up quickly and high, it has minimum of 69c up to 71c and when i play games it goes up to minimum of 82c up to 92c.
is this normal temperature or there is something wrong with my laptop? please help me with this problem, i bought it for less than a month.
  • 1 more comment
  • Anonymous Jan 28, 2009
    my laptop with same model has a temperature that is very hot. what is the problem? and what are the effects of it?
  • Sudhamshu Chandra Mar 04, 2009
    Hey, I also got the same model and it is really frying. But my laptop never beat 90. So nice to hear some one whose laptop has beaten that mark. of course, it crosses 80 mark only on a minimum of two hours of gaming. But the normal temperature of CPU itself will be around 65 and 70. HDD runs on 45 to 60.
    Note: All temperatures indicated are in centigrade degrees only.
  • Anonymous Mar 09, 2009
    I have the same model but mine has AMD Turion X2 dualcore 2.2 GHz as opposed to Athlon 64 X2 listed here.  The CPU normally runs at 60-70 Celcius when browsing the internet, but often go very high to 85-95 Celcius when playing intense games like call of duty 4. The GPU surprisingly remains constant at around 72 Celcius, eventhough it is still quite hot.  I wonder if these temperature is normal. Because it is trully very very hot and no cooling pad can help so far. I'm worried that running this for a long time will damage the cpu, and the motherboard.
    Problem Solver:
  • 17 Answers
I have all options enabled.
Posted on Apr 06, 2009
  • 32 Answers
Check if PowerMizer is enabled
It can help you drop the temperatures
Posted on Mar 11, 2009
What should my oil pressure in normal driving conditions be in a 97 Oldsmobile aurora
Minimum Pressure at Normal Operating Temperature @ Idle
35 kPa
5 psi
Minimum Pressure at Normal Operating Temperature @ 2000 RPM
250 kPa
35 psi
Jan 08, 2016 | Oldsmobile Cars & Trucks
My 01 Pontiac Montana is trying to overheat at high power
If your vehicle doesn't actually overheat, just getting hot, I think that's the normal behaviour for these cars. My 03 AWD behaves the same way. When driving uphill, especialy when towing, the temperature rises close to the red marking, but I have never experienced it overheating. I think that the temperature has to rise much over the normal driving temperature to activate the two electric fans.
Jul 15, 2014 | 2001 Pontiac Montana
GPU cooling problem
Try reinstalling the heat sink and putty on GPU. Make sure heat sink is fitting correctly. If the only thing you did was upgrade the fans and redo the putty, then your heat sink didn't seat properly.
Nov 01, 2013 | Acer Extensa Computers & Internet
Kenmore 700 series dryer little temperature difference between delicate and high
Using that thermometer I am guessing that the readings are close to what they should be. Typically there is not as big a temperature change between the two settings. What made her first think there was a big problem in the temperature settings?
Jan 22, 2013 | Kenmore Dryers
Acer Aspire Z5610 shuts downs
if you right click on "my computer" and click on manage, the console that opens has an option to look at the windows event viewer. if you look there, are there any errors reporting the shutdown (look in application and system logs) Otherwise you might be right in diagnosing the heating problem -> try to vacuum out the dust from the grid that sucks in the air -> if this doesn't help it may be time to replace the fan...
Sep 17, 2012 | Acer Computers & Internet
I have acer 4530, and it's going mad, my laptop temperature reach 90 -100 degree. it's going burn, please help...thx
Hi neo nietzsch...
Sounds like your cooling fan is faulty...
You need to try and blow the dust out of it using compressed air, by blowing air into the exaust of the laptop and hopefully this will clear your fan of dust and make your laptop run cooler.
If that does not solve the problem then your going to have to take your laptop apart and replace the cooling fan as it is defective.
Please take time to rate me
Aug 30, 2011 | Acer Aspire 4530-5889 Notebook PC
My acer laptop keeps switching itself off , and gets warm underneath , you can hear the fan working but still gets really warm, then switches off
That would be an overheat event. Spray some compressed air in the vents underneath, especially ones with fans, and most importantly the CPU fan.
If the problem persists, make sure your room temperature isn't extremely high (100+) or lay off of CPU/GPU heavy applications.
Jun 07, 2011 | Computers & Internet
I recently bought a XFX HD 5770 GPU Card. After placing it on my motherboard, I casually played games and monitored the temperature of my CPU and GPU. When playing games like GTA IV, the temperature of CPU...
I suggest that you get an additional cooling fan, just for your video card, as San Andreas is a highly complex game that utilizes the video gpu very hard. Oblivion is another game which does the same thing. Also, I would look at getting a seperate case cooler, the more fresh air you can get into the case, the cooler things will be.
Jan 18, 2011 | Pine Technology XFX RADEON HD 5770, (1 GB)...
Hi, I have a high temperature problem. Its about 72 degrees (celsius) in idle and eg durring gameplay it jumps right to about 90 degrees and i get a high temperature warning when it hits about a 100 or...
If you are not overclocking it then it could well be a faulty temp sensor. As that is at processor level you won't be able to fix it. It also depends on what prog you are using to detect the temp.
You would be able to feel it if it were at 100deg c. That's boiling point!
Jan 06, 2011 | ATI RADEON X1650 Pro, (512 MB) PCI...
Cooks too hot/fast
Hi Wendigo,
Crock pots are not exact, they only have a "target" minimum temperature (to be sure they kill bacteria). It's possible you just have a relatively strong heating element.
Also, remember that the boiling point of liquids changes considerably with your altitude, so if you're in a mountainous region you may be seeing "boiling" at a lower temperature than you expect.
Nov 12, 2007 | Rival 3040-VG 4-Quart
Acer Aspire 4530-5889 Notebook PC Logo
1,157 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
