Question about GE WBSR3140DW Top Load Washer
Agitator not working during was cycle what would cause this probl
Ge profile washer model wpsr3100woww
  • 1 more comment
  • remourrowe Jan 21, 2009
    Yes the washer does spin on the spin cycle. It acts up only when the waser fills and goes to the agitate or wash cycle
  • Anonymous Feb 05, 2009
    I have the same exact problem. I have the front panel off and have run the machine thru the various cycles. All systems work perfectly, motor, pump, belt drive, spin cycle, everything. When it is supposed to go into the aggitation mode, the motor turns the large pulley under the transmission, but no agitation. I think I will try the controller replacement if I can find one locally.
  • Quantum Flux May 11, 2010
    Does that washer spin? Are you having the problem across all cycles, or is it only on certain ones?
    Problem Solver:
  • 30 Answers
I'm experiencing the exact same issue with mine.
Can you hear the motor running during the agitation? If the motor is running, but the agitator isn't working, then that would point to something like the transmission, or some sort of obstruction that is preventing the agitator from working properly.
If the motor isn't running, then try running through different cycles. If it operates properly on one cycle, but not others, then I would tend to think that it's in the controller. If not, then it's likely in the motor. I also have seen a post somewhere instructing to check the vacuum connection to the water level control, as well. NOt sure how that plays into the equation, but it's easy enough to do & doesn't cost anything to try.
FYI: I just spent $10 for one of the "experts" here to tell me that the issue was "absolutely" in my motor. After spending $220 to replace a motor that I cannot return now since it's been installed, I find out that my original assessment is probably correct & my problem is in the controller.
If it comes down to a toss-up between the two, go with the cheapest first (likely the controller).
Hope this helps.
Posted on Jan 21, 2009
  • Quantum Flux Jan 24, 2009
    FYI...
    Today, I just replaced the controller in the machine & it now works wonderfully.
    Additionally, I would recommend checking out RepairClinic.com for your parts needs. I've used them several times & have found them to be prompt and very reasonably priced.
GE Profile WPRE6100G Top Load Washer My washer is 2 yrs old and has started to make a loud metalic banging noise during the wash cycle. It does not during the spin cycle. Doesn't seem to matter whether...
Hi!!
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90323.PDF
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 03, 2010 | GE Profile WPRE6100G Top Load Washer
Agitator will not work spin does
can you hear it trying or does it try with a grating sound,most of these have a plastic drive coupler underneath the agitator and this or the thrust bearing could be your issue,you need to remove the agitator parts first(and run a wash cycle without any clothes in the washer) and see if this is the problem,as with the agitator off the stem(both inner and outer) should run when held by hand during any cycles and there should be resistance as in no slipping during holding by hand,then if you still have problems then its further below this area
Nov 07, 2010 | GE Profile WPRE6100G Top Load Washer
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
Agitator is loose
Does the plastic cap unscrew (CCW)? If you get it off, there is a plastic block attached to the top of the shaft that should just pull off. Check it for cracking or splines that are torn out inside--replace it if damaged. Make sure the cap screws down tight.
Sep 08, 2009 | GE Profile WPSR3100W
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
Won't agitate during wash cycle, makes noise w/o movement
If you are able to tilt the machine back and check to see if the belt has fallen off.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | GE Profile WPSR3120WWW
My ge washer wpre6100g clicks during agitation part of cycle...
sounds like the agitater drive is stripped its a plastic piece under tha agitater you just grab the agitater work your fingers under the edges and **** up on it and it snaps off then remove the 5/16 screw put a new block on and snap the agitater back on
Jan 29, 2009 | GE Profile WPRE6100G Top Load Washer
During wash cycle the hub nut that is located under the agitator comes loose. It has to be tightened after each wash. GE Profile Top Load Washing Machine
replace the hub nut and the washers under the tubbe sure to tighten really tight if it comes loose again you will need to replace the transmition
Jan 15, 2009 | GE Profile WPRE6100G Top Load Washer
GE WBSR3140DW Top Load Washer Logo
151 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
